I have a project for the net I need to change to Fahrenheit. I am learning and used Visuino,
code below can I get a hint or two.
thanks
// Sketch Generated by Visuino
// www.visuino.com
// Version 7.8.2.290
//------------------ Source --------------------
// DHT11TemperatureHumidityI2CLCDDisplayInstructable.visuino
#define VISUINO_ARDUINO_NANO
#define _MITOV_DHT11_CLOCK_PIN_
#include <OpenWire.h>
#include <Mitov.h>
#include <Mitov_FormattedSerial.h>
#include <Wire.h>
#include <Mitov_Basic_I2C.h>
#include <Mitov_LiquidCrystalDisplay_I2C.h>
#include <Mitov_DHT_Sensor.h>
#include <Mitov_Timing.h>
// Arduino Board Declarations
namespace BoardDeclarations
Mitov::ArduinoDigitalInputChannel<2, false> ArduinoDigitalChannel_2( false );
} // BoardDeclarations
// Interrupts
namespace Interrupts
void Handler2();
OpenWire::PinFallingInterrupt Pin2( 2, Handler2 );
void Handler2()
Pin2.InterruptHandler();
} // Interrupts
// Declarations
namespace Declarations
Mitov::LiquidCrystalDisplay<Mitov::LiquidCrystalDisplayI2C<39,TwoWire,Wire>> LiquidCrystalDisplay1 = Mitov::LiquidCrystalDisplay<Mitov::LiquidCrystalDisplayI2C<39,TwoWire,Wire>>( 16, 2 );
Mitov::LiquidCrystalElementTextField<Mitov::LiquidCrystalDisplay<Mitov::LiquidCrystalDisplayI2C<39,TwoWire,Wire>>, Declarations::LiquidCrystalDisplay1> TArduinoLiquidCrystalElementTextField1;
Mitov::LiquidCrystalElementBasicPositionedWidthTypedField<Mitov::LiquidCrystalDisplay<Mitov::LiquidCrystalDisplayI2C<39,TwoWire,Wire>>, Declarations::LiquidCrystalDisplay1, Mitov::LiquidCrystalElementAnalogField, float> TArduinoLiquidCrystalElementAnalogField1( 0.0f );
Mitov::LiquidCrystalElementTextField<Mitov::LiquidCrystalDisplay<Mitov::LiquidCrystalDisplayI2C<39,TwoWire,Wire>>, Declarations::LiquidCrystalDisplay1> TArduinoLiquidCrystalElementTextField2;
Mitov::LiquidCrystalElementBasicPositionedWidthTypedField<Mitov::LiquidCrystalDisplay<Mitov::LiquidCrystalDisplayI2C<39,TwoWire,Wire>>, Declarations::LiquidCrystalDisplay1, Mitov::LiquidCrystalElementAnalogField, float> TArduinoLiquidCrystalElementAnalogField2( 0.0f );
Mitov::LiquidCrystalElementDefineCustomCharacter<Mitov::LiquidCrystalDisplay<Mitov::LiquidCrystalDisplayI2C<39,TwoWire,Wire>>, Declarations::LiquidCrystalDisplay1> TArduinoLiquidCrystalElementDefineCustomCharacter1( 0 );
Mitov::LiquidCrystalElementCustomCharacterField<Mitov::LiquidCrystalDisplay<Mitov::LiquidCrystalDisplayI2C<39,TwoWire,Wire>>, Declarations::LiquidCrystalDisplay1> TArduinoLiquidCrystalElementCustomCharacterField1;
Mitov::LiquidCrystalElementTextField<Mitov::LiquidCrystalDisplay<Mitov::LiquidCrystalDisplayI2C<39,TwoWire,Wire>>, Declarations::LiquidCrystalDisplay1> TArduinoLiquidCrystalElementTextField3;
Mitov::DHT11Sensor_Interrupt<2, Interrupts::Handler2> HumidityThermometer1;
Mitov::ClockGenerator ClockGenerator1;
} // Declarations
// Pin Call Declarations
namespace PinCalls
void PinCallerReceive1( void *_Data );
void PinCallerReceive2( void *_Data );
void PinCallerReceive3( void *_Data );
} // PinCalls
// Pin Call Implementations
namespace PinCalls
Declarations::TArduinoLiquidCrystalElementAnalogField1.InputPin_o_Receive( _Data );
Declarations::TArduinoLiquidCrystalElementAnalogField2.InputPin_o_Receive( _Data );
Declarations::HumidityThermometer1.ClockInputPin_o_Receive( _Data );
} // PinCalls
namespace ComponentsHardware
void SystemUpdateHardware()
} // ComponentsHardware
//The setup function is called once at startup of the sketch
static const uint8_t _CharMap[] PROGMEM = {12, 18, 18, 12, 0, 0, 0, 0};
Declarations::TArduinoLiquidCrystalElementDefineCustomCharacter1._CharMap = _CharMap;
Interrupts::Pin2.SubscribeFalling( (OpenWire::Object *)&Declarations::HumidityThermometer1, (OpenWire::TOnInterrupt)( void (OpenWire::Object::*) ( bool ) )&Mitov::DHT11Sensor_Interrupt<2, Interrupts::Handler2>::InterruptHandler );
Declarations::HumidityThermometer1.ClockInputPin_o_IsConnected = true;
Wire.begin();
Declarations::TArduinoLiquidCrystalElementTextField1.InitialValue = "Temp:";
Declarations::TArduinoLiquidCrystalElementTextField1.Width = 10;
Declarations::TArduinoLiquidCrystalElementAnalogField1.Precision = 1;
Declarations::TArduinoLiquidCrystalElementAnalogField1.Width = 4;
Declarations::TArduinoLiquidCrystalElementAnalogField1.Column = 10;
Declarations::TArduinoLiquidCrystalElementTextField2.InitialValue = "Humidity:";
Declarations::TArduinoLiquidCrystalElementTextField2.Width = 10;
Declarations::TArduinoLiquidCrystalElementTextField2.Row = 1;
Declarations::TArduinoLiquidCrystalElementAnalogField2.Precision = 1;
Declarations::TArduinoLiquidCrystalElementAnalogField2.Width = 4;
Declarations::TArduinoLiquidCrystalElementAnalogField2.Column = 10;
Declarations::TArduinoLiquidCrystalElementAnalogField2.Row = 1;
Declarations::TArduinoLiquidCrystalElementCustomCharacterField1.Index = 0;
Declarations::TArduinoLiquidCrystalElementCustomCharacterField1.Column = 15;
Declarations::TArduinoLiquidCrystalElementTextField3.InitialValue = "%";
Declarations::TArduinoLiquidCrystalElementTextField3.Column = 15;
Declarations::TArduinoLiquidCrystalElementTextField3.Row = 1;
Declarations::HumidityThermometer1.TemperatureOutputPin().SetCallback( PinCalls::PinCallerReceive1 );
Declarations::HumidityThermometer1.HumidityOutputPin().SetCallback( PinCalls::PinCallerReceive2 );
Declarations::ClockGenerator1.OutputPin().SetCallback( PinCalls::PinCallerReceive3 );
Declarations::LiquidCrystalDisplay1.SystemInit();
Declarations::TArduinoLiquidCrystalElementDefineCustomCharacter1.SystemInit();
Declarations::HumidityThermometer1.SystemInit();
Declarations::ClockGenerator1.SystemInit();
Declarations::TArduinoLiquidCrystalElementTextField1.SystemStart();
Declarations::TArduinoLiquidCrystalElementAnalogField1.SystemStart();
Declarations::TArduinoLiquidCrystalElementTextField2.SystemStart();
Declarations::TArduinoLiquidCrystalElementAnalogField2.SystemStart();
Declarations::TArduinoLiquidCrystalElementCustomCharacterField1.SystemStart();
Declarations::TArduinoLiquidCrystalElementTextField3.SystemStart();
Declarations::HumidityThermometer1.SystemStart();
Declarations::ClockGenerator1.SystemStart();
OpenWire::SystemStarted();
// The loop function is called in an endless loop
unsigned long A_Current_Microseconds = micros();
Declarations::HumidityThermometer1.SystemLoopBegin( A_Current_Microseconds );
Declarations::ClockGenerator1.SystemLoopBegin( A_Current_Microseconds );
Declarations::TArduinoLiquidCrystalElementCustomCharacterField1.SystemLoopEnd( A_Current_Microseconds );
