Hello,
In several parts of my code I have included output to Serial port for debugging purposes.
eg
if (debugEnable) Serial.println(F("Query Peak Power"));
I am now trying to figure out how it would be possible to redirect this output to say Serial1 or other Stream object based on the state of a certain variable.
for example something like this:
if (console==1) {Serial.println(F("Query Peak Power"));}
else {Serial1.println(F("Query Peak Power"));}
Obviously I wouldn't like to have to enter the text twice every time as this takes unnecessary space.
Is there a more efficient way to achieve the same result?
void debugOut(const __FlashStringHelper *s) {
switch( console ) {
case 0:
Serial.println(s);
case 1:
Serial1.println(s);
Juraj:
something like this?
Thanks so mush for the speedy reply!
Hmm i am afraid I don't understand your code
In addition... it doesn't compile...
You could make an array of pointers to several serial objects and use console as an index for this array. E.g.,
Stream* out[] {&Serial1, &Serial};
size_t console {1};
out[console]->println(F("Hi."));
Or you could use a reference, e.g.,
Stream& mySerial {Serial}; // Or `Serial1`.
mySerial.println(F("Hi."));
Thanks... that looks like it will work. I ll try it later...
Thanks for the suggesttion.
Your first option looks like it will work.
The second one however, I dont see how it can avoid entering the "Hi" text twice..
In this case, the choice is made at compile time, when you want to disable debugging, you can set the reference to Serial1 and recompile.
gcjr
October 6, 2023, 9:50am
10
what about using a ptr?
int console = 0;
Stream *serial = & Serial;
void
setup (void)
Serial.begin (9600);
Serial1.begin (9600);
if (console)
serial = & Serial1;
void
loop (void)
serial->println ("hello");
gfvalvo
October 6, 2023, 10:24am
11
Combining a couple of the ideas from this thread:
#include "Arduino.h"
class DebugPrint : public Print {
public:
virtual size_t write(uint8_t c) {
return printPtr->write(c);
void directPrint(Print &here) {
printPtr = &here;
virtual ~DebugPrint() {
private:
Print *printPtr = &Serial;
DebugPrint debug;
void setup(){
Serial1.begin(115200);
delay(2000);
debug.print("Directing Debug Output to Serial");
debug.directPrint(Serial1);
debug.print("Debug Output Now Going to Serial1");
debug.directPrint(Serial);
debug.print("Debug Output Now Back at Serial");
void loop(){
gfvalvo
October 6, 2023, 11:08am
12
Here's a version that allows disabling of the printing:
class DebugPrint: public Print {
public:
if (printPtr != nullptr) {
return 1;
printPtr = &here;
void disablePrinting() {
printPtr = nullptr;
private:
DebugPrint debug;
delay(2000);
debug.disablePrinting();
debug.print("Nothing Will Print Here");
debug.print("Debug Output Now Going to Serial1 Again");
Thanks for the input.
I did try the code.
There seems to be some kind of conflict when used together with the TelnetStream library. ie when one of the stream objects is TelnetStream.
In this case Telnet connection is often lost.
I will do some more testing tomorrow with minimal code.
system
Closed
April 3, 2024, 6:44pm
14
