Actually i have had some success so far but not quite what i needed. I used a documentation online they showed me a code i copied and pasted.
#if defined(ESP8266)
#include <ESP8266WiFi.h>
#define THINGSBOARD_ENABLE_PROGMEM 0
#elif defined(ESP32) || defined(RASPBERRYPI_PICO) || defined(RASPBERRYPI_PICO_W)
#include <WiFi.h>
#endif
#ifndef LED_BUILTIN
#define LED_BUILTIN 99
#endif
#include <Arduino_MQTT_Client.h>
#include <ThingsBoard.h>
constexpr char WIFI_SSID[] = "wifi";
constexpr char WIFI_PASSWORD[] = "password";
// See Getting Started with ThingsBoard | ThingsBoard Community Edition
// to understand how to obtain an access token
constexpr char TOKEN[] = "access_token_thingsboard";
// Thingsboard we want to establish a connection too
constexpr char THINGSBOARD_SERVER[] = "the server i am using";
// MQTT port used to communicate with the server, 1883 is the default unencrypted MQTT port.
constexpr uint16_t THINGSBOARD_PORT = 1883U;
// Maximum size packets will ever be sent or received by the underlying MQTT client,
// if the size is to small messages might not be sent or received messages will be discarded
constexpr uint32_t MAX_MESSAGE_SIZE = 1024U;
// Baud rate for the debugging serial connection.
// If the Serial output is mangled, ensure to change the monitor speed accordingly to this variable
constexpr uint32_t SERIAL_DEBUG_BAUD = 115200U;
// Initialize underlying client, used to establish a connection
WiFiClient wifiClient;
// Initalize the Mqtt client instance
Arduino_MQTT_Client mqttClient(wifiClient);
// Initialize ThingsBoard instance with the maximum needed buffer size
ThingsBoard tb(mqttClient, MAX_MESSAGE_SIZE);
// Attribute names for attribute request and attribute updates functionality
constexpr char BLINKING_INTERVAL_ATTR[] = "blinkingInterval";
constexpr char LED_MODE_ATTR[] = "ledMode";
constexpr char LED_STATE_ATTR[] = "ledState";
// handle led state and mode changes
volatile bool attributesChanged = false;
// LED modes: 0 - continious state, 1 - blinking
volatile int ledMode = 0;
// Current led state
volatile bool ledState = false;
// Settings for interval in blinking mode
constexpr uint16_t BLINKING_INTERVAL_MS_MIN = 10U;
constexpr uint16_t BLINKING_INTERVAL_MS_MAX = 60000U;
volatile uint16_t blinkingInterval = 1000U;
uint32_t previousStateChange;
// For telemetry
constexpr int16_t telemetrySendInterval = 2000U;
uint32_t previousDataSend;
// List of shared attributes for subscribing to their updates
constexpr std::array<const char *, 2U> SHARED_ATTRIBUTES_LIST = {
LED_STATE_ATTR,
// List of client attributes for requesting them (Using to initialize device states)
constexpr std::array<const char *, 1U> CLIENT_ATTRIBUTES_LIST = {
LED_MODE_ATTR
/// @brief Initalizes WiFi connection,
// will endlessly delay until a connection has been successfully established
void InitWiFi() {
Serial.println("Connecting to AP ...");
// Attempting to establish a connection to the given WiFi network
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
// Delay 500ms until a connection has been succesfully established
Serial.print(".");
Serial.println("Connected to AP");
/// @brief Reconnects the WiFi uses InitWiFi if the connection has been removed
/// @return Returns true as soon as a connection has been established again
const bool reconnect() {
// Check to ensure we aren't connected yet
const wl_status_t status = WiFi.status();
if (status == WL_CONNECTED) {
return true;
// If we aren't establish a new connection to the given WiFi network
InitWiFi();
return true;
/// @brief Processes function for RPC call "setLedMode"
/// RPC_Data is a JSON variant, that can be queried using operator[]
/// See JsonVariant::operator[] | ArduinoJson 5 for more details
/// @param data Data containing the rpc data that was called and its current value
/// @return Response that should be sent to the cloud. Useful for getMethods
RPC_Response processSetLedMode(const RPC_Data &data) {
Serial.println("Received the set led state RPC method");
// Process data
int new_mode = data;
Serial.print("Mode to change: ");
Serial.println(new_mode);
if (new_mode != 0 && new_mode != 1) {
return RPC_Response("error", "Unknown mode!");
ledMode = new_mode;
attributesChanged = true;
// Returning current mode
return RPC_Response("newMode", (int)ledMode);
// Optional, keep subscribed shared attributes empty instead,
// and the callback will be called for every shared attribute changed on the device,
// instead of only the one that were entered instead
const std::array<RPC_Callback, 1U> callbacks = {
RPC_Callback{ "setLedMode", processSetLedMode }
/// @brief Update callback that will be called as soon as one of the provided shared attributes changes value,
/// if none are provided we subscribe to any shared attribute change instead
/// @param data Data containing the shared attributes that were changed and their current value
void processSharedAttributes(const Shared_Attribute_Data &data) {
for (auto it = data.begin(); it != data.end(); ++it) {
if (strcmp(it->key().c_str(), BLINKING_INTERVAL_ATTR) == 0) {
const uint16_t new_interval = it->value().as<uint16_t>();
if (new_interval >= BLINKING_INTERVAL_MS_MIN && new_interval <= BLINKING_INTERVAL_MS_MAX) {
blinkingInterval = new_interval;
Serial.print("Blinking interval is set to: ");
Serial.println(new_interval);
} else if (strcmp(it->key().c_str(), LED_STATE_ATTR) == 0) {
ledState = it->value().as();
if (LED_BUILTIN != 99) {
digitalWrite(LED_BUILTIN, ledState);
Serial.print("LED state is set to: ");
Serial.println(ledState);
void processClientAttributes(const Shared_Attribute_Data &data) {
if (strcmp(it->key().c_str(), LED_MODE_ATTR) == 0) {
const uint16_t new_mode = it->value().as<uint16_t>();
ledMode = new_mode;
const Shared_Attribute_Callback attributes_callback(&processSharedAttributes, SHARED_ATTRIBUTES_LIST.cbegin(), SHARED_ATTRIBUTES_LIST.cend());
const Attribute_Request_Callback attribute_shared_request_callback(&processSharedAttributes, SHARED_ATTRIBUTES_LIST.cbegin(), SHARED_ATTRIBUTES_LIST.cend());
const Attribute_Request_Callback attribute_client_request_callback(&processClientAttributes, CLIENT_ATTRIBUTES_LIST.cbegin(), CLIENT_ATTRIBUTES_LIST.cend());
// Initalize serial connection for debugging
Serial.begin(SERIAL_DEBUG_BAUD);
pinMode(LED_BUILTIN, OUTPUT);
InitWiFi();
delay(10);
if (!reconnect()) {
return;
if (!tb.connected()) {
// Connect to the ThingsBoard
Serial.print("Connecting to: ");
Serial.print(THINGSBOARD_SERVER);
Serial.print(" with token ");
Serial.println(TOKEN);
if (!tb.connect(THINGSBOARD_SERVER, TOKEN, THINGSBOARD_PORT)) {
Serial.println("Failed to connect");
return;
// Sending a MAC address as an attribute
tb.sendAttributeData("macAddress", WiFi.macAddress().c_str());
Serial.println("Subscribing for RPC...");
// Perform a subscription. All consequent data processing will happen in
// processSetLedState() and processSetLedMode() functions,
// as denoted by callbacks array.
if (!tb.RPC_Subscribe(callbacks.cbegin(), callbacks.cend())) {
Serial.println("Failed to subscribe for RPC");
return;
if (!tb.Shared_Attributes_Subscribe(attributes_callback)) {
Serial.println("Failed to subscribe for shared attribute updates");
return;
Serial.println("Subscribe done");
// Request current states of shared attributes
if (!tb.Shared_Attributes_Request(attribute_shared_request_callback)) {
Serial.println("Failed to request for shared attributes");
return;
// Request current states of client attributes
if (!tb.Client_Attributes_Request(attribute_client_request_callback)) {
Serial.println("Failed to request for client attributes");
return;
if (attributesChanged) {
if (ledMode == 0) {
previousStateChange = millis();
tb.sendTelemetryData(LED_MODE_ATTR, ledMode);
tb.sendTelemetryData(LED_STATE_ATTR, ledState);
tb.sendAttributeData(LED_MODE_ATTR, ledMode);
tb.sendAttributeData(LED_STATE_ATTR, ledState);
if (ledMode == 1 && millis() - previousStateChange > blinkingInterval) {
ledState = !ledState;
if (LED_BUILTIN == 99) {
Serial.print("LED state changed to: ");
// Sending telemetry every telemetrySendInterval time
if (millis() - previousDataSend > telemetrySendInterval) {
previousDataSend = millis();
tb.sendTelemetryData("temperature", random(10, 20));
tb.sendAttributeData("rssi", WiFi.RSSI());
tb.sendAttributeData("channel", WiFi.channel());
tb.sendAttributeData("bssid", WiFi.BSSIDstr().c_str());
tb.sendAttributeData("localIp", WiFi.localIP().toString().c_str());
tb.sendAttributeData("ssid", WiFi.SSID().c_str());
Serial.println("it worked");
tb.loop();
So it can send data but I want to do the reverse and receieve the data instead. but I am not sure how to write a program/ add codes to work. is it possible for you to help me.
