how to make an oled arduino menu
hello guys
i want to do a project with arduino and an oled 128*32 so i want to do a menu with only one button and with only 3 pages but i'm stuck
i want to do first welcoming page that says press the button then second page ask to select a value using a potentiometer than the third page i want it to show that value and clock counter
i'm really stuck because i'm new to this
so if there anyone that could help and write me a simple code i would appreciate it a lot :-[ :-[
Post what code you have tried and where you are stuck.
here is my code every time i get on a screen i doesn't refresh the numbers i have to go back and enter again to see the new value
can you please help i can't finf anything on the internet helpful
#include <SPI.h>
#include<Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 32 // OLED display height, in pixels
#define startbutton 2
int currentscreen  ;
unsigned long time;
 float u;
 float z;
 float i;
 float f; // reading battery value
long int seconds=0;
int minutes=0;
int hours=0;
long int c;
  int a=1;
  float v;
  unsigned long previousmillis =0;
unsigned long interval = 1000;
volatile boolean startt ;
volatile boolean sb ;
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
void isr0() {
  sb= digitalRead(startbutton);
  startt = true;
  if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
    Serial.println(F("SSD1306 allocation failed"));
    for(;;);
  display.clearDisplay();
  delay(2000);
   attachInterrupt (digitalPinToInterrupt(2), isr0, CHANGE);
  display.setTextSize(1);
  display.setTextColor(WHITE);
screen1();
 screen2();
 u =analogRead(A1);
   f =analogRead(A0);
   z =(u/1023)*5; //voltage across resistor
   i = z/2.2 ; // current passing through resistor
  c= (hours*1000*a)+(minutes*1000*a)/60;
  v=(f/1023)*5 ; // battery voltage
  if (startt ){
    delay(200);
  switch (currentscreen){
    case 2:
   screen3();
   startt=false;
  case 3:
    screen4();
     startt=false;
   case 4:
    screen5();
     startt=false;
   case 5:
    screen2();
     startt=false;
void setClock()
 if(millis() > previousmillis + interval){
        previousmillis = millis();
        seconds++;}
if (seconds>59)
seconds=0;
minutes++;
if (minutes>59)
{hours++;
minutes=0;
if(hours>23)
hours=0;
void screen1(){
  display.setCursor(15,5);
 display.println("battery discharger");
 display.setCursor(15,20);
 display.println("by SKANDER BELHAJ");
display.display();
 delay (4000);
 currentscreen=1;
void screen2() {
  display.println("PLACE BATTERY ");
  display.println("AND PRESS START ");
  display.display();
  currentscreen=2;
void screen3 (){
  display.setCursor(35,15);
  display.print("SELECT AMPS");
   display.setCursor(50,25);
  display.print(f);
  display.display();
  currentscreen=3;
void screen4(){
  display.setCursor(30,5);
  display.print("LOW VOLTAGE");
  display.setCursor(60,15);
  display.print("/");
  display.setCursor(30,25);
  display.print("NO BATTERY");
  display.display();
  currentscreen=4;
void screen5(){
   display.setCursor(0,0);
  display.println("V = ");
   display.setCursor(20,0);
  display.println(u,1);
  display.setCursor(80,0);
  display.println("A =");
   display.setCursor(100,0);
  display.println(i,1);
  display.setCursor(0,25);
  display.println("T =");
   display.setCursor(80,25);
  display.println("C =");
  display.setCursor(100,25);
  display.print(c);
display.display();
 setClock();
display.setCursor(20,25);
if(hours<10)
display.print("0");
display.print(hours);
display.print(":");
if(minutes<10)
display.print(":");
display.print("0");
display.print(minutes);
display.print(":");
display.print(":");
if(seconds<10)
display.print("0");
display.print(seconds);
{display.print(seconds);}
    display.display();
currentscreen=5;
