hi, i'm trying to send data through serial port, the data is float number
what i just planning for is to convert these data coming from the serial port to float in order to apply mathematical and logical manipulation inside the arduino
for example when i send 1 i just want to return 1 and 500 return 500 in one line and defined as float
i tried to use this code which i found here but it gives me an error
the code for the arduino is
int val;
while(Serial.available() == 0 );
val = Serial.read();
Serial.println(val);
char carray[val.length()+1];
val.toCharArray(carray,sizeof(val));
int n = atoi(val);
Serial.println(n);
Arduino: 1.6.1 (Windows 8.1), Board: "Arduino Uno"
serial.ino: In function 'void loop()':
serial.ino:14:19: error: request for member 'length' in 'val', which is of non-class type 'int'
serial.ino:15:7: error: request for member 'toCharArray' in 'val', which is of non-class type 'int'
serial.ino:15:19: error: 'carray' was not declared in this scope
serial.ino:16:19: error: invalid conversion from 'int' to 'const char*' [-fpermissive]
In file included from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:23:0,
from serial.ino:1:
c:\program files (x86)\arduino\hardware\tools\avr\avr\include\stdlib.h:274:12: error: initializing argument 1 of 'int atoi(const char*)' [-fpermissive]
extern int atoi(const char *__s) __ATTR_PURE__;
Error compiling.
enabled in File > Preferences.
any help will be appreciated
