how to cut off 3 bits from a 32bit integer
Hi!
I am reading a 32bit integer, but I only want 29bits out of it. the three first, most significant, are flags I dont want to use.
I tried & and | but I end up with weird results - maybe someone could give me an example how to cut of some bits?
Post code, post results.
https://www.arduino.cc/en/pmwiki.php?n=Tutorial/BitMask
    CAN_config = canMsg.can_id;
    Serial.print("right from can: ");
    Serial.print(CAN_config);
    CAN_config << 3;
    Serial.print("  shifted 3 left: ");
    CAN_config >> 3;
    Serial.print("shifted three left: ");
    Serial.println(CAN_config);
    Serial.print("Message read: ");
    Serial.print(" = ");
    Serial.println(CAN_receive);
result:
CAN_config
right from can: 2147483665 shifted 3 left: 2147483665 shifted three left: 2147483665
Message read: 2147483665 = 17
CAN_config
  uint32_t y = 0xE1234567;
  Serial.println(y, HEX);
  y = y & 0x1fffffff;
As said, can_id holds more bits than needed for adress decode (from the library):
struct can_frame {
    uint32_t can_id;  /* 32 bit CAN_ID + EFF/RTR/ERR flags */
    uint8_t  can_dlc;
    uint8_t  data[8];
CAN_config << 3;
Oops
CAN_config <<= 3; The rest of the solution is left as an exercise for the reader.
   CAN_config << 3;
This line shifts but doesn't assign it to anything.
Use:
   uint32_t masked_config = CAN_config & 0x1fffffff;
Now masked_config contains CAN_config without the flags.
ToddL1962:
 y = y & 0x1fffffff;
That one does not work, when It gives me FFFFFFF
FFFFFFF, when I enter with:
  uint32_t y = 0xfffffff;
    y = y & 0x1fffffff;
TheMemberFormerlyKnownAsAWOL:
CAN_config << 3;
Oops
CAN_config <<= 3;
Ohh noooooo. yes, that one solved it .... so stupid I am :slight_smile:
Count the 'f's
when you mask
0xfffffff; // 7 f!
with
0x1fffffff;
it's absolutely correct, that you end up with nothing more than
0xfffffff;
If I go back to your entry post, you wanted to cut off the MOST significant 3 bits. Than the left shift will give you a wrong result, because it will shift out 3 bits and add zeros on the LSB
  uint32_t in = 0xffffffff; //all 32 (!!!) bits set
  Serial.println(in, HEX);
  Serial.println(in, BIN);
  uint32_t outA = in & 0x1fffffff;
  Serial.println(outA, HEX);
  Serial.println(outA, BIN);
  in <<= 3;
FFFFFFFF
11111111111111111111111111111111
1FFFFFFF
FFFFFFF8
11111111111111111111111111111000
imho masking is the correct way, if you want what you have asked for in your entry post.
AWOL was faster, but I'll keep my post...
It's amazing how a simple masking problem generated so much discussion.
Well, no- the masking is wrong!
And the number of f is correct.
When I move 32 bits 3 positions to the left AND after that I move them 3 position s to the right I will erase the 3 most significant bits - meaning I will make them zero.
By this I ensure that the number left is encoded as a 29bit value- not as a 32bit value.
All the obscure bit mask magic everyone tries to apply will alter the bits in a unpredictable way- the first 3 bits can be zeros- they can be ones- I dont know- I just dont wont them.
My example with the F shows that when all bits are set to 1 (32 x 1) the result is not 29 x1 (and that it is when you just cut of the first 3msb) - so bit masking does not work to cut of 3 bits.
Please show us the code that you say doesn't work.
Note that if you use signed types, the result may not be what you hope for.
There is nothing obscure about bit masking. "Everyone" is suggesting it because it's extremely common and well understood. Perhaps you should take a breather and try to understand it. Then you would realize, it can't possibly do what you say.
BetaCarotin:
I have been doing bit masking for 35 years. I assure you it works. Here is the code you claim doesn't work:
    y = y & 0x1fffffff;
You have 7 f's. If you mask with 0x1fffffff you get the same thing...0xfffffff.
And the desired result is 1fffffff !
So it does not work.
Why is that so hard to understand?
CAN identifiers are 29bit long, out of the CAN frame drops a 32bit value, containing flags at the beginning. These flags need to be cut off before processing the adress. Otherwise I will decode a flag as a part of an adress.
So how would you do bit masking= logical operations , that will set bits to zero- no matter what the other variable is- without altering all the other bits (29) you dont want to change? You dont! You just shift 3 left and three right, done.
So please try understand what I asked for.
BetaCarotin:
It's YOU who FAILS TO UNDERSTAND!!!!
The masking suggested WORKS!!!
Here's another example code to demostrate it:
const uint32_t BIT_MASK_29Bits = 0x1fffffff;
  uint32_t val1 = 0x1abcdef2;
  uint32_t val2 = 0xff456789;
  Serial.print("val1 = 0x");
  Serial.print(val1, HEX);
  Serial.print(", applying mask 0x");
  Serial.println(val1 & BIT_MASK_29Bits, HEX);
  Serial.print("val2 = 0x");
  Serial.print(val2, HEX);
  Serial.print(val2 & BIT_MASK_29Bits, HEX);
and the result:
val1 = 0x1ABCDEF2, applying mask 0x1ABCDEF2
val2 = 0xFF456789, applying mask 0x1F456789
As you can see, in val2, the 3 most significant bits WERE MASKED
ToddL1962:
Naw, its just Covid.
-jimlee
we don't know why you struggle at that topic.
But you could put the posted codes in your Arduino and try to follow what we are saying.
so, mask the 32bit variable with
0b00011111111111111111111111111111
and you will see, that the first 3 bits are gone.
