How to get static IP from esp32-cam?
Hello everyone. I am working with esp32-cam module. I use 2 or 3 time and then i cant connect this IP. From my point of view this IP is dynamic IP therefor i am able to use just 2 time. How to get static IP? What is your suggestion? Here is my code. Please advice me. Thanks. Regardly Farhad
#include "esp_camera.h"
#include <WiFi.h>
#include "esp_timer.h"
#include "img_converters.h"
#include "Arduino.h"
#include "FS.h"                 //--> SD Card ESP32
#include "SD_MMC.h"             //--> SD Card ESP32
#include "SPI.h"
#include "fb_gfx.h"
#include "soc/soc.h"            //--> disable brownout problems
#include "soc/rtc_cntl_reg.h"   //--> disable brownout problems
#include "esp_http_server.h"
/* ======================================== Select camera model */
// This project was tested with the AI Thinker Model, M5STACK PSRAM Model and M5STACK WITHOUT PSRAM
#define CAMERA_MODEL_AI_THINKER
//#define CAMERA_MODEL_M5STACK_PSRAM
//#define CAMERA_MODEL_M5STACK_WITHOUT_PSRAM
// Not tested with this model
//#define CAMERA_MODEL_WROVER_KIT
/* ======================================== GPIO of camera models */
#if defined(CAMERA_MODEL_WROVER_KIT)
  #define PWDN_GPIO_NUM    -1
  #define RESET_GPIO_NUM   -1
  #define XCLK_GPIO_NUM    21
  #define SIOD_GPIO_NUM    26
  #define SIOC_GPIO_NUM    27
  #define Y9_GPIO_NUM      35
  #define Y8_GPIO_NUM      34
  #define Y7_GPIO_NUM      39
  #define Y6_GPIO_NUM      36
  #define Y5_GPIO_NUM      19
  #define Y4_GPIO_NUM      18
  #define Y3_GPIO_NUM       5
  #define Y2_GPIO_NUM       4
  #define VSYNC_GPIO_NUM   25
  #define HREF_GPIO_NUM    23
  #define PCLK_GPIO_NUM    22
#elif defined(CAMERA_MODEL_M5STACK_PSRAM)
  #define RESET_GPIO_NUM    15
  #define XCLK_GPIO_NUM     27
  #define SIOD_GPIO_NUM     25
  #define SIOC_GPIO_NUM     23
  #define Y9_GPIO_NUM       19
  #define Y8_GPIO_NUM       36
  #define Y7_GPIO_NUM       18
  #define Y6_GPIO_NUM       39
  #define Y5_GPIO_NUM        5
  #define Y4_GPIO_NUM       34
  #define Y3_GPIO_NUM       35
  #define Y2_GPIO_NUM       32
  #define VSYNC_GPIO_NUM    22
  #define HREF_GPIO_NUM     26
  #define PCLK_GPIO_NUM     21
#elif defined(CAMERA_MODEL_M5STACK_WITHOUT_PSRAM)
  #define Y2_GPIO_NUM       17
#elif defined(CAMERA_MODEL_AI_THINKER)
  #define PWDN_GPIO_NUM     32
  #define XCLK_GPIO_NUM      0
  #define Y5_GPIO_NUM       21
  #define Y4_GPIO_NUM       19
  #define Y3_GPIO_NUM       18
  #define Y2_GPIO_NUM        5
#else
  #error "Camera model not selected"
#endif
/* ======================================== Replace with your network credentials */
const char* ssid = "Farhad";
const char* password = "08130873";
int tpic = 2; //--> variable for the process status of saving images to MicroSD card.
/* ======================================== variable to accommodate the results of reading text files from the MicroSD card. */
 * char txt_Text[10]; --> this variable to accommodate the results of reading text files from the MicroSD card
 * in the text file "IFNO.txt" will be written 1 to 999999999.
 * So the image file name is from IMG_000000001 to IMG_999999999.
 * So if the image file name has reached IMG_999999999, please move all image files to another storage, because after IMG_999999999 it will repeat to IMG_000000001.
char txt_Text[10];
int txt_Text_Count = 0;
typedef struct {
        httpd_req_t *req;
        size_t len;
} jpg_chunking_t;
#define PART_BOUNDARY "123456789000000000000987654321"
static const char* _STREAM_CONTENT_TYPE = "multipart/x-mixed-replace;boundary=" PART_BOUNDARY;
static const char* _STREAM_BOUNDARY = "\r\n--" PART_BOUNDARY "\r\n";
static const char* _STREAM_PART = "Content-Type: image/jpeg\r\nContent-Length: %u\r\n\r\n";
/* ======================================== Empty handle to esp_http_server */
httpd_handle_t index_httpd = NULL;
httpd_handle_t stream_httpd = NULL;
httpd_handle_t camera_httpd = NULL;
httpd_handle_t capture_httpd = NULL;
/* ======================================== HTML code for index / main page */
static const char PROGMEM INDEX_HTML[] = R"rawliteral(
<html>
  <head>
    <title>ESP32-CAM Stream Web Server with Take Picture and Save to MicroSD Card</title>
    <meta name="viewport" content="width=device-width, initial-scale=1">
    <style>
      body { font-family: Arial; text-align: center; margin:0px auto; padding-top: 30px;}
      /* ----------------------------------- Toggle Switch */
      .switch {
        position: relative;
        display: inline-block;
        width: 90px;
        height: 34px;
        top: 10px;
      .switch input {display:none;}
      .slider {
        position: absolute;
        cursor: pointer;
        top: 0;
        left: 0;
        right: 0;
        bottom: 0;
        background-color: #D3D3D3;
        -webkit-transition: .4s;
        transition: .4s;
        border-radius: 34px;
      .slider:before {
        position: absolute;
        content: "";
        height: 26px;
        width: 26px;
        left: 4px;
        bottom: 4px;
        background-color: #f7f7f7;
        transition: .4s;
        border-radius: 50%;
      input:checked + .slider {
        background-color: #5b9dd8;
      input:focus + .slider {
        box-shadow: 0 0 1px #2196F3;
      input:checked + .slider:before {
        -webkit-transform: translateX(26px);
        -ms-transform: translateX(26px);
        transform: translateX(55px);
      .slider:after {
        content:'OFF';
        color: white;
        display: block;
        position: absolute;
        transform: translate(-50%,-50%);
        top: 50%;
        left: 70%;
        font-size: 10px;
        font-family: Verdana, sans-serif;
      input:checked + .slider:after {
        left: 25%;
        content:'ON';
      /* ----------------------------------- button1 / Capture Button */
      .button1 {
        padding: 10px 20px;
        font-size: 14px;
        cursor: pointer;
        text-align: center;
        text-decoration: none;
        outline: none;
        color: #fff;
        background-color: #4CAF50;
        border: none;
        border-radius: 30px;
      .button1:hover {background-color: #3e8e41}
      .button1:active {
        transform: scale(0.9,0.9)
      .button1:disabled {
        opacity: 0.6;
        cursor: not-allowed;
        pointer-events: none;
      /* ----------------------------------- button2 / Stream Button */
      .button2 {
        padding: 10px 20px;
        font-size: 14px;
        cursor: pointer;
        text-align: center;
        outline: none;
        color: #fff;
        background-color: #935cfb;
        border: none;
      .button2:hover {background-color: #7c38fa}
      .button2:active {
      .button2:disabled {
        opacity: 0.6;
      /* ----------------------------------- Stream and Capture Viewer */
      img {
        width: auto ;
        max-width: 100% ;
        height: auto ;
    </style>
  </head>
  <body>
    <h3>ESP32-CAM Stream Web Server with Take Picture and Save to MicroSD Card</h3>
    <img src="" id="photo">
    <br><br>
    <span style="font-size:15;">LED Flash : &nbsp;</span>
    <label class="switch">
      <input type="checkbox" id="togLEDFlash" onclick="LEDFlash()">
      <div class="slider round"></div>
    </label>
    <br><br>
    <button class="button1" onclick="viewer('capture')" id="Cptr">Capture</button>
    <button class="button2" onclick="viewer('stream')" id="Strm">Stream</button>
    <br><br>
    <p id="st"></p>
    <script>
      /* ----------------------------------- Calls the video stream link and displays it */
      window.onload = document.getElementById("photo").src = window.location.href.slice(0, -1) + ":81/stream";
      document.getElementById("Cptr").disabled = false;
      document.getElementById("Strm").disabled = true;
      send_cmd("stream");
      /* ----------------------------------- Information text to be displayed when saving image to MicroSD card */
      var myTmr;
      var itext = 31;
      let text = "Saving pictures to MicroSD card...";
      var valTaTephotostate = 10;
      /* :::::::::::::::::::::::::::::::::::::::::::::::: Function to send commands to turn on or turn off the LED Flash */
      function LEDFlash() {
        var tgLEDFlash = document.getElementById("togLEDFlash");
        var tgState;
        if (tgLEDFlash.checked == true) tgState = 1;
        if (tgLEDFlash.checked == false) tgState = 0;
        send_cmd(tgState);
      /* :::::::::::::::::::::::::::::::::::::::::::::::: Function to choose to show streaming video or captured image */
      function viewer(x) {
        if (x == "capture") {
          document.getElementById("Cptr").disabled = true;
          send_cmd(x);
          window.stop();
          document.getElementById("photo").src = window.location.href.slice(0, -1) + ":81/capture";
          textSaveToMicroSD();
          start_timer();
        if (x == "stream") {
          window.location.reload();
      /* :::::::::::::::::::::::::::::::::::::::::::::::: Function for sending commands */
      function send_cmd(cmds) {
        var xhr = new XMLHttpRequest();
        xhr.open("GET", "/action?go=" + cmds, true);
        xhr.send();
      /* :::::::::::::::::::::::::::::::::::::::::::::::: Start and stop the timer */
      function start_timer() {
        myTmr = setInterval(myTimer, 1000)
      function stop_timer() {
        clearInterval(myTmr)
      /* :::::::::::::::::::::::::::::::::::::::::::::::: Timer to check image saving process to MicroSD card */
      function myTimer() {
        getTakephotostate();
        if (valTaTephotostate == 0) {
          document.getElementById("st").innerHTML = "";
          document.getElementById("Strm").disabled = false;
          stop_timer();
      /* :::::::::::::::::::::::::::::::::::::::::::::::: Function to display text information when saving image to MicroSD card */
      function textSaveToMicroSD() {
        itext++;
        if(itext>34) itext = 31;
        let result = text.substring(0, itext);
        document.getElementById("st").innerHTML = result;
      /* :::::::::::::::::::::::::::::::::::::::::::::::: Function to receive the process status of saving images to MicroSD card */
      function getTakephotostate() {
        var xhttp = new XMLHttpRequest();
        xhttp.onreadystatechange = function() {
          if (this.readyState == 4 && this.status == 200) {
            valTaTephotostate = this.responseText;
        xhttp.open("GET", "/takephotostate", true);
        xhttp.send();
    </script>
  </body>
</html>
)rawliteral";
/* ____________________________ Index handler function to be called during GET or uri request */
static esp_err_t index_handler(httpd_req_t *req){
  httpd_resp_set_type(req, "text/html");
  return httpd_resp_send(req, (const char *)INDEX_HTML, strlen(INDEX_HTML));
/* ____________________________ */
/* ____________________________ jpg_encode_stream handler function to be called during GET or uri request */
static size_t jpg_encode_stream(void * arg, size_t index, const void* data, size_t len){
    jpg_chunking_t *j = (jpg_chunking_t *)arg;
    if(!index){
        j->len = 0;
    if(httpd_resp_send_chunk(j->req, (const char *)data, len) != ESP_OK){
        return 0;
    j->len += len;
    return len;
/* ____________________________ capture handler function to be called during GET or uri request */
static esp_err_t capture_handler(httpd_req_t *req){
  tpic = 1;
  bool ledflashLastState = false;
  camera_fb_t * fb = NULL;
  esp_err_t res = ESP_OK;
  int64_t fr_start = esp_timer_get_time();
  fb = esp_camera_fb_get();
  if (!fb) {
      Serial.println("Camera capture failed");
      httpd_resp_send_500(req);
      return ESP_FAIL;
  /* ---------------------------------------- If the LED Flash is on, the LED Flash will be turned off so as not to interfere with the process of saving images to the MicroSD card. */
  /* If the saving process is complete, the LED Flash will be turned on again. */
  if (digitalRead(4) == HIGH) {
    ledflashLastState = true;
    digitalWrite(4, LOW);
  delay(1500);
  /* ---------------------------------------- The process of saving the image to the MicroSD card. */
  readFile(SD_MMC, "/FN/IFNO.txt");
  int nI = atoi(txt_Text);
  nI++;
  if (nI == 999999999) nI = 0;
  char nI_str[10];
  sprintf(nI_str, "%09d", nI);
  char pathIMG[20];
  strcat(pathIMG, "/IMG_");
  strcat(pathIMG, nI_str);
  strcat(pathIMG, ".jpg");
  fs::FS &fs = SD_MMC;
  Serial.printf("Picture file name: %s\n", pathIMG);
  File file = fs.open(pathIMG, FILE_WRITE);
  if(!file){
    Serial.println("Failed to open file in writing mode");
  else {
    file.write(fb->buf, fb->len); // payload (image), payload length
    Serial.printf("Saved file to path: %s\n", pathIMG);
  file.close();
  char rewrite_nI[10];
  itoa(nI, rewrite_nI, 10);
  writeFile(SD_MMC, "/FN/IFNO.txt", rewrite_nI);
  if (ledflashLastState == true) digitalWrite(4, HIGH);
  httpd_resp_set_type(req, "image/jpeg");
  httpd_resp_set_hdr(req, "Content-Disposition", "inline; filename=capture.jpg");
  httpd_resp_set_hdr(req, "Access-Control-Allow-Origin", "*");
  size_t out_len, out_width, out_height;
  uint8_t * out_buf;
  bool s;
  bool detected = false;
  int face_id = 0;
  if(true){
      size_t fb_len = 0;
      if(fb->format == PIXFORMAT_JPEG){
          fb_len = fb->len;
          res = httpd_resp_send(req, (const char *)fb->buf, fb->len);
          jpg_chunking_t jchunk = {req, 0};
          res = frame2jpg_cb(fb, 80, jpg_encode_stream, &jchunk)?ESP_OK:ESP_FAIL;
          httpd_resp_send_chunk(req, NULL, 0);
          fb_len = jchunk.len;
      esp_camera_fb_return(fb);
      int64_t fr_end = esp_timer_get_time();
      Serial.printf("JPG: %uB %ums\n", (uint32_t)(fb_len), (uint32_t)((fr_end - fr_start)/1000));
      tpic = 0;
      return res;
/* ____________________________ stream handler function to be called during GET or uri request. */
static esp_err_t stream_handler(httpd_req_t *req){
  size_t _jpg_buf_len = 0;
  uint8_t * _jpg_buf = NULL;
  char * part_buf[64];
  res = httpd_resp_set_type(req, _STREAM_CONTENT_TYPE);
  if(res != ESP_OK){
    return res;
  while(true){
    if (!fb) {
      res = ESP_FAIL;
      if(fb->width > 400){
        if(fb->format != PIXFORMAT_JPEG){
          bool jpeg_converted = frame2jpg(fb, 80, &_jpg_buf, &_jpg_buf_len);
          fb = NULL;
          if(!jpeg_converted){
            Serial.println("JPEG compression failed");
            res = ESP_FAIL;
          _jpg_buf_len = fb->len;
          _jpg_buf = fb->buf;
    if(res == ESP_OK){
      size_t hlen = snprintf((char *)part_buf, 64, _STREAM_PART, _jpg_buf_len);
      res = httpd_resp_send_chunk(req, (const char *)part_buf, hlen);
    if(res == ESP_OK){
      res = httpd_resp_send_chunk(req, (const char *)_jpg_buf, _jpg_buf_len);
    if(res == ESP_OK){
      res = httpd_resp_send_chunk(req, _STREAM_BOUNDARY, strlen(_STREAM_BOUNDARY));
    if(fb){
      fb = NULL;
      _jpg_buf = NULL;
    } else if(_jpg_buf){
      free(_jpg_buf);
      _jpg_buf = NULL;
    if(res != ESP_OK){
    //Serial.printf("MJPG: %uB\n",(uint32_t)(_jpg_buf_len));
  return res;
/* ____________________________ cmd handler function to be called during GET or uri request. */
static esp_err_t cmd_handler(httpd_req_t *req){
  char*  buf;
  size_t buf_len;
  char variable[32] = {0,};
  buf_len = httpd_req_get_url_query_len(req) + 1;
  if (buf_len > 1) {
    buf = (char*)malloc(buf_len);
    if(!buf){
      return ESP_FAIL;
    if (httpd_req_get_url_query_str(req, buf, buf_len) == ESP_OK) {
      if (httpd_query_key_value(buf, "go", variable, sizeof(variable)) == ESP_OK) {
        free(buf);
        httpd_resp_send_404(req);
        return ESP_FAIL;
      free(buf);
      return ESP_FAIL;
    free(buf);
    return ESP_FAIL;
  int res = 0;
  if(!strcmp(variable, "1")) {
    Serial.println("LED Flash ON");
  else if(!strcmp(variable, "0")) {
    Serial.println("LED Flash OFF");
  else if(!strcmp(variable, "capture")) {
    Serial.println("capture");
  else if(!strcmp(variable, "stream")) {
    Serial.println("stream");
  else {
    res = -1;
  if(res){
    return httpd_resp_send_500(req);
  return httpd_resp_send(req, NULL, 0);
/* ____________________________ takephotostate handler function to be called during GET or uri request. */
static esp_err_t takephotostate_handler(httpd_req_t *req){
  char tpic_buf[12];
  httpd_resp_send(req, itoa(tpic,tpic_buf,10), HTTPD_RESP_USE_STRLEN);
  return ESP_OK;
/* ____________________________ Subroutine for starting the web server / startCameraServer. */
void startCameraServer(){
  httpd_config_t config = HTTPD_DEFAULT_CONFIG();
  config.server_port = 80;
  httpd_uri_t index_uri = {
    .uri       = "/",
    .method    = HTTP_GET,
    .handler   = index_handler,
    .user_ctx  = NULL
  httpd_uri_t cmd_uri = {
    .uri       = "/action",
    .method    = HTTP_GET,
    .handler   = cmd_handler,
    .user_ctx  = NULL
  httpd_uri_t takephotostate_uri = {
    .uri       = "/takephotostate",
    .method    = HTTP_GET,
    .handler   = takephotostate_handler,
    .user_ctx  = NULL
  httpd_uri_t stream_uri = {
    .uri       = "/stream",
    .method    = HTTP_GET,
    .handler   = stream_handler,
    .user_ctx  = NULL
  httpd_uri_t capture_uri = {
    .uri       = "/capture",
    .method    = HTTP_GET,
    .handler   = capture_handler,
    .user_ctx  = NULL
  if (httpd_start(&index_httpd, &config) == ESP_OK) {
      httpd_register_uri_handler(index_httpd, &index_uri);
      httpd_register_uri_handler(index_httpd, &cmd_uri);
      httpd_register_uri_handler(index_httpd, &takephotostate_uri);
  config.server_port += 1;
  config.ctrl_port += 1;
  if (httpd_start(&stream_httpd, &config) == ESP_OK) {
      httpd_register_uri_handler(stream_httpd, &stream_uri);
      httpd_register_uri_handler(stream_httpd, &capture_uri);
  Serial.println("Camera Server started successfully");
  Serial.print("Camera Stream Ready! Go to: http://");
  Serial.print(WiFi.localIP());
/* ____________________________ Subroutine to read text in a text file on a MicroSD card. */
void readFile(fs::FS &fs, const char * path){
  Serial.printf("Reading file: %s\n", path);
  File file = fs.open(path);
  if(!file){
      Serial.println("Failed to open file for reading");
      return;
  memset(txt_Text, 0, sizeof txt_Text);
  Serial.print("Read from file: ");
  while(file.available()){
      //Serial.write(file.read());
      char inChar = file.read();
      txt_Text[txt_Text_Count] = inChar;
      txt_Text_Count++;
  file.close();
  Serial.println(txt_Text);
  txt_Text_Count = 0;
/* ____________________________ Subroutine for writing text to a text file on the MicroSD card. */
void writeFile(fs::FS &fs, const char * path, const char * message){
  Serial.printf("Writing file: %s\n", path);
  File file = fs.open(path, FILE_WRITE);
  if(!file){
      Serial.println("Failed to open file for writing");
      return;
  if(file.print(message)){
      Serial.println("File written");
      Serial.println("Write failed");
  file.close();
/* ____________________________ VOID SETUP() */
  WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0); //--> disable brownout detector
  Serial.setDebugOutput(false);
  /* ---------------------------------------- Camera configuration. */
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  if(psramFound()){
    config.frame_size = FRAMESIZE_UXGA; //UXGA;
     * From the results of the tests I did:
     * - config.jpeg_quality = 10; --> the captured images are good for indoors or in low light conditions.
     *   But the image file is "corrupted" for capturing images outdoors or in bright light conditions.
     * - config.jpeg_quality = 20; --> there is no "corrupt" of image files for image capture both indoors and outdoors.
     * I don't know if this only happens to my ESP32 Cam module. Please test the settings above.
     * From source: https://randomnerdtutorials.com/esp32-cam-ov2640-camera-settings/ , The image quality (jpeg_quality) can be a number between 0 and 63.
     * A lower number means a higher quality. However, very low numbers for image quality,
     * specially at higher resolution can make the ESP32-CAM to crash or it may not be able to take the photos properly.
    config.fb_count = 2;
    config.frame_size = FRAMESIZE_SVGA;
    config.jpeg_quality = 12;
    config.fb_count = 1;
  /* ---------------------------------------- Camera init. */
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    return;
  /* ---------------------------------------- Start accessing and checking SD card. */
   * The "SD_MMC.h" library supports 4-bit and 1-bit modes for accessing MicroSD cards.
   * The 4-bit mode uses GPIO 2, 4, 12, 13, 14, and 15. That means the LED Flash on Borad on the ESP32 Cam cannot be used, because the LED Flash uses GPIO_4.
   * The 1-bit mode does not use GPIO 4, 12 and 13 (based on some references I read).
   * So GPIO 4, 12 and 13 can be used for other purposes.
   * But in the tests that I tried on the ESP32 Cam that I have (ESP32-CAM AI-Thinker), it seems that GPIO 4, 12 and 13 are still being used.
   * However, if you use 1-bit mode, GPIO 4, 12 and 13 can still be used for other purposes with a few programming tricks.
   * Unlike the 4-bit mode, where GPIO 4, 12 and 13 cannot be used for other purposes at all.
   * I CONFIRM THE ABOVE DESCRIPTION IS BASED ON TESTING I HAVE DONE ON THE ESP32 CAM I HAVE.
   * I might be wrong. Please leave a comment about it in the comments section of this video project (on Youtube).
   * So in this project I'm using 1-bit mode.
  /* ::::::: 4-bit mode */
//  Serial.println("Start accessing SD Card 4-bit mode");
//  if(!SD_MMC.begin()){
//    Serial.println("SD Card Mount Failed");
//    return;
//  Serial.println("Started accessing SD Card 4-bit mode successfully");
  /* ::::::: 1-bit mode */
  Serial.println("Starting SD Card");
  pinMode(13, INPUT_PULLUP); //--> This is done to resolve an "error" in 1-bit mode when SD_MMC.begin("/sdcard", true). Reference: https://github.com/espressif/arduino-esp32/issues/4680
  Serial.println("Start accessing SD Card 1-bit mode");
  if(!SD_MMC.begin("/sdcard", true)){
    return;
  Serial.println("Started accessing SD Card 1-bit mode successfully");
  pinMode(13, INPUT_PULLDOWN);
  /* ---------------------------------------- Checking SD card type */
  uint8_t cardType = SD_MMC.cardType();
  if(cardType == CARD_NONE){
    Serial.println("No SD Card attached");
    return;
  pinMode(4, OUTPUT); //--> LED Flash on Board
  /* ---------------------------------------- Wi-Fi connection */
  WiFi.begin(ssid, password);
    delay(250);
    delay(250);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  startCameraServer(); //--> Start camera web server
/* ____________________________ VOID LOOP() */
  delay(1);
https://techtutorialsx.com/2020/04/21/esp32-arduino-set-static-ip-address/
You could also reserve the ip address for your device in your router.
I think that way is preferable. The ESP would continue to use DHCP. But, the DHCP server in the router would always provide the same IP address.
