Arduino IDE 1.8.19
Board WEMOS D1 Mini
Basically, does uploading a project overwrite the current EEPROM data stored on the board ?
Here's the project I'm working on, and the intention is that I should only be able to force an EEPROM data "initialisation" on "build_no" change, but it appears that every upload causes the "default" values to be asserted, even though I keep the same build number.
That's not what I want at all, changing the code shouldn't affect the EEPROM data.
To be fair, this project only has 2 parameters, and it's easy to put them back to what they might have been, but what if there was a bigger data structure, that would be a nightmare...
I've used this technique before on Nano projects, and it has appeared to work ok, is there something different with the WEMOS ?
// pRojeCt Bird Scarer
#include "Remote_XY.hpp"
#include <EEPROM.h>
// define I/O pins
#define gas_supply D2
#define ignition D1
// constants
#define dormant 0 // state engine
#define timing 1 // state engine
#define gassing 2 // state engine
#define firing 3 // state engine
#define finished 4 // state engine
#define GUI RemoteXY // easier to type !
#define build_no 35 // Build number, change this and the
// EEPROM data will get reset !!
// EEPROM Addresses
#define eeAddress 0 // start of the eeprom storage space
// volatile data
unsigned long time_now;
uint16_t fire_pulse = 3; //tenth of seconds
uint8_t cycle = 0;
// Create the EEPROM data structure
struct udt_eeData {
int16_t runaway_time; // seconds
int16_t gassing_time; // seconds
uint8_t id; // this is last to catch structure changes
//Create the EEPROM data of type udt_eeData
udt_eeData eeData;
RemoteXY_Init ();
// set output pin modes and intialise
pinMode (ignition, OUTPUT);
digitalWrite(ignition, LOW);
pinMode (gas_supply, OUTPUT);
digitalWrite(gas_supply, LOW);
// retrieve eeData from EEPROM
EEPROM.get(eeAddress, eeData);
// initialise eeData if NOT already present
// THIS SHOULD ONLY OCCUR IF BUILD has changed !!
if (eeData.id != build_no)
eeData.runaway_time = 30;
eeData.gassing_time = 3;
eeData.id = build_no;
EEPROM.put(eeAddress, eeData);
// retrieve the settings from eeData
GUI.runaway_time = eeData.runaway_time;
GUI.gassing_time = eeData.gassing_time;
// start the serial monitor
// intialise the operation cycle
cycle = dormant;
// start our internal time reference
time_now = millis();
} // end setup()
// LOOP - LOOP - LOOP - LOOP - LOOP - LOOP - LOOP
RemoteXY_Handler ();
switch(cycle)
case dormant:
// set output states
// indications
GUI.led_ready = 1;
GUI.led_timing = 0;
GUI.led_gassing = 0;
GUI.led_firing = 0;
GUI.sound_1 = 0;
// update EEPROM data if any settings changed
if(GUI.runaway_time != eeData.runaway_time)
eeData.runaway_time = GUI.runaway_time;
if(GUI.gassing_time != eeData.gassing_time)
eeData.gassing_time = GUI.gassing_time;
// wait fire button pressed
if(GUI.fire_button == 1)
cycle++; // advance to next stage
case timing:
// indications
GUI.led_ready = 0;
GUI.led_timing = 1;
GUI.led_firing = 0;
GUI.sound_1 = 2021;
if(GUI.runaway_time > 0)
// countdown runaway_time
if(millis() > time_now + 1000)
GUI.runaway_time--;
// have we timed out ?
if(GUI.runaway_time == 0)
case gassing:
digitalWrite(gas_supply, HIGH);
// indications
GUI.led_ready = 0;
GUI.led_timing = 0;
GUI.led_gassing = 1;
GUI.led_firing = 0;
GUI.sound_1 = 2011;
if(GUI.gassing_time > 0)
// countdown gassing_time
GUI.gassing_time--;
if(GUI.gassing_time == 0)
case firing:
digitalWrite(ignition, HIGH);
// indications
GUI.led_ready = 0;
GUI.led_timing = 0;
GUI.led_firing = 1;
if(fire_pulse > 0)
// countdown fire_pulse (0.1s)
if(millis() > time_now + 100)
fire_pulse--;
if(fire_pulse == 0)
cycle++; //
case finished:
// reset our volatile data from the constants
fire_pulse = 3;
cycle = dormant;
} //switch(cycle):
// catchall "abort" button pressed
if(GUI.abort_button)
fire_pulse = 3;
cycle = dormant;
// Serial monitoring
// values in [ ] are eeData
Serial.print(build_no);
Serial.print("[");
Serial.print(eeData.id);
Serial.print("]");
Serial.print(" Cycle : ");
Serial.print(cycle);
Serial.print(" Delay ");
Serial.print(GUI.runaway_time);
Serial.print("[");
Serial.print(eeData.runaway_time);
Serial.print("]");
Serial.print(" : Gas ");
Serial.print(GUI.gassing_time);
Serial.print("[");
Serial.print(eeData.gassing_time);
Serial.print("]");
Serial.print(" : Fire ");
Serial.println(fire_pulse);
} //void loop()
I've not posted the GUI (RemoteXY) header block, as it's not relevant
