How to get element index of an array?
Good morning,
I am working on a project where I need to get the element index of an array. The following may clarify this:
char cti[]={'0', '1', '2', '3', '4', '5', '6', '7', '8', '9'};
If I need the placement number of "5" (which is 6), how do I find this?
Let me know if you need more clarification
Single quotes, not double.
You could look at strchr.
index of '5' is 5, indexes starts from zero
It depends on what @algorithmmusic is talking about.
If you want to find the character 'X' in an array of chars, by hand, you can use a for loop to see if the character at an index i is equal to the character you are looking for.
If you made cti into a properly terminated string, an array of characters with a '\0' in the last index, you could use strchr().
strchr() returns a pointer; to get the index, you must subtract the base array address.
char cti[]={'0', '1', '2', 'A', '4', '5', '6', '7', '8', '9', '\0'};
  Serial.being(115200);
  Serial.println(cti[3]);
// find 'A'
  char *x = strchr(cti, 'A');
  int index = x - cti;
  Serial.println(index);
HTH
a7
you can use a loop to search for the element, e.g.
  int i;
  char cti[] = { '0', '1', '2', '3', '4', '5', '6', '7', '8', '9' }, find='5';
  for (i = 0; i < sizeof(cti); i++)
    if (cti[i] == find) {
      Serial.printf("index of %c is %d\n", find, i);
  if (i == sizeof(cti)) Serial.printf("%c not found\n", find);
a run on an ESP32 gives
index of 5 is 5
How did I forget that :person_facepalming:
