How to get rid of this blocking delay
I have written simple code. I want the 4 relay to turn on/off independently when switch is pressed first time
Relay is active low and switch is connected with pull up resistor, initially all relays are active, relay should goes off / on after pressing button
How to get rid of this blocking delay ?
const int Switch_Pin1 = 4;
const int Switch_Pin2 = 5;
const int Switch_Pin3 = 6;
const int Switch_Pin4 = 7;
const int Relay_Pin1 =  8;
const int Relay_Pin2 =  9;
const int Relay_Pin3 =  10;
const int Relay_Pin4 =  12;
  // begin serial port with baud rate 9600bps
  pinMode(Switch_Pin1, INPUT);
  pinMode(Switch_Pin2, INPUT);
  pinMode(Switch_Pin3, INPUT);
  pinMode(Switch_Pin4, INPUT);
  pinMode(Relay_Pin1, OUTPUT);
  pinMode(Relay_Pin2, OUTPUT);
  pinMode(Relay_Pin3, INPUT);
  pinMode(Relay_Pin4, INPUT);
  digitalWrite(Relay_Pin1, LOW);
  digitalWrite(Relay_Pin2, LOW);
  digitalWrite(Relay_Pin3, LOW);
  digitalWrite(Relay_Pin4, LOW);
int  Switch_State1 = digitalRead(Switch_Pin1);
int  Switch_State2 = digitalRead(Switch_Pin2);
int  Switch_State3 = digitalRead(Switch_Pin3);
int  Switch_State4 = digitalRead(Switch_Pin4);
  Serial.println(Switch_State1);
  Serial1.println(Switch_State2);
  Serial2.println(Switch_State3);
  Serial3.println(Switch_State4);
  if(Switch_State1 == LOW ){
     digitalWrite(Relay_Pin1, HIGH);
     delay(4000);
  if(Switch_State2 == LOW ){
     digitalWrite(Relay_Pin2, HIGH);
     delay(4000);
  if(Switch_State3 == LOW ){
     digitalWrite(Relay_Pin3, HIGH);
     delay(4000);
 if(Switch_State4 == LOW ){
     digitalWrite(Relay_Pin4, HIGH);
     delay(4000);
Example-code for timing based on millis()
BlinkWithoutDelay
I don't understand what to do next ?
// constants won't change:
const long interval = 4000;
 // configure inputs pins for switche's
     if (currentMillis - previousMillis >= interval) {
Let's clear up a couple of things first:
  1. Why do you have Relay_Pin3 and Relay_Pin4 defined as inputs?
  2. How are your switches wired? Do you have external pullup resistors?
You will need 4 (four) different BWD type timers.
Set a Flag when the switch goes from not pushed to pushed, turn OFF the output and reset that TIMER
When a Flag is set, check to see if that TIMER has expired; if it has, reset that Flag and turn ON the output.
Confirm your switches are wired as S2 in the schematic below:
Always show us a good schematic of your proposed circuit.
Show us a good image of your ‘actual’ wiring.
Give links to components.
An error occurred while pasting the code
Yes
here is an example of 3 independent groups of input pin / output pin and separate timers:
struct Groups {
  const byte buttonPin;
  const byte outputPin;
  uint32_t previousMillis;
Groups group[] {
  {A0, 2, 0},  // index 0: button Pin, outputPin, previousMillis
  {A1, 3, 0},
  {A2, 4, 0}
void tickButtonLed()
  for (auto & i : group)
    if (digitalRead(i.buttonPin) == LOW) {
      digitalWrite(i.outputPin, HIGH);
      i.previousMillis = millis();
    if (millis() - i.previousMillis > 3 * 1000UL && digitalRead(i.outputPin) == HIGH)
      digitalWrite(i.outputPin, LOW);
    pinMode(i.buttonPin, INPUT_PULLUP);
    pinMode(i.outputPin, OUTPUT);
  tickButtonLed();
the interval is set to 3 * 1000UL = 3 seconds.
You should be able to modify to 4 seconds on your own.
the code is described here:
https://werner.rothschopf.net/202003_arduino_retriggerbares_nachlaufrelais.htm
you can translate it with any online service to your language.
I have 40000 ms the time interval. The flag is set when the button is pressed.
How to configure the timer in code?
When a Flag is set, how to check if that TIMER has expired; ?
The code @noiasca posted will work with very little modification.
Before writing the code I want to understand few things.
I've been told I'll need four timers. I don't understand in the code which timer is using in code, how its configured and how can we compare the time
This is the code that compares the time:
This should be very close, you will do the last two :wink:
// https://forum.arduino.cc/t/how-to-get-rid-of-this-blocking-delay/1025651
//  XXXXXXXXXXXXXXXXX.ino
//  Version   YY/MM/DD     Comments
//  1.01      22/08/25     Running code
#define ResetTimer         millis()
#define ENABLED            true
#define DISABLED           false
#define RelayOFF           HIGH
#define RelayON            LOW
#define PUSHED             LOW
#define RELEASED           HIGH
const byte Switch_Pin1   = 4;
const byte Switch_Pin2   = 5;
const byte Switch_Pin3   = 6;
const byte Switch_Pin4   = 7;
const byte Relay_Pin1    = 8;
const byte Relay_Pin2    = 9;
const byte Relay_Pin3    = 10;
const byte Relay_Pin4    = 12;
const byte heartbeatLED  = 13;
boolean FLAG1            =  DISABLED;
boolean FLAG2            =  DISABLED;
boolean FLAG3            =  DISABLED;
boolean FLAG4            =  DISABLED;
byte lastSwitch_Pin1     =  RELEASED;
byte lastSwitch_Pin2     =  RELEASED;
byte lastSwitch_Pin3     =  RELEASED;
byte lastSwitch_Pin4     =  RELEASED;
//timing stuff
unsigned long heartbeatMillis;
unsigned long checkSwitchesTime;
unsigned long currentTime;
unsigned long relayTime1;
unsigned long relayTime2;
unsigned long relayTime3;
unsigned long relayTime4;
const long interval = 4000ul;
  pinMode(Switch_Pin1, INPUT_PULLUP);
  pinMode(Switch_Pin2, INPUT_PULLUP);
  pinMode(Switch_Pin3, INPUT_PULLUP);
  pinMode(Switch_Pin4, INPUT_PULLUP);
  pinMode(heartbeatLED, OUTPUT);
  pinMode(Relay_Pin3, OUTPUT);
  pinMode(Relay_Pin4, OUTPUT);
  digitalWrite(Relay_Pin1, RelayON);
  digitalWrite(Relay_Pin2, RelayON);
  digitalWrite(Relay_Pin3, RelayON);
  digitalWrite(Relay_Pin4, RelayON);
} //END of   setup()
  //capture the current time in milliseconds
  currentTime = millis();
  //*********************************                         heartbeat TIMER
  //is it time to toggle the heartbeatLED (every 500ms)?
  if (millis() - heartbeatMillis >= 500ul)
    //restart this TIMER
    heartbeatMillis = millis();
    //toggle the heartbeatLED
    digitalWrite(heartbeatLED, !digitalRead(heartbeatLED));
  //*********************************                         checkSwitches TIMER
  //time to check our switches ?
  if (currentTime - checkSwitchesTime >= 50)
    checkSwitchesTime = ResetTimer;
    checkSwitches();
  //*********************************                         Relay_Pin1 TIMER
  //if enabled, is this TIMER expired ?
  if (FLAG1 == ENABLED && currentTime - relayTime1 >= interval)
    //we are now finished with this TIMER
    FLAG1 = DISABLED;
  //*********************************                         Relay_Pin2 TIMER
  if (FLAG2 == ENABLED && currentTime - relayTime2 >= interval)
    FLAG2 = DISABLED;
  //other non blocking code goes here
} //END of    loop()
void checkSwitches()
  //*********************************                   Switch_Pin1
  byte currentState = digitalRead(Switch_Pin1);
  //did this switch change state ?
  if (lastSwitch_Pin1 != currentState)
    //update to the new state
    lastSwitch_Pin1 = currentState;
    //if we are not timing, is the switch now pushed ?
    if (FLAG1 == DISABLED && currentState == PUSHED)
      //enable this TIMER
      FLAG1 = ENABLED;
      digitalWrite(Relay_Pin1, RelayOFF);
      //reset this TIMER
      relayTime1 = ResetTimer;
      //do nothing here
  } //END of this switch
  //*********************************                   Switch_Pin2
  currentState = digitalRead(Switch_Pin2);
  if (lastSwitch_Pin2 != currentState)
    lastSwitch_Pin2 = currentState;
    if (FLAG2 == DISABLED && currentState == PUSHED)
      //enable this TIMER
      FLAG2 = ENABLED;
      digitalWrite(Relay_Pin2, RelayOFF);
      //reset this TIMER
      relayTime2 = ResetTimer;
      //do nothing here
} //END of checkSwitches()
EDIT
Added some comments
I am out of the home so can't test code but this is program I would test
#define RelayON            LOW
#define PUSHED             LOW
//timing stuff
    checkSwitches();
    FLAG1 = DISABLED;
    FLAG2 = DISABLED;
    if (FLAG3 == ENABLED && currentTime - relayTime3 >= interval)
    FLAG3 = DISABLED;
  if (FLAG4 == ENABLED && currentTime - relayTime4 >= interval)
    FLAG4 = DISABLED;
      //enable this TIMER
      FLAG1 = ENABLED;
      //reset this TIMER
      //do nothing here
      //enable this TIMER
      FLAG2 = ENABLED;
      //reset this TIMER
      //do nothing here
    currentState = digitalRead(Switch_Pin3);
  if (lastSwitch_Pin3 != currentState)
    lastSwitch_Pin3 = currentState;
    if (FLAG3 == DISABLED && currentState == PUSHED)
      //enable this TIMER
      FLAG3 = ENABLED;
      digitalWrite(Relay_Pin3, RelayOFF);
      //reset this TIMER
      relayTime3 = ResetTimer;
      //do nothing here
    currentState = digitalRead(Switch_Pin4);
  if (lastSwitch_Pin4 != currentState)
    lastSwitch_Pin4 = currentState;
    if (FLAG4 == DISABLED && currentState == PUSHED)
      //enable this TIMER
      FLAG4 = ENABLED;
      digitalWrite(Relay_Pin4, RelayOFF);
      //reset this TIMER
      relayTime4 = ResetTimer;
      //do nothing here
If you are still confused about how Blink Without Delay works, study this excellent tutorial:
I have a doubt How many hardware timers are configured for four switches one or four?
There are no hardware timers being used.
There are 4 (four) software timers, one for each relay.
There is also 1 (one) software timer used for the checkSwitches( ) function.
In post #12, there is also 1 (one) software timer used for toggling the heartbeatLED.
In the sketch in post #12, we therefore have 6 software timers.
None, as you will understand after studying the tutorial linked in post #14.
Your additions look oaky.
Words of advice:
Review the following attached version.
Pay attention to the style and code formatting to see how you can achieve documentation and readability in your projects.
In the software that you write, try to follow a similar style.
Note:
  • In the following sketch pin 12 was moved over to pin 11.
  • A heartbeatLED was added.
    This LED gives a good indication if code is blocking; the LED should toggle every 1/2 second.
//  0_Arduino_Skeleton_Sketch.ino
//  1.02      22/08/25     Added code to handle relays 4 and 5, move from pin12 to pin 11
#define RESETtime          millis()
#define RelayON            LOW
#define PUSHED             LOW      //+5V---[Pullup]---[Input Pin]---[Switch]---GND
const byte Switch1       = 4;
const byte Switch2       = 5;
const byte Switch3       = 6;
const byte Switch4       = 7;
const byte Relay1        = 8;
const byte Relay2        = 9;
const byte Relay3        = 10;
const byte Relay4        = 11;
boolean TimerFlag1       =  DISABLED;
boolean TimerFlag2       =  DISABLED;
boolean TimerFlag3       =  DISABLED;
boolean TimerFlag4       =  DISABLED;
byte lastSwitch1         =  RELEASED;
byte lastSwitch2         =  RELEASED;
byte lastSwitch3         =  RELEASED;
byte lastSwitch4         =  RELEASED;
//timing stuff
unsigned long heartbeatTime;
unsigned long relay1Time;
unsigned long relay2Time;
unsigned long relay3Time;
unsigned long relay4Time;
//                                       s e t u p ( )
  pinMode(Switch1, INPUT_PULLUP);
  pinMode(Switch2, INPUT_PULLUP);
  pinMode(Switch3, INPUT_PULLUP);
  pinMode(Switch4, INPUT_PULLUP);
  pinMode(Relay1, OUTPUT);
  pinMode(Relay2, OUTPUT);
  pinMode(Relay3, OUTPUT);
  pinMode(Relay4, OUTPUT);
  digitalWrite(Relay1, RelayON);
  digitalWrite(Relay2, RelayON);
  digitalWrite(Relay3, RelayON);
  digitalWrite(Relay4, RelayON);
} //END of   setup()
//                                        l o o p ( )
  if (currentTime - heartbeatTime >= 500ul)
    heartbeatTime = RESETtime;
  if (currentTime - checkSwitchesTime >= 50ul)
    checkSwitchesTime = RESETtime;
    checkSwitches();
  //*********************************                         Relay1 TIMER
  if (TimerFlag1 == ENABLED && currentTime - relay1Time >= interval)
  //*********************************                         Relay2 TIMER
  if (TimerFlag2 == ENABLED && currentTime - relay2Time >= interval)
  //*********************************                         Relay3 TIMER
  if (TimerFlag3 == ENABLED && currentTime - relay3Time >= interval)
  //*********************************                         Relay4 TIMER
  if (TimerFlag4 == ENABLED && currentTime - relay4Time >= interval)
} //END of    loop()
//                               c h e c k S w i t c h e s ( )
    byte currentState;
  //*********************************                         Switch1
  currentState = digitalRead(Switch1);
  if (lastSwitch1 != currentState)
    lastSwitch1 = currentState;
    if (TimerFlag1 == DISABLED && currentState == PUSHED)
      //enable this TIMER
      TimerFlag1 = ENABLED;
      digitalWrite(Relay1, RelayOFF);
      //reset this TIMER
      relay1Time = RESETtime;
  //*********************************                         Switch2
  currentState = digitalRead(Switch2);
  if (lastSwitch2 != currentState)
    lastSwitch2 = currentState;
    if (TimerFlag2 == DISABLED && currentState == PUSHED)
      //enable this TIMER
      TimerFlag2 = ENABLED;
      digitalWrite(Relay2, RelayOFF);
      //reset this TIMER
      relay2Time = RESETtime;
  //*********************************                         Switch3
  currentState = digitalRead(Switch3);
  if (lastSwitch3 != currentState)
    lastSwitch3 = currentState;
    if (TimerFlag3 == DISABLED && currentState == PUSHED)
      //enable this TIMER
      TimerFlag3 = ENABLED;
      digitalWrite(Relay3, RelayOFF);
      //reset this TIMER
      relay3Time = RESETtime;
  //*********************************                         Switch4
  currentState = digitalRead(Switch4);
  if (lastSwitch4 != currentState)
    lastSwitch4 = currentState;
    if (TimerFlag4 == DISABLED && currentState == PUSHED)
      //enable this TIMER
      TimerFlag4 = ENABLED;
      digitalWrite(Relay4, RelayOFF);
      //reset this TIMER
      relay4Time = RESETtime;
multiple switches reading work for me, How to read multiple serial port I want to avoid blocking delay mega2560 four ports
int count = 0;                                          // count = 0
char input[12];                                         // character array
char * validTags[] = {"0A006FBE33E9", "0E004560173D"};
  Serial.begin(9600);               // begin serial port with baud rate 9600bps
  Serial1.begin(9600);
if(Serial1.available())
  count = 0;
  If(Serial1.available() && count < 12) // Read 12 characters and store them in input array
    input[count] = Serial1.read();
    count++;
    delay(5);
    if  (count == 12){
        count = 0;
        String Value = input;
        Serial.println(Value);                     // Print RFID tag number
    for (int t = 0; t < 2; t++)
       if (strcmp(validTags[t], input) == 0)
          Serial.print("Tag ");
You can use a non-blocking library such as LED library.
The below code:
// in loop function
delay(4000);
Can be replaced by a non-blocking code:
relay.turnON();          // turn on immediately
relay.turnOFF(4000);     // turn off after 4 second
See this example for more detailed
