Wifi firmware 19.5.2 latest.
I just bought adafurit ATWINC1500 wifi modules and connect with my Arduino UNO board and try some examples. It is working good.
Now I want to connect this modules with my android tablet. so I need to create wifi hotspot in my android mobile to connect more than one wifi modules.
Now I have created wifi hotspot in my android tablet.
I am using virtual terminal to send and receive data from and to between module and phone.
I edited web client example to make this module as STA mode.I can connect with my tablet. but I cant send and receive data from and to between module and phone.
Example Web client
#include <SPI.h>
#include <WiFi101.h>
char ssid[] = "hotspot"; // your network SSID (name)
char pass[] = "suresh123456"; // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0; // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;
// if you don't want to use DNS (and reduce your sketch size)
// use the numeric IP instead of the name for the server:
//IPAddress server(74,125,232,128); // numeric IP for Google (no DNS)
//char server[] = "www.google.com"; // name address for Google (using DNS)
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
WiFiClient client;
WiFiServer server(80);
WiFi.setPins(8,7,4);
//Initialize serial and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
// don't continue:
while (true);
// attempt to connect to WiFi network:
while (status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
Serial.println("Connected to wifi");
printWiFiStatus();
/*Serial.println("\nStarting connection to server...");
// if you get a connection, report back via serial:
if (server.connect(80)) {
Serial.println("connected to server");
// Make a HTTP request:
//client.println("GET /search?q=arduino HTTP/1.1");
//client.println("Host: www.google.com");
//client.println("Connection: close");
//client.println();
// if there are incoming bytes available
// from the server, read them and print them:
while (client.available()) {
char c = client.read();
Serial.write(c);
// if the server's disconnected, stop the client:
if (!client.connected()) {
Serial.println("disconnecting from server.");
client.stop();
// do nothing forevermore:
while (true);
void printWiFiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
