How to pause & continue led sequence with button press
Hi!
I am new here, I would like to seek some advice on how to solve the following problem:
I would like to have cca. 7 LED. Each led has an assigned switch.
The action is:
To have a sequence, that lights up each LED after one another, but when any switch is pressed (one at a time, so the one that was pressed "faster") the sequence should pause, the assigned number of LED should light up as long as the button is pressed, when the button is released, the sequence should continue from where it was paused.
LEDs should go ON and OFF dimmed, so from 0-100% in let's say 0,5 sec, 1 sec ON, then 100-0% in 0,5sec.
LED1 goes on for 2 sec,
LED1 goes off,
delay 0,1sec,
LED2 goes on for 2 sec,
LED2 goes off,
delay 0,1sec,
and so on...
There is no code yet that I could post, only some very basic idea that lacks the main solution for the problem.
I do appreciate help of any kind!
You can use arduino UNO for this simple task.
if you have any specific way or requirement by which you want to do this. please mention.
Just my curiosity: what's the purpose of all that? Is it a kinda game?
Yes, something similar, like a "wheel of fortune".
I think you could use any Arduino board, including UNO like @anantmohit already said.
I don't know if the fact you're saying you're "new here" means you have some kinda experience with Arduino and/or programming. If you don't have such experience I think you need to start learning a bit about Arduino before, together with at least a basic knowledge of digital electronics (limited to pushbuttons and LEDs just for now) and the C programming language.
If you already know enough about that, my personal advice is to use a simulator like Wokwi, so you can just test the wirings (you can draw your circuit with an Arduino and all the other elements needed) and the code without even buying the hardware. when the simulation looks good to you, you can start putting your hands on the real hardware to build a prototype.
I have some experience with Arduino, I am 99% sure about wiring this exact circuit.
I have started the code by defining pin layout, and a basic sequence that lights up the LEDs, but
I am stuck figuring out which command/s in which order will give the required result at the end.
Please post your sketch as it is now
Nice. So, post your current code (even if it's "a very basic idea") and we'll take a look at it.
But we also need yo to draw your current wiring an post it here (as I said before, IMHO the best way to do it is using Wokwi, where you can also test your code, and share here the whole project).
In the meantime I have learned that the delay function is unusable for this, as it stops the program as long as it lasts.
I have found the "blink without delay" sketch, which made me a bit more confused.
I'm figuring out the Wokwi app, as soon as I managed to model the wiring I'll post it.
const int LED1 = 13;
const int LED2 = 12;
const int LED3 = 11;
const int buttonPin1 = 10;
// variables will change:
int buttonState = 0;  // variable for reading the pushbutton status
  pinMode(LED1, OUTPUT);
  pinMode(LED2, OUTPUT);
  pinMode(LED3, OUTPUT);
  pinMode(buttonPin1, INPUT);
  digitalWrite(LED1, HIGH);  //turn on led 1
  delay(2000);  //keep led on for 2sec
  digitalWrite(LED1, LOW); // turn off led1
  delay(100); //wait 0,1 sec
  digitalWrite(LED2, HIGH); //turn led2 on
  delay(2000); //keep led2 on for 2 sec
  digitalWrite(LED2, LOW); //turn led2 off
  // read the state of the pushbutton value:
  buttonState = digitalRead(buttonPin1);
  // check if the pushbutton is pressed. If it is, the buttonState is HIGH:
  if (buttonState == HIGH) {
    // turn LED on:
    digitalWrite(LedPin1, HIGH);
    // turn LED off:
    digitalWrite(ledPin1, LOW);
I understand being confused, I get confused, too with "millis()". There is no "right" way to do this, but some methods are preferred. The more you tinker with it, the more you will understand. Here is my spin on "blink without delay" that you can plug into WOKWI.COM for testing. The LED_BUILTIN blinks all the time UTIL the button is pressed, and the LED pauses in the state it was in UNTIL the button is released. The Serial Monitor also shows the state of the LED.
sketch.ino
unsigned long newMillis = 0, oldMillis = 0; // event timers
unsigned long interval = 500; // milliseconds
bool state; // the state of the LED
byte buttonPin = 2; // button pin
  Serial.begin(115200); // configure Serial Monitor baud
  pinMode(LED_BUILTIN, OUTPUT); // configure LED_BUILTIN/DIO pin 13 as OUTPUT
  pinMode(buttonPin, INPUT_PULLUP); // configure button pin as INPUT with internal pullup resistor
  blink(); // call the "blink" function
void blink() {
  newMillis = millis(); // start an event
  if (newMillis - oldMillis > interval) { // compare difference in event times to interval
    oldMillis = newMillis; // store the new event start time
    state = !state; // flip the current state for the LED
    digitalWrite(LED_BUILTIN, state); // set the LED to the current state
    if (state) Serial.print("1"); // show current state in Serial Monitor
    else Serial.print("0"); // show current state in Serial Monitor
  while (!digitalRead(buttonPin)) {} // hold here while button is pressed
diagram.json
  "version": 1,
  "author": "Anonymous maker",
  "editor": "wokwi",
  "parts": [
    { "type": "wokwi-arduino-nano", "id": "nano", "top": -110.4, "left": 201.1, "attrs": {} },
      "type": "wokwi-pushbutton-6mm",
      "id": "btn1",
      "top": -136.6,
      "left": 336,
      "attrs": { "color": "green" }
      "type": "wokwi-text",
      "id": "text1",
      "top": -163.2,
      "left": 326.4,
      "attrs": { "text": "pause" }
  "connections": [ [ "nano:GND.2", "btn1:2.l", "black", [ "v0" ] ], [ "nano:2", "btn1:1.l", "green", [ "v0" ] ] ],
  "dependencies": {}
