How to have webclient and webserver works together?
I wanted to send my data to the server and at the same time, get data from another server?
I try this code but keep getting connection failed. I am able to get connection for the server but not the client.
  Web Server
 A simple web server that shows the value of the analog input pins.
 using an Arduino Wiznet Ethernet shield.
 Circuit:
 * Ethernet shield attached to pins 10, 11, 12, 13
 * Analog inputs attached to pins A0 through A5 (optional)
 created 18 Dec 2009
 by David A. Mellis
 modified 9 Apr 2012
 by Tom Igoe
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
IPAddress ip(192,168,123,3); // ip in lan
IPAddress gateway(192,168,1,1); // internet access via router
IPAddress subnet(255,255,255,0); //subnet mask
IPAddress myserver(192,168,123,4);
EthernetServer server(80); //server port
EthernetClient client;
String readString;
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
  pinMode(4, OUTPUT); //pin selected to control
  Ethernet.begin(mac, ip, subnet, gateway);
  server.begin();
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  // start the Ethernet connection and the server:
  Serial.print("server is at ");
  Serial.println(Ethernet.localIP());
  // listen for incoming clients
  if (client) {
    Serial.println("new client");
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    sendGET();
    // before connection
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        Serial.write(c);
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
          client.println("Content-Type: text/html");
          client.println("Connection: close");  // the connection will be closed after completion of the response
	  client.println("Refresh: 5");  // refresh the page automatically every 5 sec
          client.println();
          client.println("<!DOCTYPE HTML>");
          client.println("<html>");
          // output the value of each analog input pin
          for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
            int sensorReading = analogRead(analogChannel);
            client.print("analog input ");
            client.print(analogChannel);
            client.print(" is ");
            client.print(sensorReading);
            client.println("
          client.println("</html>");
        if (c == '\n') {
          // you're starting a new line
        else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
    Serial.println("client disconnected");
void sendGET() //client function to send/receie GET request data.
  if (client.connect(myserver, 80)) {
    Serial.println("connected");
    client.println("GET /~shb/arduino.txt HTTP/1.0");
    client.println();
  else {
    Serial.println("connection failed");
  while(client.connected() && !client.available()) delay(1); //waits for data
  while (client.connected() || client.available()) { //connected or data available
    Serial.print(c);
  Serial.println("disconnecting.");
  Serial.println("==================");
  client.stop();
Is the code have some errors that I made?
Thanks in advance.
I don't seem to be able to use the GET method here. It keeps getting connection failed. Is it I use it wrongly?
    client.println();
  else {
    Serial.print(c);
  client.stop();
Your Ethernet.begin call parameters are not correct.
// replace this
// with this
  Ethernet.begin(mac, ip, gateway, gateway, subnet);
The first gateway parameter is actually a placeholder for a dns server ip. Some routers like mine will perform dns, but others won't. If you are not resolving any domain names, it doesn't matter if it won't.
Combined client/server test code:
//zoomkat 10-02-14, combined client and server
//simple button GET with iframe code
//for use with IDE 1.0
//open serial monitor and send a g to test client GET and
//see what the arduino client/server receives
//web page buttons make pins high/low
//use the ' in html instead of " to prevent having to escape the "
//address will look like http://192.168.1.102:84 when submited
//for use with W5100 based ethernet shields
#include <SPI.h>
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //assign arduino mac address
byte ip[] = {192, 168, 1, 102 }; // ip in lan assigned to arduino
byte gateway[] = {192, 168, 1, 1 }; // internet access via router
byte subnet[] = {255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port arduino server will use
char serverName[] = "checkip.dyndns.com"; // (DNS) dyndns web page server
//byte serverName[] = { 208, 104, 2, 86 }; // (IP) zoomkat web page server IP address
String readString; //used by server to capture GET request
void setup(){
  pinMode(5, OUTPUT); //pin selected to control
  pinMode(6, OUTPUT); //pin selected to control
  pinMode(7, OUTPUT); //pin selected to control
  pinMode(8, OUTPUT); //pin selected to control
  //pinMode(5, OUTPUT); //pin 5 selected to control
  Ethernet.begin(mac,ip,gateway,gateway,subnet);
  server.begin();
  Serial.println(F("server/client 1.0 test 9/02/14")); // keep track of what is loaded
  Serial.println(F("Send a g in serial monitor to test client")); // what to do to test client
void loop(){
  // check for serial input
  if (Serial.available() > 0)
    byte inChar;
    inChar = Serial.read();
    if(inChar == 'g')
      sendGET(); // call client sendGET function
  if (client) {
        //read char by char HTTP request
        if (readString.length() < 100) {
          //store characters to string
          readString += c;
          //Serial.print(c);
        //if HTTP request has ended
        if (c == '\n') {
          Serial.print(readString); //print to serial monitor for debuging
            //now output HTML data header
          if(readString.indexOf('?') >=0) { //don't send new page
            client.println(F("HTTP/1.1 204 Zoomkat"));
            client.println();
            client.println();
          else {
            client.println(F("HTTP/1.1 200 OK")); //send new page on browser request
            client.println(F("Content-Type: text/html"));
            client.println();
            client.println(F("<HTML>"));
            client.println(F("<HEAD>"));
            client.println(F("<TITLE>Arduino GET test page</TITLE>"));
            client.println(F("</HEAD>"));
            client.println(F("<BODY>"));
            client.println(F("<H1>Zoomkat's simple Arduino 1.0 button</H1>"));
            // DIY buttons
            client.println(F("Pin5"));
            client.println(F("<a href=/?on2 target=inlineframe>ON</a>"));
            client.println(F("<a href=/?off3 target=inlineframe>OFF</a>
            client.println(F("Pin6"));
            client.println(F("<a href=/?on4 target=inlineframe>ON</a>"));
            client.println(F("<a href=/?off5 target=inlineframe>OFF</a>
            client.println(F("Pin7"));
            client.println(F("<a href=/?on6 target=inlineframe>ON</a>"));
            client.println(F("<a href=/?off7 target=inlineframe>OFF</a>
            client.println(F("Pin8"));
            client.println(F("<a href=/?on8 target=inlineframe>ON</a>"));
            client.println(F("<a href=/?off9 target=inlineframe>OFF</a>
            client.println(F("Pins"));
            client.println(F("&nbsp;<a href=/?off2468 target=inlineframe>ALL ON</a>"));
            client.println(F("&nbsp;<a href=/?off3579 target=inlineframe>ALL OFF</a>"));
            client.println(F("<IFRAME name=inlineframe style='display:none'>"));
            client.println(F("</IFRAME>"));
            client.println(F("</BODY>"));
            client.println(F("</HTML>"));
          delay(1);
          //stopping client
          client.stop();
          ///////////////////// control arduino pin
          if(readString.indexOf('2') >0)//checks for 2
            digitalWrite(5, HIGH);    // set pin 5 high
            Serial.println(F("Led 5 On"));
          if(readString.indexOf('3') >0)//checks for 3
            digitalWrite(5, LOW);    // set pin 5 low
            Serial.println(F("Led 5 Off"));
          if(readString.indexOf('4') >0)//checks for 4
            digitalWrite(6, HIGH);    // set pin 6 high
            Serial.println(F("Led 6 On"));
          if(readString.indexOf('5') >0)//checks for 5
            digitalWrite(6, LOW);    // set pin 6 low
            Serial.println(F("Led 6 Off"));
          if(readString.indexOf('6') >0)//checks for 6
            digitalWrite(7, HIGH);    // set pin 7 high
            Serial.println(F("Led 7 On"));
          if(readString.indexOf('7') >0)//checks for 7
            digitalWrite(7, LOW);    // set pin 7 low
            Serial.println(F("Led 7 Off"));
          if(readString.indexOf('8') >0)//checks for 8
            digitalWrite(8, HIGH);    // set pin 8 high
            Serial.println(F("Led 8 On"));
          if(readString.indexOf('9') >0)//checks for 9
            digitalWrite(8, LOW);    // set pin 8 low
            Serial.println(F("Led 8 Off"));
          //clearing string for next read
          readString="";
void sendGET() //client function to send and receive GET data from external server.
  if (client.connect(serverName, 80)) {
    Serial.println(F("connected"));
    client.println(F("GET / HTTP/1.1"));
    client.println(F("Host: checkip.dyndns.com"));
    client.println(F("Connection: close"));
    client.println();
  else {
    Serial.println(F("connection failed"));
    char c = client.read(); //gets byte from ethernet buffer
    readString += c; //places captured byte in readString
  //Serial.println();
  client.stop(); //stop client
  Serial.println(F("client disconnected."));
  Serial.println(F("Data from server captured in readString:"));
  Serial.print(readString); //prints readString to serial monitor
  Serial.println(F("End of readString"));
  Serial.println(F("=================="));
  readString=""; //clear readString variable
Thanks a lot for your help
Hello Zoomcat,
I am using enc28j60 Ethernet module. Will your code work with UIPEthernet libray?
Regards,
Hemant
