NEW_hep.ino (14.5 KB)
i want to control the vfd motor rotation movement based on the angle values from sensors and previously in this i tried using delay in function sensors don 't get values during delay so it misses that position it starts to rotate continuously and i want to stop the vfd motor when it reaches the exact position let s say 90 degree s how to achieve this ??? please help with this .........
code is there in the above ino file
///// sensor 1 pins
const int ClockPin = 6; //output to clock
const int CSnPin = 5; //output to chip select
const int InputPin = 4; //read AS5040
/////////sensor 2 pins
const int ClockPin2 = 11; //output to clock
const int CSnPin2 = 12; //output to chip select
const int InputPin2 = 10; //read AS5040
int enablePin2 = 8;
int enablePin1 = 9;
// slave 1 COMMANDS
byte FWD1[] = {0x01, 0x06, 0x11, 0x00, 0x00, 0x01, 0x4D, 0x36};
byte REV1[] = {0x01, 0x06, 0x11, 0x00, 0x00, 0x02, 0x0D, 0x37};
byte STOP1[]= {0x01, 0x06, 0x11, 0x00, 0x00, 0x06, 0x0C, 0xF4};
byte SPD01[] = {0x01, 0x06, 0x10, 0x00, 0x00, 0x00, 0x8D, 0x0A}; // 0 % OF MAX SPEED AT SLAVE 1
byte SPD101[]= {0x01, 0x06, 0x10, 0x00, 0x03, 0xE8, 0x8D, 0xB4}; // 10 % OF MAX SPEED AT SLAVE 1
byte SPD251[]= {0x01, 0x06, 0x10, 0x00, 0x09, 0xC4, 0x8A, 0xC9}; // 25 % OF MAX SPEED AT SLAVE 1
byte SPD501[]= {0x01, 0x06, 0x10, 0x00, 0x13, 0x88, 0x80, 0x5C}; // 50 % OF MAX SPEED AT SLAVE 1
byte SPD751[]= {0x01, 0x06, 0x10, 0x00, 0x1D, 0x4C, 0x85, 0xAF}; // 75 % OF MAX SPEED AT SLAVE 1
byte SPD1001[]= {0x01, 0x06, 0x10, 0x00, 0x27, 0x10, 0x97, 0x36}; // 100 % OF MAX SPEED AT SLAVE 1
// slave 2
byte FWD2[] = {0x02, 0x06, 0x11, 0x00, 0x00, 0x01, 0x4D, 0x05}; // FWD : 02 06 11 00 00 01 4D 05
byte REV2[] = {0x02, 0x06, 0x11, 0x00, 0x00, 0x02, 0x0D, 0x04}; // REV : 02 06 11 00 00 02 0D 04
byte STOP2[]= {0x02, 0x06, 0x11, 0x00, 0x00, 0x06, 0x0C, 0xC7}; // STOP : 02 06 11 00 00 06 0C C7
byte SPD02[] = {0x02, 0x06, 0x10, 0x00, 0x00, 0x00, 0x8D, 0x039}; // SPEED0 : 02 06 10 00 00 00 8D 39
byte SPD102[]= {0x02, 0x06, 0x10, 0x00, 0x03, 0xE8, 0x8D, 0x87}; // SPEED10 : 02 06 10 00 03 E8 8D 87
byte SPD252[]= {0x02, 0x06, 0x10, 0x00, 0x09, 0xC4, 0x8A, 0xFA}; // SPEED25 : 02 06 10 00 09 C4 8A FA
byte SPD502[]= {0x02, 0x06, 0x10, 0x00, 0x13, 0x88, 0x80, 0x6F}; // SPEED50 : 02 06 10 00 13 88 80 6F
byte SPD752[]= {0x02, 0x06, 0x10, 0x00, 0x1D, 0x4C, 0x85, 0x9C}; // SPEED75 : 02 06 10 00 1D 4C 85 9C
byte SPD1002[]={0x02, 0x06, 0x10, 0x00, 0x27, 0x10, 0x97, 0x05}; // SPEED100 : 02 06 10 00 27 10 97 05
// value of runcom is 1 then it indicates fwd
// value of runcom is 2 then it indicates rev // speedcontrol is given in percentage basically four values can be chosen 25% ,50% , 75% ,100%
// this function is to run motor 1
// defining the range of motor's rotation
// every value is in angle value of degree
const long potMini=0; //450;
const long potMaxi=360; //723;
// sets value to 562
// inital posn value
long axis1=206,prev_axis1=206,inv_axis1=206; //middle position 0-1024 val=586
long axis2=206,prev_axis2=206,inv_axis2=206; //middle position 0-1024 val=586
static long brakingDistance=7;
static unsigned long sensor1,sensor2;
void Run_motor1( int runCom, int speedControl)
if (runCom==1 )// it indicates fwd
Serial1.write(SPD01, sizeof(SPD01));
delay(20);
Serial1.write(FWD1, sizeof(FWD1));
delay(20);
if (speedControl==25)
Serial1.write(SPD251, sizeof(SPD251));
delay(20);
else if (speedControl==50)
Serial1.write(SPD501, sizeof(SPD501));
delay(20);
else if (speedControl==75)
Serial1.write(SPD751, sizeof(SPD751));
delay(20);
else if (speedControl==100)
Serial1.write(SPD1001, sizeof(SPD1001));
delay(20);
if (runCom== 2)// it indicates rev
delay(20);
Serial1.write(REV1, sizeof(REV1));
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
// this function is to run motor 2
void Run_motor2( int runCom, int speedControl)
Serial2.write(SPD02, sizeof(SPD02));
delay(20);
Serial2.write(FWD2, sizeof(FWD2));
delay(20);
Serial2.write(SPD252, sizeof(SPD252));
delay(20);
Serial2.write(SPD502, sizeof(SPD502));
delay(20);
Serial2.write(SPD752, sizeof(SPD752));
delay(20);
Serial2.write(SPD1002, sizeof(SPD1002));
delay(20);
delay(20);
Serial2.write(REV2, sizeof(REV2));
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
// to stop both motor 1 and 2
void Stop ()
delay(20);
delay(20);
Serial2.write(STOP2, sizeof(STOP2));
delay(20);
Serial1.write(STOP1, sizeof(STOP1));
delay(20);
// to stop motor 2
void Stop_2()
delay(20);
delay(20);
// to stop motor 1
void Stop_1()
Serial1.write(STOP1, sizeof(STOP2));
delay(20);
delay(20);
// this func is to get the angle from sensor
unsigned int GetSensorValue(uint8_t CS,uint8_t CLK,uint8_t SerD){
static unsigned long angle = 0;
digitalWrite(CS, LOW); // CSn low: start of transfer
delayMicroseconds(1);
digitalWrite(CLK, LOW); // CLK goes low: start clocking
angle = 0;
for (int x = 0; x < 10; x++) // clock signal, 16 transitions, output to clock pin
digitalWrite(CLK, HIGH); //clock goes high
angle = ((angle << 1) | digitalRead(SerD));// left-shift summing variable, add pin value
digitalWrite(CS, HIGH); // CSn high
return uint16_t((angle * 45) >> 7) ;
void motorMotion(int motor_num, long actualPos,long targetPos)
// here i am using two while loop to run please check the logic
while (actualPos != targetPos)
if (motor_num ==1)
// actualPos= sen1();
// actualPos= sen2();
int Tol=2;
// 2 degree no order to move will be sent to the motor if the target is close to the actual position
// this prevents short jittering moves
int gap;
int pwm=50;
// security concern : targetPos has to be within the mechanically authorized range
targetPos=constrain(targetPos,potMini+brakingDistance,potMaxi-brakingDistance);
gap=abs(targetPos-actualPos);
if (gap<= Tol)
if (motor_num==1)
Stop_1();
delay(20);
Stop_2();//too near to move: stop motor
delay(20);
// PID : calculates speed according to distance
pwm=25;
if (gap>17) pwm=50;
if (gap>26) pwm=75;
if (gap>35) pwm=100;
// pwm=map(pwm, 0, 255, 0, pwmMax); //adjust the value according to pwmMax for mechanical debugging purpose !
Serial3.println("Moving MOTOR"+String(motor_num)+" PWM:"+String(pwm)+" | APOS:"+String(actualPos)+" | GAP:"+String(gap)+" | TPOS:"+String(targetPos));
// if motor is outside from the range, send motor back to the limit !
// below condition is to check to rotation of motor if it is nearer to clockwise then rotate clockwise or else rotate anti clockiwise
// please check here
if ( ( ( (actualPos<potMini) || (actualPos<targetPos) )*1-( (actualPos>potMaxi) || (actualPos>targetPos) )*1)==1 )
if ( motor_num==1)
delay(20);
while (actualPos != targetPos){
Run_motor1(1,pwm);// motor 1 rotates in clk wise ( 1 inside the paramter indiactes forward dirn )
delay(20);
Run_motor2(1,pwm);// motor 2 rotates in clk wise ( 1 inside the paramter indiactes forward dirn )
if ( ( ( (actualPos<potMini) || (actualPos<targetPos) )*1-((actualPos>potMaxi) || (actualPos>targetPos))*1)==-1)
{ if ( motor_num==1)
delay(20);
Run_motor1(2,pwm);// motor 1 rotates in anticlk wise ( 2 inside the paramter indiactes revr dirn )
//actualPos= sen1();
//Run_motor2(2,pwm);
Run_motor2(2,pwm); // motor 2 rotates in anticlk wise ( 2 inside the paramter indiactes revr dirn )
Serial3.begin(115200);
pinMode(ClockPin, OUTPUT); // SCK
pinMode(CSnPin, OUTPUT); // CSn -- has to toggle high and low to signal chip to start data transfer
pinMode(InputPin, INPUT); // SDA
pinMode(ClockPin2, OUTPUT); // SCK
pinMode(CSnPin2, OUTPUT); // CSn -- has to toggle high and low to signal chip to start data transfer
pinMode(InputPin2, INPUT); // SDA
/// setup for vfds
Serial1.begin(19200); // slave 2
Serial2.begin(19200); // slave 1
pinMode(enablePin2, OUTPUT);
pinMode(enablePin1, OUTPUT);
delay(10);
digitalWrite(enablePin2, HIGH); // Always high as Master Writes data to Slave
digitalWrite(enablePin1, HIGH);
sensor1=GetSensorValue( CSnPin, ClockPin, InputPin);
sensor2=GetSensorValue( CSnPin2, ClockPin2, InputPin2);
Serial3.print("the angle from the motor 1 is ");
Serial3.println(sensor1);
delay (50);
Serial3.print("the angle from the motor 2 is ");
Serial3.println(sensor2);
