How to create "Input Box"?
Hi! im currently trying to do a Wemos(my first time using Wemos and doing html-related)
i wonder what is the code for creating input box where i can input my name, numbers. for example, if input numbers, the servo motor will rotate on respective angle.
i have 0 knowledge about this and whenever i search i can barely find one(while the others require Ajax, SQL or sort)
i really do hope you can help~!
this code is an Example Code from WifiAccessPoint
Hi! i wonder what should be the code for inputting integers in a website.? so what im doing right now is to create a website 194.34.ip.ip/ , using Wemos. there will be an input box there and I will a input numbers from 1-100 then it will send to Wemos that will display the input as text in LCD. the problem is i never experienced HTML or web related designing. so coding one looks difficult.
my code:
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#ifndef APSSID
#define APSSID "Wemostest"
#define APPSK  "12345678"
#endif
/* Set these to your desired credentials. */
const char *ssid = APSSID;
const char *password = APPSK;
const int S
ESP8266WebServer server(80);
/* Just a little test message.  Go to http://192.168.4.1 in a web browser
   connected to this access point to see it.
void handleRoot() {
  server.send(200, "text/html", "<h1>You are connected</h1>");
  server.send(200, "input/html"
  Serial.print("Configuring access point...");
  /* You can remove the password parameter if you want the AP to be open. */
  WiFi.softAP(ssid, password);
  IPAddress myIP = WiFi.softAPIP();
  Serial.print("AP IP address: ");
  Serial.println(myIP);
  server.on("/", handleRoot);
  server.begin();
  Serial.println("HTTP server started");
  server.handleClient();
i havent included the LCD yet but that will be easy i think. only the website part is difficult
@Leocann Your topics on the same subject have been merged
HTML Input Types helps you. With examples.
