// Sweep
// by BARRAGAN <http://barraganstudio.com>
// This example code is in the public domain.
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// a maximum of eight servo objects can be created
int pos = 0; // variable to store the servo position
myservo.attach(9); // attaches the servo on pin 9 to the servo object
for(pos = 0; pos < 180; pos += 1) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15); // waits 15ms for the servo to reach the position
for(pos = 180; pos>=1; pos-=1) // goes from 180 degrees to 0 degrees
This makes the servo motor go from 0 to 180 degrees and 180 to 0. If I wanted it to go from 0 to 30 and back, do I just change it to:
// Sweep
#include <Servo.h>
for(pos = 0; pos < 30; pos += 1) // goes from 0 degrees to 180 degrees
for(pos = 30; pos>=1; pos-=1) // goes from 180 degrees to 0 degrees
The code makes the servo turn clockwise until it can't be turned anymore and it just stays there. When I try to bend it CCW, I can feel it forcing clockwise.
I don't see anything wrong in the original code or you modified version. Did the original code work correctly? If not, how is the servo powered ans what connections do you have to the Arduino?
That is most likely because the servo library assumes and applies a default values assuming your servo can handle microsecond pulse lengths of:
default min is 544, max is 2400
And it maps those pulse width values to assume 0 to 180 if using the servo.write(angle_value) command.
The original R/C servo standard was a range of 1000 to 2000 microseconds and all servos will work with that range. Most servos do have 'overrange' below and above 1000 to 2000 but how much varies from specific servo brand and model you have. So you are most likely forcing your servo up against a mechanical stop and that is not a good thing. You need to either limit the range of values in your your servo.write commands to less then arduino 0-180 angle degrees or use the servo.writeMicrosecond command with actual pulse width values that your specific servo can handle safely. All servos cannot safely respond to 544 to 2400 microsecond range and all servos do not have a 0-180 degree mechanical travel range.
The arduino abstracted servo 'angle' positioning method is a flawed concept (it works on assumptions that may or may not to true for any specific servo) and helps prevent beginners to servos from understanding how they actual work.
// zoomkat 10-22-11 serial servo test
// type servo position 0 to 180 in serial monitor
// or for writeMicroseconds, use a value like 1500
// for IDE 0022 and later
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
myservo.writeMicroseconds(1500); //set initial servo position if desired
myservo.attach(7, 500, 2500); //the pin for the servo control, and range if desired
Serial.println("servo-test-22-dual-input"); // so I can keep track of what is loaded
while (Serial.available()) {
char c = Serial.read(); //gets one byte from serial buffer
readString += c; //makes the string readString
delay(2); //slow looping to allow buffer to fill with next character
if (readString.length() >0) {
Serial.println(readString); //so you can see the captured string
int n = readString.toInt(); //convert readString into a number
// auto select appropriate value, copied from someone elses code.
if(n >= 500)
Serial.print("writing Microseconds: ");
Serial.println(n);
myservo.writeMicroseconds(n);
Serial.print("writing Angle: ");
Serial.println(n);
myservo.write(n);
readString=""; //empty for next input
