how to connect a USB host shield with Xbox 360 controller receiver ???
hello everyone, I'm trying to connect my Xbox 360 controller to my USB shield via receiver but it doesn't get recognized or connected for some reason, I'm using the XBOXRECV.h from the USB HOST SHIELD LIBRARY 2.0 , when i run the "board_qc" test it gives me this::
Circuits At Home 2011
USB Host Shield Quality Control Routine
Reading REVISION register... Die revision 03
SPI long test. Transfers 1MB of data. Each dot is 64K................ SPI long test passed
GPIO test. Connect GPIN0 to GPOUT7, GPIN1 to GPOUT6, and so on
Test failed. Value written: 00 Value read: A0
Press any key to continue...
it does nothing when i press keys even though I'm plugging my receiver.
in the sketch, when calling the method "Xbox.XboxReceiverConnected" of the library's example "xbox360" in the first IF statement, it returns false.. here is the example code
 Example sketch for the Xbox Wireless Reciver library - developed by Kristian Lauszus
 It supports up to four controllers wirelessly
 For more information see the blog post: http://blog.tkjelectronics.dk/2012/12/xbox-360-receiver-added-to-the-usb-host-library/ or
 send me an e-mail:  kristianl@tkjelectronics.com
#include <XBOXRECV.h>
// Satisfy the IDE, which needs to see the include statment in the ino too.
#ifdef dobogusinclude
#include <spi4teensy3.h>
#endif
#include <SPI.h>
USB Usb;
XBOXRECV Xbox(&Usb);
#if !defined(__MIPSEL__)
  while (!Serial); // Wait for serial port to connect - used on Leonardo, Teensy and other boards with built-in USB CDC serial connection
#endif
  if (Usb.Init() == -1) {
    Serial.print(F("\r\nOSC did not start"));
    while (1); //halt
  Serial.print(F("\r\nXbox Wireless Receiver Library Started"));
  Usb.Task();
  Serial.println(Xbox.XboxReceiverConnected);
  if (Xbox.XboxReceiverConnected) {
    for (uint8_t i = 0; i < 4; i++) {
      if (Xbox.Xbox360Connected[i]) {
        if (Xbox.getButtonPress(L2, i) || Xbox.getButtonPress(R2, i)) {
          Serial.print("L2: ");
          Serial.print(Xbox.getButtonPress(L2, i));
          Serial.print("\tR2: ");
          Serial.println(Xbox.getButtonPress(R2, i));
          Xbox.setRumbleOn(Xbox.getButtonPress(L2, i), Xbox.getButtonPress(R2, i), i);
        if (Xbox.getAnalogHat(LeftHatX, i) > 7500 || Xbox.getAnalogHat(LeftHatX, i) < -7500 || Xbox.getAnalogHat(LeftHatY, i) > 7500 || Xbox.getAnalogHat(LeftHatY, i) < -7500 || Xbox.getAnalogHat(RightHatX, i) > 7500 || Xbox.getAnalogHat(RightHatX, i) < -7500 || Xbox.getAnalogHat(RightHatY, i) > 7500 || Xbox.getAnalogHat(RightHatY, i) < -7500) {
          if (Xbox.getAnalogHat(LeftHatX, i) > 7500 || Xbox.getAnalogHat(LeftHatX, i) < -7500) {
            Serial.print(F("LeftHatX: "));
            Serial.print(Xbox.getAnalogHat(LeftHatX, i));
            Serial.print("\t");
          if (Xbox.getAnalogHat(LeftHatY, i) > 7500 || Xbox.getAnalogHat(LeftHatY, i) < -7500) {
            Serial.print(F("LeftHatY: "));
            Serial.print(Xbox.getAnalogHat(LeftHatY, i));
            Serial.print("\t");
          if (Xbox.getAnalogHat(RightHatX, i) > 7500 || Xbox.getAnalogHat(RightHatX, i) < -7500) {
            Serial.print(F("RightHatX: "));
            Serial.print(Xbox.getAnalogHat(RightHatX, i));
            Serial.print("\t");
          if (Xbox.getAnalogHat(RightHatY, i) > 7500 || Xbox.getAnalogHat(RightHatY, i) < -7500) {
            Serial.print(F("RightHatY: "));
            Serial.print(Xbox.getAnalogHat(RightHatY, i));
        if (Xbox.getButtonClick(UP, i)) {
          Xbox.setLedOn(LED1, i);
          Serial.println(F("Up"));
        if (Xbox.getButtonClick(DOWN, i)) {
          Xbox.setLedOn(LED4, i);
          Serial.println(F("Down"));
        if (Xbox.getButtonClick(LEFT, i)) {
          Xbox.setLedOn(LED3, i);
          Serial.println(F("Left"));
        if (Xbox.getButtonClick(RIGHT, i)) {
          Xbox.setLedOn(LED2, i);
          Serial.println(F("Right"));
        if (Xbox.getButtonClick(START, i)) {
          Xbox.setLedMode(ALTERNATING, i);
          Serial.println(F("Start"));
        if (Xbox.getButtonClick(BACK, i)) {
          Xbox.setLedBlink(ALL, i);
          Serial.println(F("Back"));
        if (Xbox.getButtonClick(L3, i))
          Serial.println(F("L3"));
        if (Xbox.getButtonClick(R3, i))
          Serial.println(F("R3"));
        if (Xbox.getButtonClick(L1, i))
          Serial.println(F("L1"));
        if (Xbox.getButtonClick(R1, i))
          Serial.println(F("R1"));
        if (Xbox.getButtonClick(XBOX, i)) {
          Xbox.setLedMode(ROTATING, i);
          Serial.print(F("Xbox (Battery: "));
          Serial.print(Xbox.getBatteryLevel(i)); // The battery level in the range 0-3
          Serial.println(F(")"));
        if (Xbox.getButtonClick(SYNC, i)) {
          Serial.println(F("Sync"));
          Xbox.disconnect(i);
        if (Xbox.getButtonClick(A, i))
          Serial.println(F("A"));
        if (Xbox.getButtonClick(B, i))
          Serial.println(F("B"));
        if (Xbox.getButtonClick(X, i))
          Serial.println(F("X"));
        if (Xbox.getButtonClick(Y, i))
          Serial.println(F("Y"));
any ideas ??
