How to generate .a and .so files to add in arduino project
I know to make a library on arduino ide with source codes, but I cant send my source code to another users who want to use my lib.
So I need to make a library with precompiled=true info at library.properties. And I need to put my .a and .so files at src/{build.mcu} (in my case, src/avr/mylib.a and mylib.so).
But, where is that files (.a and .so)?!
Does the arduino compiler generate this files? If so, where? If dont, how compiler I need to use?
I found the .o file at appData\local\Temp\arduino_build_XXXX\libraries\mylib\
Thank you very much and sory about my english.
Enable verbose mode when compiling, and see for yourself. The answer is no, as the normal compile/link/upload process does not need them.
Thankyou for you early help.
Do you know which compiler I can use to generate this files? I think should be one compatible compiler.
There is most likely a compiler option for the gcc compiler (that you refer to as "the Arduino compiler") that will tell it to create the .a or .so files. When I used Unix, years ago, one used either .a files or .so files, depending on which version of Unix you were using.
Thank you Brattain.
I make using avr-gcc-a using Arduino IDE.
The resolution I posted here: How to generate .a and .so files to add in arduino project - Arduino Stack Exchange
Best regards.
