gfvalvo:
Store minutes as a uint32_t. Use 'put' and 'get' for storage and retrieval. See: https://www.arduino.cc/en/Reference/EEPROM
This is my engine hour meter code
#include <EEPROM.h>
#include <Wire.h>
#include <Adafruit_GFX.h>////////////////oled
#include <Adafruit_SSD1306.h>////////////oled
#include <OneWire.h>/////////////////////Temp sensor
#include <DallasTemperature.h>///////////Temp sensor
#define ONE_WIRE_BUS A0//////////////////Temp sensor
OneWire oneWire(ONE_WIRE_BUS);//////////Temp sensor
DallasTemperature sensors(&oneWire);////Temp sensor
#define ONE_WIRE_BUS A0////////////////Temp sensor
#define OLED_Address 0x3C///////////////oled
#define OLED1_Address 0x3D///////////////oled
Adafruit_SSD1306 oled(1);///////////////oled
//Adafruit_SSD1306 oled1(1);///////////////oled
//#include "Wire.h"
#define SCREEN_WIDTH 128 // ///////////////////////////////////OLED display width, in pixels
#define SCREEN_HEIGHT 64 ////////////////////////////////////////OLED
#define NUM_PAGE 8/////////////////oled
#include "RTClib.h"///////////////////// rtc
RTC_DS3231 rtc;////////////////////////// rtc
#define deviceAddress 0b1101000 //0x68
#define NUMFLAKES 10/////////////////oled
#define XPOS 0///////////////////////oled
#define YPOS 1///////////////////////oled
#define DELTAY 2///////////////////oled
#define LOGO16_GLCD_HEIGHT 16///////oled
#define LOGO16_GLCD_WIDTH 16//////oled
//Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);//OLED display height, in pixels
const uint8_t maint = 3;
const byte ledPin = 13;
const byte interruptPin = 2;
volatile byte state = LOW;
const uint8_t EngineCommand = 8;
float temp;
unsigned long time_now = 0;
unsigned long currentMillis;
unsigned long startDelay = 15000;
unsigned long waitTimeStart;
int EventState = 0;
int addr_secnd = 0;
int addr_Minute = 1;
int addr_hrs1 = 2;
int addr_hrs2 = 3;
int addr_hrs3 = 4;
int addr_hrs4 = 5;
int addr_hrs5 = 6;
int secnd = 0;
int Minute = 0;
int hrs1 = 0;
int hrs2 = 0;
int hrs3 = 0;
int hrs4 = 0;
int hrs5 = 0;
int value_secnd;
int value_Minute;
int value_hrs1;
int value_hrs2;
int value_hrs3;
int value_hrs4;
int value_hrs5;
int x6;
int x7;
int x8;
boolean waitingToStart = false ;
long lastTime = 1;
long seconds = EEPROM.read(addr_secnd);
long minutes = EEPROM.read(addr_Minute);
long hours = EEPROM.read(addr_hrs2);
oled.begin(SSD1306_SWITCHCAPVCC, 0x3C);
// oled1.begin(SSD1306_SWITCHCAPVCC, 0x3D);
rtc.begin();
sensors.begin();
Wire.begin();
DateTime now = rtc.now();
if (! rtc.begin())
Serial.println("Couldn't find RTC");
while (1);
if (rtc.lostPower())
Serial.println("RTC lost power, lets set the time!");
rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
pinMode(ledPin, OUTPUT);
pinMode(EngineCommand, INPUT);
pinMode(interruptPin, INPUT_PULLUP);
pinMode(maint, INPUT);
attachInterrupt(digitalPinToInterrupt(interruptPin), blink, FALLING);
setSQW(0x00);
oled.clearDisplay();
oled.setTextSize(2);
oled.setTextColor(WHITE);
oled.setCursor(0, 0);
oled.print("Plase subscribe");
oled.display();
/* oled1.setFont(&FreeMono9pt7b);
oled1.clearDisplay();
oled1.setTextSize(1);
oled1.setTextColor(WHITE);
oled1.setCursor(0, 20);
oled1.print("SREEKANTH");
oled1.display();*/
delay(5000);
String time()
String dataString = "";
dataString += String(now.year(), DEC);
dataString += String('.');
dataString += String(now.month(), DEC);
dataString += String(now.day(), DEC);
dataString += String(" ");
dataString += String(now.hour(), DEC);
dataString += String(':');
dataString += String(now.minute(), DEC);
dataString += String(now.second(), DEC);
return dataString;
display1();
Serial.print(hours);
Serial.print(":");
Serial.print(minutes);
Serial.print(":");
Serial.println(seconds);
sensors.requestTemperatures();
temp = sensors.getTempCByIndex(0);
float sensorValue = analogRead(A1);////////////used pot.meter as pressure sensor
if ( temp >= 24 && temp < 25 )/////////water temp sensor
oled.setTextSize(1);
oled.setTextColor(BLACK, WHITE);
oled.setCursor(64, 24);
oled.print(" TEMP-HIGH ");
oled.display();
else if ( temp >= 26 )//////////water temp sensor
oled.print(" ENG.OFF ");
oled.display();
if ( (sensorValue / 10) <= 2.00 && waitingToStart == false)////engine oil pressure
waitingToStart = true;
unsigned long waitTimeStart = millis();
if (waitingToStart == true && (millis() - waitTimeStart ) > startDelay)
waitingToStart = false;
oled.setCursor(68, 11);
oled.print(" PRES-LOW ");
oled.display();
digitalWrite(ledPin, HIGH);
if (digitalRead(EngineCommand) == HIGH)/////////engine off last reading stored in eeprom
if (EventState < 1)
EEPROM.update(addr_secnd, seconds);
EEPROM.update(addr_Minute, minutes);
EEPROM.update(addr_hrs2, hours);
Serial.print(EEPROM.read(addr_hrs2));
Serial.print(EEPROM.read(addr_Minute));
Serial.println(EEPROM.read(addr_secnd));
EventState++;
void display1()///////////data displayed on oled
oled.setTextColor(WHITE, BLACK);
oled.print(time());
oled.drawLine(0, 10, 127, 10, WHITE);
oled.drawLine(0, 11, 127, 11, WHITE);
oled.setCursor(0, 8);
oled.print((hours));//,":",(minutes));
oled.print(":");
oled.print((minutes));//,":",(minutes));
oled.print(":");
oled.print((seconds));//,":",(minutes));
oled.setCursor(0, 16);
oled.print((temp));
oled.setCursor(0, 24);
oled.print("E.O.P:");
oled.print((sensorValue) / 10);
oled.display();
//////////////////Engine working hours counting section///////////////////
void blink() {
if (digitalRead(EngineCommand) == LOW)
EventState = 0;
// if (millis() - lastTime > 0)
if (lastTime > 0)
seconds++;
//lastTime = millis();
if (seconds > 59)
minutes++;
seconds = 0;
if (minutes > 59)
hours++;
minutes = 0;
digitalWrite(ledPin, !digitalRead(ledPin));
void setSQW(uint8_t value) {
Wire.beginTransmission(deviceAddress); //device address and STSRT command are queued
Wire.write(0x0E); //Control Register Address is queued
Wire.write(0x00); //Data for Control Register is queued
Wire.endTransmission(); //queued information are transferred under ACK; STOP
