Hello, how to pass the hex value to a variable in another procedure (void)
My code
#include <IRremote.h>
#include <IRremoteInt.h>
int RECV_PIN = 11;
byte ircom;
IRrecv irrecv(RECV_PIN);
decode_results results;
IRsend irsend;
irrecv.enableIRIn(); // Start the receiver
void irir(variable(oto)) //<-- here
irsend.sendNEC(oto, 32);
irrecv.resume();
Serial.println(oto);
if (irrecv.decode(&results)) {
switch (results.value) {
case 0x2F5807F:
//irsend.sendNEC(, 32);
Serial.println("OK!");
irir(0x807F58A7); //<--- this value
system
October 21, 2018, 4:59pm
2
Here, you are passing the hex value 0x2580 to a function.
variable(oto)
is "unsigned long oto"
I do not understand why I should use the serial port to pass values to a variable in another procedure. I think I explained what I mean in the picture.
Regards
Instead of
Try:
void irir(unsigned long oto) {
Is an example of passing a value to a function. In this case a decimal value
The point is that it is exactly the same as doing
Serial.begin(0x2580);
Hex is only one of many ways to represent a number
The serial was just an example. Your code looks OK at first glance.
What is your problem?
If you don't want to pass a hard-coded value, you can pass results.value in the function call.
Why my arduino frezzing after few uses.
int RECV_PIN = 11;
long ot = 0x0000000;
IRsend irsend;
ot=results.value;
switch (ot) {
case 0x2F5807F: { irir(0x807F58A7); break; }
case 0x2F5C03F: { irir(0x807FE817); break; }
case 0x2F540BF: { irir(0x5FA38C7); break; }
case 0x2F59867: { irir(0xE8AFBC77); break; }
case 0x2F548B7: { irir(0x807F42BD); break; }
case 0x2F5A05F: { irir(0x807FB04F); break; }
case 0x2F57887: { irir(0x5FABA45); break; }
case 0x2F5F00F: { irir(0x5FA02FD); break; }
After a few uses, it hangs and does not resume, it also happens as I hold the button on the remote control.
system
October 21, 2018, 7:06pm
11
You don't have a call to resume (that I can see)
