How to control the Bluetooth module BLE 33 underwater
Correct, and using very slow CW (Morse code). And even then subject to errors, so multiple retransmissions to hope get the messeag.
If it is a salt water only floating antenna, or sonar, in fresh water you can use CB radio up to 20 m deep.
for short range use 5kHz
Indeed - the lower the better (3 to 30 Hz)
➜ which is pretty far away from the 2,4GHz of WiFi or BT...
some reading ➜ https://www.diva-portal.org/smash/get/diva2:1148743/FULLTEXT01.pdf
