Hello friends.
I am measuring a value. Now i want to add a logile to my project.
So basic idea: Everytime a given thresholds is crossed, a logfile should be written.
In my "code-planing" i am facing the following problem.
Lets say my thresholds is 10. I am currently measuring a value that is lets say 12.
My first idea was something like this
if(currentvalue < 10)
...write loggile ....
obviously wrong. Because it would write me a logfile the whole time as long the value is < 10
Next idea:
if(currentvalue == 10)
is also far from perfect, becauce it is not always guaranteed that the measured value == 10. Becauce when the value changes to fast, it could be the case that the value 10 is skipped.
Adding a range of values into my if statement is possibly also not the right why, because it could be the case that the measured value will be in this range and i have the same problem like i mentioned above.
So the last idea that crossed my mind is something like this:
...execute a code that writes a logfile just once...
So i am a bit uninspired how to realize this idea IF the idea is the best
Someone has an idea or every faced the same problem?
Thank you
Use a boolean variable to control when data is written to the file
Set the boolean, let's name it okToWrite to false and write code to write to the file when the boolean is true and set it to false after writing. Now, when the threshold becomes exceeded set the boolean to true and the write will only happen once
Keep a variable with the previous value you read, prevValue perhaps. When checking whether to log, only log if previous was one side of the threshold and current is on the other.
thank you for the answers:
But when i do something like this (simplified)
bool okToWrite = false;
okToWrite = true
and i have a function like
void writelog()
if(okToWrite)
...write logfile...;
okToWrite = false;
To check if the value is < 10, the if statement must be in the loop.
So the problem is see now is: after i write the logfile, okToWrite will be set to false. BUT, since the value is still < 10 the okToWrite will be set again to true and another logfile will be written and so on.
Or do i miss something?
Thank you
You missed something.
I wrote
when the threshold becomes exceeded. That is not the same as when the threshold is exceeded
See also reply #2
