How to change Servo library default timer?
im building a quadcopter and
I use SERVO library and APM RC_CHANNEL library radio.
Both libraries use timers and I'm guessing that the program is not working properly because they use the same timer.
How do I change the default timer in the SERVO library?
this the code in the library:
#include <avr/interrupt.h>
#include <Arduino.h>
#include "Servo.h"
#define usToTicks(_us)    (( clockCyclesPerMicrosecond()* _us) / 8)     // converts microseconds to tick (assumes prescale of 8)  // 12 Aug 2009
#define ticksToUs(_ticks) (( (unsigned)_ticks * 8)/ clockCyclesPerMicrosecond() ) // converts from ticks back to microseconds
#define TRIM_DURATION       2                               // compensation ticks to trim adjust for digitalWrite delays // 12 August 2009
//#define NBR_TIMERS        (MAX_SERVOS / SERVOS_PER_TIMER)
static servo_t servos[MAX_SERVOS];
static volatile int8_t Channel[_Nbr_16timers ];
uint8_t ServoCount = 0;
// convenience macros
#define SERVO_INDEX_TO_TIMER(_servo_nbr) ((timer16_Sequence_t)(_servo_nbr / SERVOS_PER_TIMER))
#define SERVO_INDEX_TO_CHANNEL(_servo_nbr) (_servo_nbr % SERVOS_PER_TIMER)
#define SERVO_INDEX(_timer,_channel)  ((_timer*SERVOS_PER_TIMER) + _channel)
#define SERVO(_timer,_channel)  (servos[SERVO_INDEX(_timer,_channel)])
#define SERVO_MIN() (MIN_PULSE_WIDTH - this->min * 4)
#define SERVO_MAX() (MAX_PULSE_WIDTH - this->max * 4)
/************ static functions common to all instances ***********************/
static inline void handle_interrupts(timer16_Sequence_t timer, volatile uint16_t *TCNTn, volatile uint16_t* OCRnA)
  if( Channel[timer] < 0 )
    *TCNTn = 0;
  else{
    if( SERVO_INDEX(timer,Channel[timer]) < ServoCount && SERVO(timer,Channel[timer]).Pin.isActive == true )
      digitalWrite( SERVO(timer,Channel[timer]).Pin.nbr,LOW);
  Channel[timer]++;    // increment to the next channel
  if( SERVO_INDEX(timer,Channel[timer]) < ServoCount && Channel[timer] < SERVOS_PER_TIMER) {
    *OCRnA = *TCNTn + SERVO(timer,Channel[timer]).ticks;
    if(SERVO(timer,Channel[timer]).Pin.isActive == true)     // check if activated
      digitalWrite( SERVO(timer,Channel[timer]).Pin.nbr,HIGH);
  else {
    if( ((unsigned)*TCNTn) + 4 < usToTicks(REFRESH_INTERVAL) )
      *OCRnA = (unsigned int)usToTicks(REFRESH_INTERVAL);
      *OCRnA = *TCNTn + 4;
    Channel[timer] = -1;
#ifndef WIRING // Wiring pre-defines signal handlers so don't define any if compiling for the Wiring platform
// Interrupt handlers for Arduino
#if defined(_useTimer1)
ISR(TIMER1_COMPA_vect)
  handle_interrupts(_timer1, &TCNT1, &OCR1A);
#endif
#if defined(_useTimer3)
ISR(TIMER3_COMPA_vect)
  handle_interrupts(_timer3, &TCNT3, &OCR3A);
#endif
#if defined(_useTimer4)
ISR(TIMER4_COMPA_vect)
  handle_interrupts(_timer4, &TCNT4, &OCR4A);
#endif
#if defined(_useTimer5)
ISR(TIMER5_COMPA_vect)
  handle_interrupts(_timer5, &TCNT5, &OCR5A);
#endif
#elif defined WIRING
// Interrupt handlers for Wiring
void Timer1Service()
#endif
void Timer3Service()
#endif
#endif
static void initISR(timer16_Sequence_t timer)
#if defined (_useTimer1)
  if(timer == _timer1) {
    TCCR1A = 0;             // normal counting mode
    TCCR1B = _BV(CS11);     // set prescaler of 8
    TCNT1 = 0;              // clear the timer count
#if defined(__AVR_ATmega8__)|| defined(__AVR_ATmega128__)
    TIFR |= _BV(OCF1A);      // clear any pending interrupts;
    TIMSK |=  _BV(OCIE1A) ;  // enable the output compare interrupt
#else
    // here if not ATmega8 or ATmega128
    TIFR1 |= _BV(OCF1A);     // clear any pending interrupts;
    TIMSK1 |=  _BV(OCIE1A) ; // enable the output compare interrupt
#endif
#if defined(WIRING)
    timerAttach(TIMER1OUTCOMPAREA_INT, Timer1Service);
#endif
#endif
#if defined (_useTimer3)
  if(timer == _timer3) {
    TCCR3A = 0;             // normal counting mode
    TCCR3B = _BV(CS31);     // set prescaler of 8
    TCNT3 = 0;              // clear the timer count
#if defined(__AVR_ATmega128__)
    TIFR |= _BV(OCF3A);     // clear any pending interrupts;
 ETIMSK |= _BV(OCIE3A);  // enable the output compare interrupt
#else
    TIFR3 = _BV(OCF3A);     // clear any pending interrupts;
    TIMSK3 =  _BV(OCIE3A) ; // enable the output compare interrupt
#endif
#if defined(WIRING)
    timerAttach(TIMER3OUTCOMPAREA_INT, Timer3Service);  // for Wiring platform only
#endif
#endif
#if defined (_useTimer4)
  if(timer == _timer4) {
    TCCR4A = 0;             // normal counting mode
    TCCR4B = _BV(CS41);     // set prescaler of 8
    TCNT4 = 0;              // clear the timer count
    TIFR4 = _BV(OCF4A);     // clear any pending interrupts;
    TIMSK4 =  _BV(OCIE4A) ; // enable the output compare interrupt
#endif
#if defined (_useTimer5)
  if(timer == _timer5) {
    TCCR5A = 0;             // normal counting mode
    TCCR5B = _BV(CS51);     // set prescaler of 8
    TCNT5 = 0;              // clear the timer count
    TIFR5 = _BV(OCF5A);     // clear any pending interrupts;
    TIMSK5 =  _BV(OCIE5A) ; // enable the output compare interrupt
#endif
static void finISR(timer16_Sequence_t timer)
#if defined WIRING
    #if defined(__AVR_ATmega1281__)||defined(__AVR_ATmega2561__)
    TIMSK1 &=  ~_BV(OCIE1A) ;
    #else
    TIMSK &=  ~_BV(OCIE1A) ;
    #endif
    timerDetach(TIMER1OUTCOMPAREA_INT);
  else if(timer == _timer3) {
    TIMSK3 &= ~_BV(OCIE3A);
    #else
    ETIMSK &= ~_BV(OCIE3A);
    #endif
    timerDetach(TIMER3OUTCOMPAREA_INT);
#else
#endif
static boolean isTimerActive(timer16_Sequence_t timer)
  // returns true if any servo is active on this timer
  for(uint8_t channel=0; channel < SERVOS_PER_TIMER; channel++) {
    if(SERVO(timer,channel).Pin.isActive == true)
      return true;
  return false;
/****************** end of static functions ******************************/
Servo::Servo()
  if( ServoCount < MAX_SERVOS) {
    this->servoIndex = ServoCount++;                    // assign a servo index to this instance
 servos[this->servoIndex].ticks = usToTicks(DEFAULT_PULSE_WIDTH);   // store default values  - 12 Aug 2009
    this->servoIndex = INVALID_SERVO ;  // too many servos
uint8_t Servo::attach(int pin)
  return this->attach(pin, MIN_PULSE_WIDTH, MAX_PULSE_WIDTH);
uint8_t Servo::attach(int pin, int min, int max)
  if(this->servoIndex < MAX_SERVOS ) {
    pinMode( pin, OUTPUT) ;
    servos[this->servoIndex].Pin.nbr = pin;
    // todo min/max check: abs(min - MIN_PULSE_WIDTH) /4 < 128
    this->min  = (MIN_PULSE_WIDTH - min)/4;
    this->max  = (MAX_PULSE_WIDTH - max)/4;
    // initialize the timer if it has not already been initialized
    timer16_Sequence_t timer = SERVO_INDEX_TO_TIMER(servoIndex);
    if(isTimerActive(timer) == false)
      initISR(timer);
    servos[this->servoIndex].Pin.isActive = true;
  return this->servoIndex ;
void Servo::detach()
  servos[this->servoIndex].Pin.isActive = false;
  if(isTimerActive(timer) == false) {
    finISR(timer);
void Servo::write(int value)
  if(value < MIN_PULSE_WIDTH)
    if(value < 0) value = 0;
    if(value > 180) value = 180;
    value = map(value, 0, 180, SERVO_MIN(),  SERVO_MAX());
  this->writeMicroseconds(value);
void Servo::writeMicroseconds(int value)
  byte channel = this->servoIndex;
  if( (channel < MAX_SERVOS) )
    if( value < SERVO_MIN() )
      value = SERVO_MIN();
    else if( value > SERVO_MAX() )
      value = SERVO_MAX();
   value = value - TRIM_DURATION;
    value = usToTicks(value); 2009
    uint8_t oldSREG = SREG;
    cli();
    servos[channel].ticks = value;
    SREG = oldSREG;
int Servo::read()
  return  map( this->readMicroseconds()+1, SERVO_MIN(), SERVO_MAX(), 0, 180);
int Servo::readMicroseconds()
  unsigned int pulsewidth;
  if( this->servoIndex != INVALID_SERVO )
    pulsewidth = ticksToUs(servos[this->servoIndex].ticks)  + TRIM_DURATION ;   // 12 aug 2009
    pulsewidth  = 0;
  return pulsewidth;
bool Servo::attached()
  return servos[this->servoIndex].Pin.isActive ;
It may be easier to use the ServoTimer2 library
UKHeliBob:
I never heard of this library, but only by the name I can understand that it really would be a better idea.
I'll look for it.
ServoTimer2
...R
