Im new to this so decided as a starting project i would make a program that converts a number up to 4095(i have 12 led's) into binary and shows it on the led's. I got it all working and wanted it to make a random number every 5 seconds after the last one, but i cant use randomseed outside of loop or setup, and if i use it in loop it changes the
number before its done converting, but if i put it in setup its not in the scope of the loop. Here is the code without me attempting to randomize it:
int number = 15;
int digitNbr = 12;
pinMode(13, OUTPUT);
pinMode(12, OUTPUT);
pinMode(11, OUTPUT);
pinMode(10, OUTPUT);
pinMode(9, OUTPUT);
pinMode(8, OUTPUT);
pinMode(7, OUTPUT);
pinMode(6, OUTPUT);
pinMode(5, OUTPUT);
pinMode(4, OUTPUT);
pinMode(3, OUTPUT);
pinMode(2, OUTPUT);
if (number - pow(2, digitNbr) >= 0 && (number > 0)) { // this check if a number is greater that 2^digitnbr,
digitalWrite(digitNbr + 2, HIGH); // and if it is, it takes it away and lowers digitnbr by
number = number - pow(2, digitNbr); // one, and loops. if not, it takes one away and checks again, until
digitNbr -= 1; // number = 0, then it stops. (the digitalwrite is just for the led's, ignore it
else if (number > 0) {
digitNbr = digitNbr - 1;
and here it is with my randomizing attempts
int number = 15;
int digitNbr = 12;
randomSeed(analogRead(A0));
pinMode(9, OUTPUT);
pinMode(8, OUTPUT);
pinMode(7, OUTPUT);
pinMode(6, OUTPUT);
pinMode(5, OUTPUT);
pinMode(4, OUTPUT);
pinMode(3, OUTPUT);
pinMode(2, OUTPUT);
digitNbr -= 1;
else if (number == 0) {
delay(5000);
int number = random(4095);
digitNbr = 12; // when the number reaches 0, this is supposed to wait 5 sec, reset it to a random number and
// set digitnbr back to 12, but the problem is that it doesnt change it on the scope i want(i think)
i keep getting this: " error: expected constructor, destructor, or type conversion before '(' token
randomSeed(analogRead(A0));"
also, when i change the number in that else if at the end manually, the main converter doesnt start up again.
Thanks
