How to compile/link .c files from a subdir?
Hi. I’m trying to incorporate libbson into an Arduino project. I’d like to put all the libbson stuff into a bson/ directory alongside the sketch file, then compile & link everything in that directory with the sketch file.
I can get the sketch file itself to compile, but it looks like Arduino isn’t finding the bson/*.c files. Is there some way I can tell it to check that subdirectory?
Right now I’ve hacked it together with a bunch of symlinks, but I’d really prefer a better solution.
Along the same line: is there a way I can define a compiler directive, à la -DFOO=BAR or such such?
Thank you!
Please remember that C and C++ use different conventions for naming functions. To link from a C++ source file to a C library you have to tell the C++ compiler that the names use the C convention:
#extern “C” {
#include “somelib.h”
That’s from memory so I may be off a bit in the syntax.
You may also have to put the folder in a “src” folder in your sketch folder.
@johnwasser I’m already doing extern "C".
Are you saying I need my bson stuff in $SKETCH_DIR/src/bson/? So #include <bson/bson.h> would bring in $SKETCH_DIR/src/bson/bson.h?
worth a try.
Also try
$SKETCH_DIR/bson/src/bson.h
That's the organization for the library folders in the library hierarchy, so it may work the same.
Just a guess.
Alas, neither of these work. :frowning:
Is there maybe some interface for per-sketch customization of the compile & link options? (In my case that’s xtensa-esp32-elf-g++.)
(Update: apparently that can’t be done …)
