How to get the best low power while in sleep mode
My goal is as said, run my system at the lowest power I can.
I have an esp32, a dc-dc boost converter(from 3V battery to 3.3V) and some sensors.
These are 2 schematics I am considering:
  1. Powering the esp32 from the 3V battery always and the sensors from the 3.3V - is it possible and correct to do so? Using an efficient dc-dc converter what magnitude of current do they take with enable off?
Screenshot 2022-01-18 223011
  1. Switching between the power sources - when in active mode - esp32 is on the 3.3V, and when in sleep mode esp32 is on the 3V battery.
    Which is better? Or there is a simpler alternative?
    Thanks!
The datasheet has the answer.
Ok, and what about the circuits?
The second circuit adds an inverter that consumes power. Just collect data and add the currents.
The inverter doesn't have to be there, I intend to use a P-fet instead.
I did not understand, will the circuit work well? Can I remove the diode? because it lowers the voltage that goes to ESP32.
A P FET. Will that match with the EN level/logic?
Use a Schottky diode. They have a low voltage loss.
If it works or not depends on You finding FETs that work with the low Vgs availabe.
Thanks for the reply, I am worried about using a Schottky diode due to its change of voltage according to current and even the lowest drop(0.3?) could be a lot.
I replaced the schematic with this one:
What do you say?
To be clear it divides into 2 states:
  1. EN on - ESP32 and sensors get 3.3V off the dc-dc converter, battery goes only to the converter.
  2. EN off - ESP32 gets voltage off the battery only, converter and sensors are disconnected.
    Thanks!
Make a test without the esp32. Use a toggle switch sending the EN signal. Use simple LEDs + resistor as loads to simulate the esp32 and the sensors.
