How to create pseudo code for this code
#include <Stepper.h>
#include <Servo.h>
#include <SoftwareSerial.h>
#include "VoiceRecognitionV3.h"
#include "DFRobotDFPlayerMini.h"
VR myVR(10, 11);
DFRobotDFPlayerMini myDFPlayer;
uint8_t buf[64]; // Increased buffer size
const int stepsPerRevolution = 32;
const int buzzerPin = 17;
const int irSensorPin = A0;
const int servoPin = 2;
const int led1Pin = 35; // Define LED1 pin
const int led2Pin = 37; // Define LED2 pin
const int led3Pin = 31; // Define LED3 pin
const int led4Pin = 33; // Define LED4 pin
const int led5Pin = 27; // Define LED5 pin
const int led6Pin = 29; // Define LED6 pin
const int led7Pin = 23; // Define LED7 pin
const int led8Pin = 25; // Define LED8 pin
Servo servo;
int servoAngle = 0;
int NeozepCount = 0; // Counter for "Neozep" commands
int BiogesicCount = 0; // Counter for "Biogesic" commands
int ParacetamolCount = 0; // Counter for "Paracetamol" commands
int DecolgenCount = 0; // Counter for "Decolgen" commands
Stepper myStepper1(stepsPerRevolution, 22, 26, 24, 28);
Stepper myStepper2(stepsPerRevolution, 30, 34, 32, 36);
Stepper myStepper3(stepsPerRevolution, 38, 42, 40, 44);
Stepper myStepper4(stepsPerRevolution, 46, 50, 48, 52);
#define NeozepRecord (8)
#define NeozepRecord (9)
#define BiogesicRecord (10)
#define NeozepRecord (11)
#define ParacetamolRecord (12)
#define ParacetamolRecord (13)
#define DecolgenRecord (14)
Serial.println("Elechouse Voice Recognition V3 Module\r\nControl LED sample");
Serial1.begin(9600); // Initialize serial communication with DFPlayer Mini
myDFPlayer.begin(Serial1); // Start communication with DFPlayer Mini
delay(1000); // Wait for DFPlayer Mini to initialize
myVR.begin(9600);
if (myVR.clear() == 0) {
Serial.println("Recognizer cleared.");
Serial.println("Voice Recognition Module not found.");
Serial.println("Please check the connection and restart Arduino.");
while (1);
if (myVR.load((uint8_t)NeozepRecord) >= 0) {
Serial.println("NeozepRecord loaded");
if (myVR.load((uint8_t)BiogesicRecord) >= 0) {
Serial.println("Biogesic loaded");
if (myVR.load((uint8_t)ParacetamolRecord) >= 0) {
Serial.println("Paracetamol loaded");
if (myVR.load((uint8_t)DecolgenRecord) >= 0) {
Serial.println("Decolgen loaded");
pinMode(irSensorPin, INPUT);
pinMode(buzzerPin, OUTPUT);
pinMode(servoPin, OUTPUT);
pinMode(led1Pin, OUTPUT);
pinMode(led2Pin, OUTPUT);
pinMode(led3Pin, OUTPUT);
pinMode(led4Pin, OUTPUT);
pinMode(led5Pin, OUTPUT);
pinMode(led6Pin, OUTPUT);
pinMode(led7Pin, OUTPUT);
pinMode(led8Pin, OUTPUT);
// Initialize LED pins as outputs
digitalWrite(led1Pin, LOW); // Turn off all LEDs initially
digitalWrite(led2Pin, LOW); // Turn off all LEDs initially
digitalWrite(led3Pin, LOW); // Turn off all LEDs initially
digitalWrite(led4Pin, LOW); // Turn off all LEDs initially
digitalWrite(led5Pin, LOW); // Turn off all LEDs initially
digitalWrite(led6Pin, LOW); // Turn off all LEDs initially
digitalWrite(led7Pin, LOW); // Turn off all LEDs initially
digitalWrite(led8Pin, LOW); // Turn off all LEDs initially
servo.attach(servoPin);
myStepper1.setSpeed(1000);
myStepper1.step(0);
myStepper2.setSpeed(1000);
myStepper2.step(0);
myStepper3.setSpeed(1000);
myStepper3.step(0);
myStepper4.setSpeed(1000);
myStepper4.step(0);
int ret = myVR.recognize(buf, 50); // Adjust recognition threshold
Serial.print("Voice Recognition Result: ");
Serial.println(ret);
if (ret > 0) {
int sensorStatus; // Declare sensorStatus outside the switch statement
switch (buf[1]) {
case NeozepRecord:
// Increment Neozep count
NeozepCount++;
Serial.print("Neozep count: ");
Serial.println(NeozepCount);
// Check if any medicine count is greater than or equal to 4
if (NeozepCount < 4 && BiogesicCount < 4 && ParacetamolCount < 4 && DecolgenCount < 4) {
// Play the first audio file
myDFPlayer.play(1);
delay(1000); // Wait for the first audio to finish playing
// Rotate Stepper 1 clockwise
myStepper1.step(1024);
// Rotate the stepper motor back
myStepper1.step(-1024);
// Trigger buzzer using IR sensor
sensorStatus = digitalRead(irSensorPin);
Serial.println("IR Sensor Status: " + String(sensorStatus)); // Debug print
if (sensorStatus == LOW) {
digitalWrite(buzzerPin, HIGH);
delay(1000); // Increase the delay for a longer buzzer sound
digitalWrite(buzzerPin, LOW);
// Rotate the servo motor
Serial.println("Rotating Servo to 90 degrees..."); // Debug print
servo.write(45); // Rotate to 90 degrees (adjust as needed)
delay(300); // Adjust the delay based on your requirements
Serial.println("Rotating Servo back to 0 degrees..."); // Debug print
servo.write(0); // Rotate back to 0 degrees
// Play the second audio file
myDFPlayer.play(2); // corrected file number
delay(3000); // Wait for the second audio to finish playing
// If "Neozep" is said two times, turn on the first LED
if (NeozepCount == 2) {
digitalWrite(led1Pin, HIGH); // Turn on the first LED
// Play the third audio file
myDFPlayer.play(3); // corrected file number
delay(3000); // Wait for the third audio to finish playing
// If "Neozep" is said three times, turn on the second LED
if (NeozepCount == 3) {
digitalWrite(led1Pin, LOW); // Turn off the first LED
digitalWrite(led2Pin, HIGH); // Turn on the second LED
// Play the fourth audio file
myDFPlayer.play(4); // corrected file number
delay(3000); // Wait for the fourth audio to finish playing
case BiogesicRecord:
// Increment Biogesic count
BiogesicCount++;
Serial.print("Biogesic count: ");
Serial.println(BiogesicCount);
// Play the fifth audio file
myDFPlayer.play(5);
delay(1000); // Wait for the fifth audio to finish playing
// Rotate Stepper 2 clockwise
myStepper2.step(1024);
myStepper2.step(-1024);
// Play the sixth audio file
myDFPlayer.play(6); // corrected file number
delay(3000); // Wait for the sixth audio to finish playing
// If "Biogesic" is said two times, turn on the third LED
if (BiogesicCount == 2) {
digitalWrite(led3Pin, HIGH); // Turn on the third LED
// Play the seventh audio file
myDFPlayer.play(7); // corrected file number
delay(3000); // Wait for the seventh audio to finish playing
// If "Biogesic" is said three times, turn on the fourth LED
if (BiogesicCount == 3) {
digitalWrite(led3Pin, LOW); // Turn off the third LED
digitalWrite(led4Pin, HIGH); // Turn on the fourth LED
// Play the eighth audio file
myDFPlayer.play(8); // corrected file number
delay(3000); // Wait for the eighth audio to finish playing
case ParacetamolRecord:
// Increment Paracetamol count
ParacetamolCount++;
Serial.print("Paracetamol count: ");
Serial.println(ParacetamolCount);
// Play the nineth audio file
myDFPlayer.play(9);
delay(1000); // Wait for the nineth audio to finish playing
// Rotate Stepper 3 clockwise
myStepper3.step(1024);
myStepper3.step(-1024);
// Play the tenth audio file
myDFPlayer.play(10); // corrected file number
delay(3000); // Wait for the tenth audio to finish playing
// If "Paracetamol" is said two times, turn on the fifth LED
if (ParacetamolCount == 2) {
digitalWrite(led5Pin, HIGH); // Turn on the fifth LED
// Play the eleventh audio file
myDFPlayer.play(11); // corrected file number
delay(3000); // Wait for the eleventh audio to finish playing
// If "Paracetamol" is said three times, turn on the sixth LED
if (ParacetamolCount == 3) {
digitalWrite(led5Pin, LOW); // Turn off the fifth LED
digitalWrite(led6Pin, HIGH); // Turn on the sixth LED
// Play the twelfth audio file
myDFPlayer.play(12); // corrected file number
delay(3000); // Wait for the twelfth audio to finish playing
case DecolgenRecord:
// Increment decolgen count
DecolgenCount++;
Serial.print("Decolgen count: ");
Serial.println(DecolgenCount);
// Play the thirteenth audio file
myDFPlayer.play(13);
delay(1000); // Wait for the thirteenth audio to finish playing
// Rotate Stepper 4 clockwise
myStepper4.step(1024);
myStepper4.step(-1024);
// Play the fourteenth audio file
myDFPlayer.play(14); // corrected file number
delay(3000); // Wait for the fourteenth audio to finish playing
// If "delcolgen" is said two times, turn on the seventh LED
if (DecolgenCount == 2) {
digitalWrite(led7Pin, HIGH); // Turn on the seventh LED
// Play the fifteenth audio file
myDFPlayer.play(15); // corrected file number
delay(3000); // Wait for the fifteenth audio to finish playing
// If "decolgen" is said three times, turn on the eight LED
if (DecolgenCount == 3) {
digitalWrite(led7Pin, LOW); // Turn off the seventh LED
digitalWrite(led8Pin, HIGH); // Turn on the eighth LED
// Play the sixteenth audio file
myDFPlayer.play(16); // corrected file number
