how to create a variable in .h file
Hey everone,
I'm having trouble with what I believe should be fairly straightforward. I'm trying to create a variable in a header file and use it a corresponding .cpp file. the code is a follows:
project.ino:
#include <EEPROM.h>
#include "Config.h"
  init();
Config.h:
//variables
unsigned char stored;     //data stored in EEPROM
void initPen();
Config.cpp:
#include <Arduino.h>
#include <EEPROM.h>
//Initialize everything
void init()
  //Get stored data from EEPROM.
  stored = EEPROM.read(0); //read value at address 0
When compiling I get the following error:
Config.cpp:8: error: 'stored' was not declared in this scope
  • stored = EEPROM.read(0); //read value at address 0*
Shouldn't the variable 'stored' be available for the .cpp file with the same name as the .h file? or am I misguided here?
Yes, you are misguided.
You need to #include the file - there is nothing automatic about files with similar names being included.
You forgot to include that header file in you .cpp as well :wink:
But that will give you a new problem which is guarding. Add
#pragma once
at the top of the .h.
You also need to decide if that variable needs to be known in multiple files or only in config.cpp.
If only in config.cpp, you can simply declare the variable in the config.cpp instead of in the h file. Or use a different .h file (e.g. config_private.h) and include that file in config.cpp.
You shouldn't be "creating" the variable in the .h file at all. If you need to access that variable from multiple source files (the ONLY reason to have it in a .h file at all), then you must DECLARE it in the .h file. You then #include the .h file into every source file that needs to access the variable. Finally, you must DEFINE that variable as a global in exactly ONE of the source files. And, use Include Guards. Thus:
HeaderFile.h:
#ifndef _HEADER_FILE_H_
#define _HEADER_FILE_H_
extern uint8_t globalVariable;   // Declare the variable
#endif
MainFile.ino:
#include "HeaderFile.h"  // #include header in all files that need the variable
uint8_t globalVariable;  // Define the variable once and only once
  globalVariable = 7;  // Use the global variable
AnotherFile.cpp:
void aFunction() {  // some function
  globalVariable = 2;   // Use the global variable
AWOL:
  • Duh - thank you! I've been staring at this way too long.
septillion:
Add
#pragma once
Thanks! That's a neat way of handling the guarding instead of the ifndef stuff.
sterretje:
Thanks! Yes I do need the data to be globally available.
gfvalvo:
Thank you. That's what I get for having english as a second language. Thank you for the example!
Conclusion:
No - cpp files don't inherit anything from their .h file counterparts. Remember to include those.
Use '#pragma once' in top of header files to be sure they're not included multiple times -> compile errors
