hii thanku fr ur code..well i am trying to record through analog pin.and i could successfully record the noise. now i want to record a analog waveform out from dac 0808.so i had interfaced arduino uno with isd 1760 and dac 0808. in the code when record command is given the output from portD is given to dac input pins parallely. output of dac0808 is connected to analog pin of isd 1760. so wen isd 1760 goes in record mode it will have analog signal at its input.but in the serial monitor only starting,power up and cl is displayed. instead of cl it shud be displayed as clear interrupt end.and after giving record command its not recording!!.plz someone guide me on where i m going wrong.or if someone has any other idea. here is ma code:
[//define pins
#define DATAOUT 11 //mosi
#define DATAIN 12 //miso
#define SPICLOCK 13 //sck
#define SLAVESELECT 10 //ss
//opcodes
#define PU 0x01
#define STOP 0x02
#define RESET 0x03
#define CLR_INT 0x04
#define RD_STATUS 0x05
#define RD_PLAY_PTR 0x06
#define PD 0x07
#define RD_REC_PTR 0x08
#define DEVID 0x09
#define PLAY 0x40
#define REC 0x41
#define REC_LED 0x51//record with LED on
#define ERASE 0x42
#define G_ERASE 0x43
#define RD_APC 0x44
#define WR_APC1 0x45
#define WR_APC2 0x65
#define WR_NVCFG 0x46
#define LD_NVCFG 0x47
#define FWD 0x48
#define CHK_MEM 0x49
#define EXTCLK 0x4A
#define SET_PLAY 0x80
#define SET_REC 0x81
#define SET_REC_LED 0x91//set record with LED on
#define SET_ERASE 0x82
#define WAIT_TIME 10//waiting time (ms) after SS=LOW at least 500ns
#define WAIT_TIME2 100
int start_adress = 0x010;//test address to record
int end_adress = 0x024;//20unit
byte sine[] = {127, 134, 142, 150, 158, 166, 173, 181, 188, 195, 201, 207, 213, 219, 224, 229, 234, 238, 241, 245, 247, 250, 251, 252, 253, 254, 253, 252, 251, 250, 247, 245, 241, 238, 234, 229, 224, 219, 213, 207, 201, 195, 188, 181, 173, 166, 158, 150, 142, 134, 127, 119, 111, 103, 95, 87, 80, 72, 65, 58, 52, 46, 40, 34, 29, 24, 19, 15, 12, 8, 6, 3, 2, 1, 0, 0, 0, 1, 2, 3, 6, 8, 12, 15, 19, 24, 29, 34, 40, 46, 52, 58, 65, 72, 80, 87, 95, 103, 111, 119,};
byte index = 0;//index variable for extracting data from array "sine"
if (index==100)
//reset index if it reaches 100
index=0;
pinMode(DATAOUT, OUTPUT);
pinMode(DATAIN, INPUT);
pinMode(SPICLOCK, OUTPUT);
pinMode(SLAVESELECT, OUTPUT);
initialize();
for (byte i=0;i<8;i++)
pinMode(i, OUTPUT);//set digital pins 0-7 as outputs
cli();//stop interrupts
//set timer1 interrupt at ~44.1kHz
TCCR1A = 0;// set entire TCCR1A register to 0
TCCR1B = 0;// same for TCCR1B
TCNT1 = 0;//initialize counter value to 0
// set compare match register for 1hz increments
OCR1A = 361;// = (16*10^6) / (44100*1) - 1 (must be <65536)
// turn on CTC mode
TCCR1B |= (1 << WGM12);
// Set CS10 bit for 1 prescaler
TCCR1B |= (1 << CS10);
// enable timer compare interrupt
TIMSK1 |= (1 << OCIE1A);
void initialize()
byte clr;
digitalWrite(SLAVESELECT, HIGH); //disable device
digitalWrite(SPICLOCK, HIGH); //SCLK
digitalWrite(DATAOUT, LOW); //MOSI
SPCR = B01111111; //data lsb, clock high when idle, samples on falling
clr = SPSR;
clr = SPDR;
delay(10);
//start serial
Serial.println("Sketch is starting up");
pu();
clear_int();
char c;
if(Serial.available())
c = Serial.read();
switch(c)
case '0':
initialize();
case '2':
set_rec(start_adress, end_adress);
case '3':
set_play(start_adress, end_adress);
case 'k':
clear_int();
case 'z':
eraseAll();
case 'p':
stop();
case 's':
reset();
case 'a':
write_apc(true, false, 7);//mic in & no moniter on recording
case 'b':
write_apc(false, false, 7);//analog in & no moniter on recording
case 'c':
Serial.println(read_apc(), BIN);//read apc
case 'd':
Serial.println(read_status(), BIN);//read status
void pu() //power up
digitalWrite(SLAVESELECT, LOW);
delay(WAIT_TIME);
spi_transfer(PU); // power up
spi_transfer(0x00); // data byte
delay(WAIT_TIME2);
Serial.println("power up end");
void clear_int()// clear interupt
delay(WAIT_TIME);
spi_transfer(CLR_INT); // clear interupt and eom bit
delay(WAIT_TIME2);
Serial.println("clear int end");
void reset()// reset
delay(WAIT_TIME);
spi_transfer(RESET); // resett
delay(WAIT_TIME2);
Serial.println("reset end");
void stop()
delay(WAIT_TIME);
spi_transfer(STOP); // stop
delay(WAIT_TIME2);
Serial.println("stop end");
void set_play(int starta, int enda)
delay(WAIT_TIME);
spi_transfer(SET_PLAY); // set play
spi_transfer(0); // data byte
spi_transfer(starta & 255); // data byte start
spi_transfer(starta >> 8); // data byte last 3 bits
spi_transfer(enda & 255); // data byte stop
spi_transfer(enda >> 8); // data byte last 3 bits
spi_transfer(0); // data byte blank
delay(WAIT_TIME2);
Serial.println("set play end");
void set_rec(int starta, int enda)
delay(WAIT_TIME);
sei();//enable interrupts
spi_transfer(SET_REC); // clear interupt and eom bit
//spi_transfer(SET_REC_LED);//set record with LED on
delay(WAIT_TIME2);
Serial.println("set rec end");
PORTD = sine[index];//send a value stored in the array sine out to the DAC through digital pins 0-7
index++;//increment index by one
void eraseAll()
delay(WAIT_TIME);
spi_transfer(G_ERASE);// g_erase
delay(WAIT_TIME2);
Serial.println("erase all end");
char spi_transfer(volatile char data)
SPDR = data; // Start the transmission
while (!(SPSR & (1 << SPIF))) // Wait for the end of the transmission
return SPDR; // return the received byte
void write_apc(boolean flag, boolean flag2, int vol)
uint16_t d[12];
for(int i = 0; i < 12; i++)
d[i] = 0x00;
d[3] = 0x01;
d[6] = 0x00;
uint16_t apc = (d[0] | d[1] << 1 | d[2] << 2 | d[3] << 3 | d[4] << 4 | d[5] << 5 | d[6] << 6 | d[7] << 7 | d[8] << 8 | d[9] << 9 | d[10] << 10 | d[11] << 11);
delay(WAIT_TIME);
spi_transfer(WR_APC2); // write apc register 2
spi_transfer(apc & 0xFF); // data byte start
spi_transfer(apc >>8) ; // data byte last 3 bits
delay(WAIT_TIME2);
Serial.println("write apc end");
uint16_t read_apc()
uint16_t apc;
uint8_t data[4] = {0xFF,0xFF,0xFF,0xFF};
delay(WAIT_TIME);
data[0] = spi_transfer(RD_APC); // read apc register
data[1] = spi_transfer(0);
data[2] = spi_transfer(0);
data[3] = spi_transfer(0);
delay(WAIT_TIME2);
apc = word(data[3], data[2]);
Serial.println("read apc end");
return apc;
uint16_t read_status(void)
uint16_t sr1;
uint8_t data[3] = {0xFF,0xFF,0xFF};
delay(WAIT_TIME);
data[0] = spi_transfer(RD_STATUS); // read status register
delay(WAIT_TIME2);
sr1 = word(data[2], 0xFF);
return sr1;
/code]
[/quote]
