Hello Arduino-Community,
Im pretty new here and me and a friend of mine have build a 8x8 Bi colored LED Matrix. Here is a photo of this Matrix:
Now I've got the problem that i can't control a single LED in a row(as you can see on my photo).
I'm using this code to control my Matrix:
//Pin connected to ST_CP of 74HC595
int latchPin = 8;
//Pin connected to SH_CP of 74HC595
int clockPin = 12;
////Pin connected to DS of 74HC595
int dataPin = 11;
//byte Matrix[8];
//set pins to output so you can control the shift register
pinMode(latchPin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
/* Matrix[1] = 129;
Matrix[2] = 66;
Matrix[3] = 36;
Matrix[4] = 24;
Matrix[5] = 24;
Matrix[6] = 36;
Matrix[7] = 66;
Matrix[8] = 129; */
// count from 0 to 255 and display the number
// on the LEDs
//for (int numberToDisplay = 1; numberToDisplay < 8; numberToDisplay++) {
// take the latchPin low so
// the LEDs don't change while you're sending in bits:
digitalWrite(latchPin, LOW);
// shift out the bits:
shiftOut(dataPin, clockPin, MSBFIRST, 0b00000001);
//take the latch pin high so the LEDs will light up:
digitalWrite(latchPin, HIGH);
// pause before next value:
delay(50);
Sorry that i commented so many things out, but so I can use them later again.
Im grateful about any help.
best regards,
idl0r
If you are not going to be serious don't bother asking.
That picture is rubbish. Can you see anything from it? I know I cant.
Please a schematic or forget it.
sorry I don't wanted to annoy you, but I still don't know what you mean with schematic :S.
Do you mean something like this? (example: http://www.amparchives.com/Amp%20Archives/Fender/Schematics/bassman-5f6-a-schematic.gif ), because we didn't make such a schematic for our project.
If you only can help us/me with such a schematic we gonna create one.
Sorry for the incident.
best regards,
idl0r
So how could you possibly build anything without one? Let alone know if you had designed it and built it correctly. I can't do that and I have been at electronics for 45 years.
Just think about what sort of answer you are expecting from this board.
You expect to be pointed at where you have gone wrong but without knowing what you have done how can anyone tell this?
Are you expecting a reply like "oh you have the shift register latch connected to the wrong pin"? When you don't say what pin it is connected to.
