I am trying to create a timer that outputs the time remaining in minutes. I am using an Adafruit Circuit Playground Express.
For example, if the timer is 5 minutes, then every minute it should output the time remaining, until the time ends.
5 minutes timer started.
Delay: 5 minutes
Delay:4 minutes
Delay: 3 minutes
Delay: 2 minutes
Delay: 1 minute
This is my attempt to implement this, but it does not output the time in minutes.
uint32_t start_delay = 5 * 60 * 1000UL;
Serial.println("5 minutes timer started.");
Serial.print(F("Delay: "));
for (uint32_t timer_delay = millis(); (millis() - timer_delay) < start_delay; ) {
Serial.print((millis() - timer_delay));
Serial.println(F(" minute(s)"));
Thanks!
Six_Actual:
It doesn't even compile. It's incomplete. Post a complete code.
Thanks for your response. I have tried to implement these suggestions, but the program does not enter the if statement. What am I doing wrong?
const unsigned long interval = 1 * 60 * 1000UL;
unsigned long previousMillis = 0;
int minutes = 5;
while (minutes >= 0){
if (currentMillis - previousMillis >= interval) {
Serial.print(minutes);
minutes = minutes - 1;
Second verse, same as the first. Except posted without code tags.
Where do you have
currentMillis = millis(); // capture current time
or
previousMillis = currentMillis; // save new time as old time
Six_Actual:
Posting an incomplete program.
Posting incorrectly -- no Code Tags.
Sorry, I forgot to include: unsigned long currentMillis = millis();
int minutes = 5;
while (minutes >= 0) {
How many times do you have to be told to post ALL your code before you actually start to take notice?
You win no friends here by constantly ignoring people who are trying to help you.
