How to go through each LED pattern 5 times - Arduino Assignment
I have 3 LEDS that go through 3 different patterns/cases of lighting up. I need the LEDS to go through each pattern 5 times each before going on to the next pattern.
My lecturer says that I need to change this part of my code
  state++;
  state=state % 3;
  count = count + 1;
  count = count % 5;
Here's the full code
const int Led1 = 13; // the number of the LED pin
const int Led2 = 12; // the number of the LED pin
const int Led3 = 11; // the number of the LED pin
const int ms = 300; // the duration of the led blink in milli seconds
int state = 0;
int count = 0;
int counter = 5;
// the setup function runs once when you press reset or power the board
  // initialize digital pin LED_BUILTIN as an output.
  pinMode(Led1, OUTPUT);
  pinMode(Led2, OUTPUT);
  pinMode(Led3, OUTPUT);
void together() {
 digitalWrite(Led1, HIGH);   // turn the LED on (HIGH is the voltage level)
  digitalWrite(Led2, HIGH);
  digitalWrite(Led3, HIGH);
  delay(ms);                       // wait for a second
  digitalWrite(Led1, LOW);    // turn the LED off by making the voltage LOW
  digitalWrite(Led2, LOW);
  digitalWrite(Led3, LOW);
void traffic() {
void flashing() {
  digitalWrite(Led1, LOW);   // turn the LED on (HIGH is the voltage level)
// the loop function runs over and over again forever
  state++;
  state=state % 3;
  count = count + 1;
  count = count % 5;
  Serial.print("state= ");
  Serial.print(state);
  Serial.print("  count= ");
  Serial.println(count);
  switch (state) {
    case 0:
      together();
    case 1:
      traffic();
    case 2:
      flashing();
I've attached the full Arduino file below as well. You'll be a huge help to assist me in getting this right!
Leds2 Goodwin-NS.ino (4.3 KB)
Whenever count equals 5 then increment the state and set count back to 0.
Can You turn the poetry description into a drawing showing what You want. Tell what's the happening now?
int state = 0;
int count = 0;
int counter = 5;
void together() {
void traffic() {
void flashing() {
  state++;
  state=state % 3;
  count = count + 1;
  count = count % 5;
  switch (state) {
    case 0:
for (int i = 0; i < 5; i++){
      together();
    case 1:
      traffic();
    case 2:
      flashing();
like this? Does this do what you're after?
