I've converted a mixed Arduino Mega 2560 C,C++ to C++. My last holdout is storing a struct with default values in Flash Memory.
The Struct:
typedef struct
uint8_t pulseMicroSeconds;
uint8_t stepperIdleLockTime;
uint8_t flags;
float stepsPerMm[NabAxes];
} settings_s;
Original flash code:
const __flash settings_s defaults = {\
.pulseMicroSeconds = DefStepPulseMicroSeconds,
.stepperIdleLockTime = DefStepperLockTime,
.flags = DefFlags,
.stepsPerMm[NabAxisX] = DefStepsPerMmX,
.stepsPerMm[NabAxisY] = DefStepsPerMmY,
.stepsPerMm[NabAxisZ] = DefStepsPerMmZ,
New PROGMEM code:
const settings_s defaults PROGMEM = {\
.flags = DefFlags,
I'm getting an error for each of the array items: error: expected primary-expression before '.' token
What are the necessary steps to convert __flash to PROGMEM?
gcjr
July 18, 2023, 8:43pm
2
this compiles for me
const uint8_t NabAxisX = 0;
const uint8_t NabAxisY = 1;
const uint8_t NabAxisZ = 2;
const uint8_t DefStepPulseMicroSeconds = 10;
const uint8_t DefStepperLockTime = 11;
const uint8_t DefFlags = 1;
const uint8_t DefStepsPerMmX = 1;
const uint8_t DefStepsPerMmY = 1;
const uint8_t DefStepsPerMmZ = 1;
struct Settings_s {
uint8_t flags;
uint8_t stepsPerMm [3];
const PROGMEM Settings_s defaults = {
.flags = DefFlags,
.stepsPerMm = { DefStepsPerMmX, DefStepsPerMmY, DefStepsPerMmZ },
OK! Thanks.
I converted my code and that error is solved, however, I'm getting three (3)
sorry, unimplemented: non-trivial designated initializers not supported
I thought it might be the .flags, I commented that line and then there are an additional (4)
The Defxxx items are #define
#define DefStepPulseMicroSeconds 10
#define DefStepperLockTime 255
#define DefFlags ((DefReportInches << StgBitReportInches) \
| (DefLaserMode << StgBitLaserMode) \
| (DefInvertStepEnable << StgBitInvertStepEnable) \
| (DefHardLimitEnable << StgBitHardLimitEnable) \
| (DefHomingEnable << StgBitHomingEnable) \
| (DefSoftLimitEnable << StgBitSoftLimitEnable) \
| (DefInvertLimitPins << StgBitInvertLimitPins) \
| (DefInvertProbePin << StgBitInvertProbePin))
#define DefStepsPerMmX 80.0
#define DefStepsPerMmY 80.0
#define DefStepsPerMmZ 80.0
I've not ever have seen this message before. Any suggestions?
I converted the #define to const 'type'. Still getting the same 'sorry' messages.
Research on this 'sorry' message found another difference between C & C++, namely that the order if initialization must be the same as the struct! Once I fixed the order of items, it compiles.
system
Closed
January 14, 2024, 11:04pm
6
