Well, for starters, there is only one port available and I'm not allowed to use batteries, so I'm not sure if the two microcontroller idea would even be feasible.
The first sketch which is the camera running is right here:
// This sketch modifies the example: ArduCAM_Mini_2MP_Plus_Multi_Capture2SD
#include <Wire.h>
#include <ArduCAM.h>
#include <SPI.h>
#include <SD.h>
#include "memorysaver.h"
//This demo can only work on OV5640_MINI_5MP_PLUS or OV5642_MINI_5MP_PLUS platform.
#if !(defined (OV2640_MINI_2MP_PLUS))
#error Please select the hardware platform and camera module in the ../libraries/ArduCAM/memorysaver.h file
#endif
#define FRAMES_NUM 0x06
// set pin 7 as the slave select for the digital pot:
const int CS = 7;
//ETCG Note -- Modify this for what your shield/module for the SD Card
#define SD_CS 10
bool is_header = false;
int total_time = 0;
#if defined (OV2640_MINI_2MP_PLUS)
ArduCAM myCAM( OV2640, CS );
#endif
uint8_t read_fifo_burst(ArduCAM myCAM);
//ETCG Note -- RTC/ Real Time Clock Code
#include <DS3231.h>
DS3231 rtc(SDA, SCL);
rtc.begin();
uint8_t vid, pid;
uint8_t temp;
#if defined(SAM3X8E)
Wire1.begin();
#else
Wire.begin();
#endif
Serial.println(F("ArduCAM Start!"));
// set the CS as an output:
pinMode(CS, OUTPUT);
digitalWrite(CS, HIGH);
// initialize SPI:
SPI.begin();
//Reset the CPLD
myCAM.write_reg(0x07, 0x80);
delay(100);
myCAM.write_reg(0x07, 0x00);
delay(100);
while (1) {
//Check if the ArduCAM SPI bus is OK
myCAM.write_reg(ARDUCHIP_TEST1, 0x55);
temp = myCAM.read_reg(ARDUCHIP_TEST1);
if (temp != 0x55)
Serial.println(F("SPI interface Error!"));
delay(1000); continue;
Serial.println(F("SPI interface OK.")); break;
while (1) {
//Check if the camera module type is OV2640
myCAM.wrSensorReg8_8(0xff, 0x01);
myCAM.rdSensorReg8_8(OV2640_CHIPID_HIGH, &vid);
myCAM.rdSensorReg8_8(OV2640_CHIPID_LOW, &pid);
if ((vid != 0x26 ) && (( pid != 0x41 ) || ( pid != 0x42 ))) {
Serial.println(F("ACK CMD Can't find OV2640 module!"));
else {
Serial.println(F("ACK CMD OV2640 detected.")); break;
#endif
//Initialize SD Card
while (!SD.begin(SD_CS))
Serial.println(F("SD Card Error!")); delay(1000);
Serial.println(F("SD Card detected."));
//Change to JPEG capture mode and initialize the OV5640 module
myCAM.set_format(JPEG);
myCAM.InitCAM();
myCAM.clear_fifo_flag();
myCAM.write_reg(ARDUCHIP_FRAMES, FRAMES_NUM);
unsigned long start = millis ();
while(millis () - start <= 660000) { // for 11 minutes
myCAM.flush_fifo();
myCAM.OV2640_set_JPEG_size(OV2640_1600x1200);
#endif
//Start capture
myCAM.start_capture();
Serial.println(F("start capture."));
total_time = millis();
while ( !myCAM.get_bit(ARDUCHIP_TRIG, CAP_DONE_MASK));
Serial.println(F("CAM Capture Done."));
total_time = millis() - total_time;
Serial.print(F("capture total_time used (in miliseconds):"));
Serial.println(total_time, DEC);
read_fifo_burst(myCAM);
Serial.print(F("save capture total_time used (in miliseconds):"));
//Clear the capture done flag
delay(5000);
void loop(){
//empty
uint8_t temp = 0, temp_last = 0;
uint32_t length = 0;
static int i = 0;
static long k = 0;
char str[16];
File outFile;
byte buf[256];
length = myCAM.read_fifo_length();
Serial.print(F("The fifo length is :"));
Serial.println(length, DEC);
if (length >= MAX_FIFO_SIZE) //8M
Serial.println("Over size.");
return 0;
if (length == 0 ) //0 kb
Serial.println(F("Size is 0."));
return 0;
myCAM.CS_LOW();
myCAM.set_fifo_burst();//Set fifo burst mode
i = 0;
while ( length-- )
temp_last = temp;
temp = SPI.transfer(0x00);
//Read JPEG data from FIFO
if ( (temp == 0xD9) && (temp_last == 0xFF) ) //If find the end ,break while,
buf[i++] = temp; //save the last 0XD9
//Write the remain bytes in the buffer
myCAM.CS_HIGH();
outFile.write(buf, i);
//Close the file
outFile.close();
Serial.println(F("OK"));
is_header = false;
myCAM.CS_LOW();
i = 0;
if (is_header == true)
//Write image data to buffer if not full
if (i < 256)
buf[i++] = temp;
//Write 256 bytes image data to file
myCAM.CS_HIGH();
outFile.write(buf, 256);
i = 0;
buf[i++] = temp;
myCAM.CS_LOW();
else if ((temp == 0xD8) & (temp_last == 0xFF))
is_header = true;
myCAM.CS_HIGH();
//ETCG Note -- Create Filename
long timeStamp = rtc.getUnixTime(rtc.getTime());
timeStamp = timeStamp - 1600000000;
Serial.println(timeStamp);
String fileName = String(timeStamp) + ".jpg";
Serial.println(fileName);
//Open the new file
outFile = SD.open(fileName, O_WRITE | O_CREAT | O_TRUNC);
if (! outFile)
Serial.println(F("File open failed"));
while (1);
myCAM.CS_LOW();
buf[i++] = temp_last;
buf[i++] = temp;
myCAM.CS_HIGH();
return 1;
The second piece of code is the servo and lights turning on:
#include <Servo.h>
Servo servo;
int LEDs_pin = 8;
servo.attach(9);
pinMode(LEDs_pin, OUTPUT);
digitalWrite(LEDs_pin, HIGH);
for(int i=0;i<180; i++){
servo.write(i);
delay(7);
for(int i=180; i>0; i--){
servo.write(i);
delay(7);
I had no idea you could run one code and then run another for 1ms without resetting either of the codes, so I'm sorry if my questions might have seemed stupid. Would any of you mind showing me an example of how to do this?
