How to make my load cell sample only every 0.5 sec
I have two load cells, measuring 2 different weights.
Looks something like this:
(I have built in an LCD display, and Timer, I don't want to overflow the code with it, but if needed, I can copy it, but it's a maaasssssssssssss:D ).
#include <Hx711.h>
Hx711 scale1(A0, A1);
Hx711 scale2(A2, A3);
scale1.set_scale(1140.f);
scale2.set_scale(1140.f);
scale1.tare();
scale2.tare();
lcd.begin(16,2);
  lcd.backlight();
  LCD display codes....
  delay(200);
My problem is, that it's sampling the loadcell too fast without a delay operation, but I don't want to use delay, because it screws up the timer. So I want to do it with an Interrupt which reads the current value every let say .5 sec and display it on the LCD display.
What interrupt should I use?
Timer/Counter?
ADC conversion complete?
My timer works with millis(), so it can count sec, minutes, will the other ISR screw up my timer?
Thanks in advanced
Don't do it with interrupts. Do it like blink without delay.
Here's the blink without delay code adapted to do what you need. You just need to insert your code to read the load cell where indicated.
// Generally, you should use "unsigned long" for variables that hold time
unsigned long previousMillis = 0;        // will store last time load cell was read
// constants won't change:
const long interval = 500;           // interval at which to read load cell
  // do whatever you need to do
  // here is where you'd put code that needs to be running all the time.
  // check to see if it's time to read the load cell; that is, if the difference
  // between the current time and last time you read the load cell is bigger than
  // the interval at which you want to read the load cell.
  if (currentMillis - previousMillis >= interval) {
    // save the last time you read the load cell
    // CODE TO READ THE LOAD CELL GOES HERE
Okay, I think I start to understand this millis() thing, and Blink without delay().
My timer is build like this, the problem that my timer now skips seconds, ultimately it's okay in the long run, but the reading on the LCD display is a mess :S
I think I need to do it outside of the loop, so they don't get confused, right?
This is my Stopwatch code inside loop:
digitalWrite(ledPin, LOW);            // Initiate LED and Step Pin States
  startState = digitalRead(startPin); // Check for button press, read the button state and store
  // check for a high to low transition if true then found a new button press while clock is not running - start the clock
  if (startState == LOW && lastButtonState == HIGH  &&  blinking == false) {
    startTime = millis();                               // store the start time
    blinking = true;                                  // turn on blinking while timing
    //delay(10);                                         // short delay to debounce switch
    lastButtonState = startState;                    // store startState in lastButtonState, to compare next time
  // check for a high to low transition if true then found a new button press while clock is running - stop the clock and report
  else if (startState == LOW && lastButtonState == HIGH && blinking == true) {
    blinking = false;                                    // turn off blinking, all done timing
    // Routine to report elapsed time
    elapsedTime =   millis() - startTime;                // store elapsed time
    elapsedMinutes = (elapsedTime / 60000L);
    elapsedSeconds = (elapsedTime / 1000L);              // divide by 1000 to convert to seconds - then cast to an int to print
    elapsedFrames = (elapsedTime / interval);            // divide by 100 to convert to 1/100 of a second - then cast to an int to print
    fractionalSecs = (int)(elapsedSeconds % 60L);        // use modulo operator to get fractional part of 60 Seconds
    fractionalMins = (int)(elapsedMinutes % 60L);        // use modulo operator to get fractional part of 60 Minutes
    lcd.setCursor(11,1);
    if (fractionalMins < 10) {                           // pad in leading zeros
      lcd.print("0");                                 // add a zero
    lcd.print(itoa(fractionalMins, buf, 10));       // convert the int to a string and print a fractional part of 60 Minutes to the LCD
    lcd.print(":");                                 //print a colan.
    if (fractionalSecs < 10) {                           // pad in leading zeros
    lcd.print(itoa(fractionalSecs, buf, 10));          // convert the int to a string and print a fractional part of 60 Seconds to the LCD
  else {
  // run commands at the specified time interval
  // blink routine - blink the LED while timing
  // check to see if it's time to blink the LED; that is, the difference
  // between the current time and last time we blinked the LED is larger than
  // the interval at which we want to blink the LED.
  if ( (millis() - previousMillis > interval) ) {
    if (blinking == true) {
      previousMillis = millis();                    // remember the last time we blinked the LED
      digitalWrite(ledPin, HIGH);                   // Pulse the LED for Visual Feedback
      elapsedMinutes = (elapsedTime / 60000L);      // divide by 60000 to convert to minutes - then cast to an int to print
      elapsedFrames = (elapsedTime / interval);     // divide by 40 to convert to 1/25 of a second - then cast to an int to print
    else {
      digitalWrite(ledPin, LOW);                 // turn off LED when not blinking
Should I get rid of the blinking statement? I don't know why it is there :smiley:
God bless copy paste coding :smiley:
XenoBen:
That is probably because you update your timer all the time (and print out all the info every time)
Main thing, write to the lcd-screen only when something has changed and preferably only the parts that have changed.
