Alright so, I'm trying to write this program, and I have this function that prints a string to a modem and I want to transmit latitude and longitude to it. The problem is that those are defined as different variables in the code and I need to make them as one message. I don't really know how to do this because
char message = longitude + ", " latitude
Doesn't work
Also, I tried
std::string
And included
#include <string>
But that came up with the error "'string' is not a member of 'std'"
This is my whole code:
//------------{Libraries}----------//
#include <Wire.h> //Needed for I2C to GPS
#include <IridiumSBD.h>
#include <string>
#define IridiumSerial Serial3
#define DIAGNOSTICS false // Change this to see diagnostics
#include "SparkFun_Ublox_Arduino_Library.h" //http://librarymanager/All#SparkFun_Ublox_GPS
SFE_UBLOX_GPS myGPS;
IridiumSBD modem(IridiumSerial);
long lastTime = 0; //Simple local timer. Limits amount if I2C traffic to Ublox module.
int signalQuality = -1;
int err;
Wire.begin();
while (!Serial);
IridiumSerial.begin(19200);
Serial.println("Starting modem...");
err = modem.begin();
if (err != ISBD_SUCCESS) {
Serial.print("Begin failed: error ");
Serial.println(err);
if (err == ISBD_NO_MODEM_DETECTED) {
Serial.println("No modem detected: check wiring.");
} return;
if (myGPS.begin() == false) {
Serial.println(F("Ublox GPS not detected, Is it plugged in?"));
while (1);
myGPS.setI2COutput(COM_TYPE_UBX);
myGPS.saveConfiguration();
char version[12];
err = modem.getFirmwareVersion(version, sizeof(version));
Serial.print("FirmwareVersion failed: error ");
return;
Serial.print("Firmware Version is ");
Serial.print(version);
Serial.println(".");
err = modem.getSignalQuality(signalQuality);
Serial.print("SignalQuality failed: error ");
return;
Serial.print("On a scale of 0 to 5, signal quality is currently ");
Serial.print(signalQuality);
long latitude = myGPS.getLatitude();
long longitude = myGPS.getLongitude();
if(latitude and longitude == 0) {
Serial.println("Error: Could not get GPS coordinates");
while (1);
char message = latitude + ", " + longitude;
Serial.print("Trying to send the message. This might take several minutes.\r\n");
err = modem.sendSBDText(message);
Serial.print("sendSBDText failed: error ");
if (err == ISBD_SENDRECEIVE_TIMEOUT) {
Serial.println("Try again with a better view of the sky.");
Serial.println("Hey, it worked!");
#if DIAGNOSTICS
void ISBDConsoleCallback(IridiumSBD *device, char c) {
Serial.write(c);
void ISBDDiagsCallback(IridiumSBD *device, char c) {
Serial.write(c);
#endif
you need to use the sprintf() function [or snprintf()]
int err;
Wire.begin();
while (!Serial);
while (1);
while (1);
char version[12];
while(1);
while(1);
if (latitude == 0 && longitude == 0) {
while (1);
char message[50];
sprintf(message, "%ld, %ld",latitude,longitude);
#if DIAGNOSTICS
Serial.write(c);
Serial.write(c);
#endif
sprintf is a bit of a fly-swatting bazooka - if you find yourself short on memory, itoa, ltoa and dtostrf (who makes up these names?) are the ones to look at, along with strncpy etc.
