How to get rid of this blocking delay
See Robin's Serial Input Basics - updated to get some ideas.
Note: Your code in post #19 will not work reliably; serial is slow so the processor might see 3 bytes followed by 5 bytes followed by 4 bytes.
I want to receive string of 12 characters
I want to read 4 serial port independently and turn on/off relay pin after each reading and comparing string
What is the exact Data Format that you expect to receive ?
What kind of Data ?
How many characters ?
What terminator is used ?
How much ?
Ah, I see that you can look in the future. Replying before @LarryD posted his question.
:rofl: :rofl: :rofl:
:scream:
if(Serial1.available())
You could use:
if(Serial1.available() > 11)
From your post #1
Serial.println(Switch_State1);
Serial1.println(Switch_State2);
Serial2.println(Switch_State3);
Serial3.println(Switch_State4);
What does the achieve ?
From your post #12.
What is connected to Serial1 port ?
How is the addition of the 4 Serial ports going to affect your current sketch ?
Do receive messages have a terminator character ?
Edit:
What message turns on the relay ?
For how long ?
What message turns off the relay ?
For how long ?
Can any serial port operate any relay ?
I am posting complete sketch which is working fine but there is only one problem. Controller get busy to turn on, off relay so that other serial port can not work
How to remove blocking delay for every relay's
#define ResetTimer         millis()
#define ENABLED            true
#define DISABLED           false
#define RelayOFF           HIGH
#define RelayON            LOW
#define PUSHED             LOW
#define RELEASED           HIGH
int Switch_State1, Switch_State2, Switch_State3, Switch_State4 = 0;
int count1, count2, count3, count4 = 0;                                          // count
char input1[12], input2[12], input3[12], input4[12] ;                            // character array to store 12 bytes
const int Switch_Pin1 = 4;
const int Switch_Pin2 = 5;
const int Switch_Pin3 = 6;
const int Switch_Pin4 = 7;
const int Relay_Pin1 =  8;
const int Relay_Pin2 =  9;
const int Relay_Pin3 =  10;
const int Relay_Pin4 =  11;
boolean FLAG1            =  DISABLED;
boolean FLAG2            =  DISABLED;
boolean FLAG3            =  DISABLED;
boolean FLAG4            =  DISABLED;
byte lastSwitch_Pin1     =  RELEASED;
byte lastSwitch_Pin2     =  RELEASED;
byte lastSwitch_Pin3     =  RELEASED;
byte lastSwitch_Pin4     =  RELEASED;
//timing stuff
unsigned long checkSwitchesTime;
unsigned long currentTime;
unsigned long relayTime1;
unsigned long relayTime2;
unsigned long relayTime3;
unsigned long relayTime4;
const long interval = 4000ul;
// Store valid tags for each door access
char * Valid_Tags_Door1[] = {"0B000238D9B", "060031F4894C", "16002GH7BF62", "190077FC1D24", "160064F9C45A"};
char * Valid_Tags_Door2[]  = {"0B000238D9B", "060031F4894C", "16002GH7BF62", "190077FC1D24", "160064F9C45A"};
char * Valid_Tags_Door3[]  = {"0B000238D9B", "060031F4894C", "16002GH7BF62", "190077FC1D24", "160064F9C45A"};
char * Valid_Tags_Door4[]  = {"0B000238D9B", "060031F4894C", "16002GH7BF62", "190077FC1D24", "160064F9C45A"};
  // begin serial port with baud rate 9600bps
  Serial1.begin(9600);
  Serial2.begin(9600);
  Serial3.begin(9600);
 // configure inputs pins for switche's
  pinMode(Switch_Pin1, INPUT);
  pinMode(Switch_Pin2, INPUT);
  pinMode(Switch_Pin3, INPUT);
  pinMode(Switch_Pin4, INPUT);
  // configure output pins for Door's
  pinMode(Relay_Pin1, OUTPUT);
  pinMode(Relay_Pin2, OUTPUT);
  pinMode(Relay_Pin3, OUTPUT);
  pinMode(Relay_Pin4, OUTPUT);
  // initially all door's are closed
  digitalWrite(Relay_Pin1, RelayON );
  digitalWrite(Relay_Pin2, RelayON );
  digitalWrite(Relay_Pin3, RelayON );
  digitalWrite(Relay_Pin4, RelayON );
   currentTime = millis();
  //time to check our switches ?
  if (currentTime - checkSwitchesTime >= 50)
    //restart this TIMER
    checkSwitchesTime = ResetTimer;
    checkSwitches();
  //if enabled, is this TIMER expired ?
  if (FLAG1 == ENABLED && currentTime - relayTime1 >= interval)
    //we are now finished with this TIMER
    FLAG1 = DISABLED;
    digitalWrite(Relay_Pin1, RelayON);
  if (FLAG2 == ENABLED && currentTime - relayTime2 >= interval)
    FLAG2 = DISABLED;
    digitalWrite(Relay_Pin2, RelayON);
  if (FLAG3 == ENABLED && currentTime - relayTime3 >= interval)
    FLAG3 = DISABLED;
    digitalWrite(Relay_Pin3, RelayON);
  if (FLAG4 == ENABLED && currentTime - relayTime4 >= interval)
    FLAG4 = DISABLED;
    digitalWrite(Relay_Pin4, RelayON);
  if(Serial.available())
    while(Serial.available() && count1 < 12) // Read 12 characters and store them in input array
      input1[count1] = Serial.read();
      count1++;
      delay(4);
    if  (count1 == 12){
        count1 = 0;
        String RFID1_tag_number = input1;
      for (int i = 0; i < 5; i++)
         if (strcmp(Valid_Tags_Door1[i] , input1) == 0)
            digitalWrite(Relay_Pin1, RelayOFF );
            delay(1500);
  if(Serial1.available()){
    while(Serial1.available() && count2 < 12) // Read 12 characters and store them in input array
      input2[count2] = Serial1.read();
      count2++;
      delay(2);
    if  (count2 == 12){
         count2 = 0;
        String RFID2_tag_number = input2;
         if (strcmp(Valid_Tags_Door2[i] , input2) == 0){
            digitalWrite(Relay_Pin2, RelayOFF );
 if(Serial2.available())
    while(Serial2.available() && count3 < 12) // Read 12 characters and store them in input array
      input3[count3] = Serial2.read();
      count3++;
      delay(4);
    if  (count3 == 12){
        count3 = 0;
        String RFID3_tag_number = input3;
         if (strcmp(Valid_Tags_Door3[i] , input3) == 0)
            digitalWrite(Relay_Pin3, RelayOFF );
 if(Serial3.available())
    while(Serial3.available() && count4 < 12) // Read 12 characters and store them in input array
      input4[count4] = Serial3.read();
      count4++;
      delay(4);
    if  (count4 == 12){
        count4 = 0;
        String RFID4_tag_number = input4;
         if (strcmp(Valid_Tags_Door4[i] , input4) == 0)
            digitalWrite(Relay_Pin4, RelayOFF);
void checkSwitches()
  byte currentState = digitalRead(Switch_Pin1);
  if (lastSwitch_Pin1 != currentState)
    lastSwitch_Pin1 = currentState;
    if (FLAG1 == DISABLED && currentState == PUSHED)
      //enable this TIMER
      FLAG1 = ENABLED;
      digitalWrite(Relay_Pin1, RelayOFF);
      //reset this TIMER
      relayTime1 = ResetTimer;
  } //END of this switch
  //*********************************                   Switch_Pin2
  currentState = digitalRead(Switch_Pin2);
  //did this switch change state ?
  if (lastSwitch_Pin2 != currentState)
    //update to the new state
    lastSwitch_Pin2 = currentState;
    //if we are not timing, is the switch now pushed ?
    if (FLAG2 == DISABLED && currentState == PUSHED)
      //enable this TIMER
      FLAG2 = ENABLED;
      digitalWrite(Relay_Pin2, RelayOFF);
      //reset this TIMER
      relayTime2 = ResetTimer;
  currentState = digitalRead(Switch_Pin3);
  if (lastSwitch_Pin3 != currentState)
    lastSwitch_Pin3 = currentState;
    if (FLAG3 == DISABLED && currentState == PUSHED)
      //enable this TIMER
      FLAG3 = ENABLED;
      digitalWrite(Relay_Pin3, RelayOFF);
      //reset this TIMER
      relayTime3 = ResetTimer;
  currentState = digitalRead(Switch_Pin4);
  if (lastSwitch_Pin4 != currentState)
    lastSwitch_Pin4 = currentState;
    if (FLAG4 == DISABLED && currentState == PUSHED)
      //enable this TIMER
      FLAG4 = ENABLED;
      //reset this TIMER
      relayTime4 = ResetTimer;
You must give use complete code.
As you see below, one group has 11 characters and the others have 12
0B000238D9B     This has 11 characters   <-----<<<<<
060031F4894C    This has 12 characters
16002GH7BF62    This has 12 characters
190077FC1D24    This has 12 characters
160064F9C45A    This has 12 characters
sorry it was copy paste error. All are 12 characters
What should this be 0B000238D9B ?
12 characters
0B000238CD9B
060031F4894C
16002GH7BF62
190077FC1D24
160064F9C45A
This is close.
You can do Serial1-2-3
//  https://forum.arduino.cc/t/how-to-get-rid-of-this-blocking-delay/1025651
//  0_Arduino_Skeleton_Sketch.ino
//  Version   YY/MM/DD     Comments
//  1.01      22/08/25     Running code
//  1.02      22/08/25     Added code to handle relays 4 and 5, move from pin12 to pin 11
//  1.03      22/08/26     Added RFID code
#define RESETtime           millis()
#define RelayON             LOW
#define PUSHED              LOW      //+5V---[Pullup]---[Input Pin]---[Switch]---GND
const byte Switch1        = 4;
const byte Switch2        = 5;
const byte Switch3        = 6;
const byte Switch4        = 7;
const byte Relay1         = 8;
const byte Relay2         = 9;
const byte Relay3         = 10;
const byte Relay4         = 11;
const byte heartbeatLED   = 13;
boolean TimerFlag1        = DISABLED;
boolean TimerFlag2        = DISABLED;
boolean TimerFlag3        = DISABLED;
boolean TimerFlag4        = DISABLED;
byte lastSwitch1          = RELEASED;
byte lastSwitch2          = RELEASED;
byte lastSwitch3          = RELEASED;
byte lastSwitch4          = RELEASED;
byte count1;
byte count2;
byte count3;
byte count4;
char input1[12];
char input2[12];
char input3[12];
char input4[12];
//valid tags for each door access:
char * Valid_Tags_Door1[] = {"0B000238CD9B", "060031F4894C", "16002GH7BF62", "190077FC1D24", "160064F9C45A"};
char * Valid_Tags_Door2[] = {"0B000238CD9B", "060031F4894C", "16002GH7BF62", "190077FC1D24", "160064F9C45A"};
char * Valid_Tags_Door3[] = {"0B000238CD9B", "060031F4894C", "16002GH7BF62", "190077FC1D24", "160064F9C45A"};
char * Valid_Tags_Door4[] = {"0B000238CD9B", "060031F4894C", "16002GH7BF62", "190077FC1D24", "160064F9C45A"};
//timing stuff
const unsigned long switchInterval = 4000ul;
const unsigned long rfidInterval   = 1500ul;
unsigned long interval;
unsigned long heartbeatTime;
unsigned long checkRfidTime;
unsigned long relay1Time;
unsigned long relay2Time;
unsigned long relay3Time;
unsigned long relay4Time;
//                                       s e t u p ( )
  //  Serial1.begin(9600);
  //  Serial2.begin(9600);
  //  Serial3.begin(9600);
  pinMode(Switch1, INPUT_PULLUP);
  pinMode(Switch2, INPUT_PULLUP);
  pinMode(Switch3, INPUT_PULLUP);
  pinMode(Switch4, INPUT_PULLUP);
  pinMode(heartbeatLED, OUTPUT);
  pinMode(Relay1, OUTPUT);
  pinMode(Relay2, OUTPUT);
  pinMode(Relay3, OUTPUT);
  pinMode(Relay4, OUTPUT);
  digitalWrite(Relay1, RelayON);
  digitalWrite(Relay2, RelayON);
  digitalWrite(Relay3, RelayON);
  digitalWrite(Relay4, RelayON);
} //END of   setup()
//                                        l o o p ( )
  //*********************************                         heartbeat TIMER
  //is it time to toggle the heartbeatLED (every 500ms)?
  if (millis() - heartbeatTime >= 500ul)
    heartbeatTime = RESETtime;
    //toggle the heartbeatLED
    digitalWrite(heartbeatLED, !digitalRead(heartbeatLED));
  //*********************************                         checkSwitches TIMER
  //is time to check our switches ?
  if (millis() - checkSwitchesTime >= 50ul)
    checkSwitchesTime = RESETtime;
    checkSwitches();
  //*********************************                         checkRfidTime TIMER
  //is time to check for RFID receive characters ?
  if (millis() - checkRfidTime >= 20ul)
    checkRfidTime = RESETtime;
    checkrfidTags();
  //*********************************                         Relay1 TIMER
  if (TimerFlag1 == ENABLED && millis() - relay1Time >= interval)
  //*********************************                         Relay2 TIMER
  if (TimerFlag2 == ENABLED && millis() - relay2Time >= interval)
  //*********************************                         Relay3 TIMER
  if (TimerFlag3 == ENABLED && millis() - relay3Time >= interval)
  //*********************************                         Relay4 TIMER
  if (TimerFlag4 == ENABLED && millis() - relay4Time >= interval)
  //other non blocking code goes here
} //END of    loop()
//                               c h e c k S w i t c h e s ( )
  byte currentState;
  //*********************************                         Switch1
  currentState = digitalRead(Switch1);
  if (lastSwitch1 != currentState)
    lastSwitch1 = currentState;
    if (TimerFlag1 == DISABLED && currentState == PUSHED)
      //enable this TIMER
      TimerFlag1 = ENABLED;
      //set the interval for the relay TIMER
      interval = switchInterval;
      //reset this TIMER
      relay1Time = RESETtime;
      digitalWrite(Relay1, RelayOFF);
  //*********************************                         Switch2
  currentState = digitalRead(Switch2);
  if (lastSwitch2 != currentState)
    lastSwitch2 = currentState;
    if (TimerFlag2 == DISABLED && currentState == PUSHED)
      //enable this TIMER
      TimerFlag2 = ENABLED;
      //reset this TIMER
      relay2Time = RESETtime;
      digitalWrite(Relay2, RelayOFF);
  //*********************************                         Switch3
  currentState = digitalRead(Switch3);
  if (lastSwitch3 != currentState)
    lastSwitch3 = currentState;
    if (TimerFlag3 == DISABLED && currentState == PUSHED)
      //enable this TIMER
      TimerFlag3 = ENABLED;
      //reset this TIMER
      relay3Time = RESETtime;
      digitalWrite(Relay3, RelayOFF);
  //*********************************                         Switch4
  currentState = digitalRead(Switch4);
  if (lastSwitch4 != currentState)
    lastSwitch4 = currentState;
    if (TimerFlag4 == DISABLED && currentState == PUSHED)
      //enable this TIMER
      TimerFlag4 = ENABLED;
      //reset this TIMER
      relay4Time = RESETtime;
      digitalWrite(Relay4, RelayOFF);
} //END of checkSwitches()
//                                    r f i d T a g s ( )
void checkrfidTags()
  //*********************************                         port Serial
  //are any characters in the buffer on this port ?
  while (Serial.available() > 0)
    //Don't allow more than 12 characters, i.e. 0 thru 11 only
    if (count1 < 12)
      count1++;
      //clear out extra characters if any
        count1 = 0;
        //throw away this character
        Serial.read();
      //clear out the array
      for (byte x = 0; x < 12; x++)
        input1[x] = 0;
  //have we received all 12 characters 0 thru 11 ?
  if (count1 == 12)
    //get ready for next string of received characters
    count1 = 0;
    //go thru all the Tags on file to see if we find a match
      //do we have a compare with the received Tag to the Tags on file ?
      if (TimerFlag1 == DISABLED && strcmp(Valid_Tags_Door1[i] , input1) == 0)
        //enable this TIMER
        //set the Timer interval
        interval = rfidInterval;
        //reset this TIMER
} //END   rfidTags()s
My Thoughts on how to accomplish this:
const int Relay_Pin4 =  12;
  pinMode(Relay_Pin3, INPUT);
  pinMode(Relay_Pin4, INPUT);
  digitalWrite(Relay_Pin1, LOW);
  digitalWrite(Relay_Pin2, LOW);
  digitalWrite(Relay_Pin3, LOW);
  digitalWrite(Relay_Pin4, LOW);
  int  Switch_State1 = digitalRead(Switch_Pin1);
  int  Switch_State2 = digitalRead(Switch_Pin2);
  int  Switch_State3 = digitalRead(Switch_Pin3);
  int  Switch_State4 = digitalRead(Switch_Pin4);
  static unsigned int StartTime1;
  static unsigned int StartTime2;
  static unsigned int StartTime3;
  static unsigned int StartTime4;
  if (Switch_State1 == LOW && (millis() - StartTime1) >= (4000) ) { // Restricts the output from restarting like delay() would
    StartTime1 = millis();
  if (Switch_State2 == LOW && (millis() - StartTime2) >= (4000) ) { // Restricts the output from restarting like delay() would
    StartTime2 = millis();
  if (Switch_State3 == LOW && (millis() - StartTime3) >= (4000) ) { // Restricts the output from restarting like delay() would
    StartTime3 = millis();
  if (Switch_State4 == LOW && (millis() - StartTime4) >= (4000) ) { // Restricts the output from restarting like delay() would
  digitalWrite(Relay_Pin4, (millis() - StartTime1) < (4000));
  digitalWrite(Relay_Pin4, (millis() - StartTime2) < (4000));
  digitalWrite(Relay_Pin4, (millis() - StartTime3) < (4000));
  digitalWrite(Relay_Pin4, (millis() - StartTime4) < (4000));
This felt a lot easier than other examples I've seen
Z
How can copy/paste cause errors like that? This is the second time you mentioned a copy paste error in this thread. Are you re-typing the code in to this forum?
