I have some pressure I2C sensors as the attached, and I'd like to measure the pressures with several sensors at the same time.
I've modified the example Wire code as the following and can get the correct reading.
#include <Wire.h>
Wire.begin(); // join i2c bus (address optional for master)
Serial.begin(9600); // start serial for output
}void loop() {
Wire.requestFrom(0x28, 2); // request 2 bytes from address 0x28while (Wire.available()) { // slave may send less than requested
byte a = Wire.read(); // receive a byte as character
//Serial.print("a : ");Serial.println(int(a));
byte b = Wire.read();
//Serial.print("b : ");Serial.println(int(b));
float p = (((int(a)256+int(b))/16383.-0.1)(5-(-5))/0.8)+(-5);
Serial.println(p);
}delay(1000);
I wonder if I can use one Arduino to get those data from 3~4 pressure sensors with the same address.
Could you give any suggestions?
Thanks a lot!!!
