I just read the content of a 27256 from an old car ECM (1994 Mazda MX6) I had lying around using this code and a Mega2560. If you have a Mega and follow the connections (and tie E to GND) you should be able to print the content to the serial monitor as I did. What you can do with the result is another matter...
(the last few lines of the output)
30 93 34 23 0C 8F 96 33 BD FD 94 40 50 82 00 20
0A 40 50 82 00 8F 96 33 BD FD 94 D3 30 39 D6 30
27 1A 5F D7 30 4C D6 31 27 07 E6 01 11 25 01 17
39 4D 2B 07 A6 01 CE 01 01 DF 30 39 4A D6 31 26
09 43 E6 00 11 25 01 17 43 39 4D 2A 08 A6 00 43
CE 01 00 DF 30 39 04 04 04 04 04 04 04 4D 27 02
C6 FF 39 04 04 04 04 04 04 04 39 47 56 47 56 47
56 47 56 47 56 47 56 47 56 39 05 25 06 05 25 03
05 24 03 CC FF FF 39 CE 2C FC 86 03 4D 27 0E 0F
E6 00 5C 26 01 5A E7 00 0E 08 4A 20 EF 39 41 C5
96 C7 96 C7 96 C7 96 C7 96 C7 96 C7 96 C7 96 C7
96 C7 92 7E 92 87 96 C7 96 C7 96 C7 96 C7 92 72
92 90 96 C7 96 C7 96 C7 92 99 92 B7 92 C0 93 4A
92 C9 96 C7 96 C7 96 C7 96 C7 96 C7 96 C7 8E 26
unsigned int
Address;
//PORTF
//can use PINF to read data bus
const byte pinD0 = A0;
const byte pinD1 = A1;
const byte pinD2 = A2;
const byte pinD3 = A3;
const byte pinD4 = A4;
const byte pinD5 = A5;
const byte pinD6 = A6;
const byte pinD7 = A7;
const byte pinA0 = 2;
const byte pinA1 = 3;
const byte pinA2 = 4;
const byte pinA3 = 5;
const byte pinA4 = 6;
const byte pinA5 = 7;
const byte pinA6 = 8;
const byte pinA7 = 9;
const byte pinA8 = 10;
const byte pinA9 = 11;
const byte pinA10 = 12;
const byte pinA11 = 13;
const byte pinA12 = 21;
const byte pinA13 = 20;
const byte pinA14 = 19;
const byte pinG = 18;
const byte grData[] =
pinD0, pinD1, pinD2, pinD3,
pinD4, pinD5, pinD6, pinD7
const byte grAddr[] =
pinA0, pinA1, pinA2, pinA3,
pinA4, pinA5, pinA6, pinA7,
pinA8, pinA9, pinA10, pinA11,
pinA12, pinA13, pinA14
char szStr[16];
void setup( void )
unsigned char
idx,
databyte;
pinMode( pinG, OUTPUT );
digitalWrite( pinG, HIGH );
for( int i=0; i<8; i++ )
pinMode( grData[i], INPUT_PULLUP );
for( int i=0; i<15; i++ )
pinMode( grAddr[i], OUTPUT );
//0bx111 1111 1111 1111
Address = 0x0000;
idx = 0;
do
SetAddress( Address );
digitalWrite( pinG, LOW );
databyte = PINF;
sprintf( szStr, "%02X ", databyte );
Serial.print( szStr );
idx++;
if( idx == 16 )
idx = 0;
Serial.println("");
}//if
Address++;
}while( Address < 0x8000 );
}//setup
void loop( void )
}//loop
void SetAddress( unsigned int Adr )
digitalWrite( grAddr[i], (Adr & (1<<i)) ? HIGH:LOW );
}//SetAddress
