alert requires the sht31 to be in Periodic Data Acquisition Mode
the following code tests the high alert temperature set and clear
Note to use this code the file Docements>Arduino>libraries>Adafruit_SHT31_Library>Adafruit_SHT31.h
requires line 66 editing to comment out the private keyword, e.g
//private:
this gives the code below access to the private members of class Adafruit_SHT31
// SHT31 - read and set high alert temperature set and clear and test
// see https://sensirion.com/products/catalog/SHT31-DIS-B/
// datasheet and alert mode application note
// to use this code the file Docements>Arduino>libraries>Adafruit_SHT31_Library>Adafruit_SHT31.h
// requires line 66 editing to comment out the private keyword, e.g
// //private:
// this gives the code below access to the private members of class Adafruit_SHT31
#include <Arduino.h>
#include <Wire.h>
#include "Adafruit_SHT31.h"
// parameters for test
#define alertPin 2 // sht31 alert pin
float highAlertTemperatureSet = 29.0f; // high alert set
float highAlertTemperatureClear = 26.0f; // high alert cleared
Adafruit_SHT31 sht31 = Adafruit_SHT31();
// alert interrupt ISR - set alertFlag on change of state
volatile int alertFlag = 0;
void alertISR(void) {
alertFlag = 1; // set alert indicator
if (!sht31.begin(0x44)) { // Set to 0x45 for alternate I2C address
Serial.println("Couldn't find SHT31");
while (1) delay(1);
Serial.println("\n\nsht31 alert limit tests");
sht31.reset();
float HighAlertLimitSetTemperature = 0, HighAlertLimitClearTemperature = 0, LowAlertLimitSetTemperature = 0,
HighAlertLimitSetHumidity = 0, HighAlertLimitClearHumidity = 0, LowAlertLimitSetHumidity = 0;
// check high and low alert temperatures - should be +60 and -10
readHighAlertLimitSet(HighAlertLimitSetTemperature, HighAlertLimitSetHumidity);
Serial.print("high alert limit set temperature (should be 60.00) = ");
Serial.print(HighAlertLimitSetTemperature);
Serial.print(" humidity (should be 80.00) = ");
Serial.println(HighAlertLimitSetHumidity);
readHighAlertLimitClear(HighAlertLimitClearTemperature, HighAlertLimitClearHumidity);
Serial.print("high alert limit clear temperature (should be 58.00) = ");
Serial.print(HighAlertLimitClearTemperature);
Serial.print(" humidity (should be 79.00) = ");
Serial.println(HighAlertLimitClearHumidity);
readLowAlertLimitSet(LowAlertLimitSetTemperature, LowAlertLimitSetHumidity);
Serial.print("low alert limit set(should be -10.00) = ");
Serial.print(LowAlertLimitSetTemperature);
Serial.print(" humidity (should be 22.00) = ");
Serial.println(LowAlertLimitSetHumidity);
// set the high temperature alert set and clear
writeHighAlertLimitSet(highAlertTemperatureSet); // set high alert temperature level and check it
Serial.print("\nnew high alert limit set temperature = ");
Serial.print(highAlertTemperatureSet = HighAlertLimitSetTemperature);
Serial.print(" humidity ");
writeHighAlertLimitClear(highAlertTemperatureClear);
Serial.print("new high alert limit clear temperature = ");
Serial.print(highAlertTemperatureClear = HighAlertLimitClearTemperature);
Serial.print(" humidity = ");
uint16_t status = sht31.readStatus();
Serial.print("status ");
Serial.println(status, HEX);
clearStatusRegister(); // clear status bits
setPeriodicDataAcquisitionMode(); // set Periodic Data Acquisition Mode
attachInterrupt(digitalPinToInterrupt(alertPin), alertISR, CHANGE); // set up interrupt
// loop reading temperature and humidity and check for alerts
uint16_t status = sht31.readStatus(); // read status bits
Serial.print(status, HEX); // read temperature and humidity
float temperature, humidity;
readTempHum(temperature, humidity);
if (!isnan(temperature)) { // check if 'is not a number'
Serial.print(" Temp *C = ");
Serial.print(temperature);
Serial.print("\t\t");
Serial.println("Failed to read temperature");
if (!isnan(humidity)) { // check if 'is not a number'
Serial.print("Hum. % = ");
Serial.println(humidity);
Serial.println("Failed to read humidity");
// delay checking alertFlag
long timer = millis();
bool printedAlert = 0;
while (millis() - timer < 3000) {
if (alertFlag) { // if alert occured
alertFlag = 0;
if (!printedAlert) { // if not already printed
printedAlert = 1;
Serial.print("******* alert !! ******* status ");
Serial.print(" alert pin state = ");
int alertPinState = digitalRead(alertPin);
Serial.println(alertPinState);
if (alertPinState)
Serial.println(" *** high temperature alert set ! **** ");
Serial.println(" *** high temperature alert cleared ! **** ");
// set up setPeriodic Data Acquisition Mode for alerts
void setPeriodicDataAcquisitionMode(void) {
sht31.writeCommand(0x2126); // set repeatability mode
delay(20);
void clearStatusRegister(void) {
sht31.writeCommand(0x3041); // clear status register
delay(20);
// read high alert set limit
bool readHighAlertLimitSet(float &temp, float &humidity) {
Serial.println("reading high alert limit set ");
uint8_t readbuffer[3] = { 0 };
sht31.writeCommand(0xE11F); // read high alert set
delay(20);
sht31.i2c_dev->read(readbuffer, sizeof(readbuffer));
if (readbuffer[2] != crc8(readbuffer, 2)) {
Serial.println("CRC error!");
return false;
Serial.print("readHigAlertLimitSet 0x");
Serial.print(readbuffer[0], HEX);
Serial.print(readbuffer[1], HEX);
Serial.println(readbuffer[2], HEX);
// temperature convert 9 bit value to 16bit value
int32_t stemp = ((int32_t)(((uint32_t)((readbuffer[0] & 0x01) << 8)) | readbuffer[1])) << 7;
// convert from 16bit value
stemp = 100.0f * ((stemp * 175.0f) / 65535.0f - 45.0f);
temp = (float)stemp / 100.0f;
// humidity convert 7 bit value to 16 bit value
uint32_t shum = (uint32_t)((uint32_t)(readbuffer[0] & 0xFE) << 8);
humidity = (shum * 100.0f) / 65535.0f;
return true;
// read high alert clear limit
bool readHighAlertLimitClear(float &temp, float &humidity) {
Serial.print("reading high alert limit clear ");
sht31.writeCommand(0xE114); // read high alert set
delay(20);
return false;
Serial.print(" 0x");
return true;
// write high alert set temperature
void writeHighAlertLimitSet(float temp) {
Serial.print("write high alert limit set ");
Serial.println(temp);
// calculate 9 bit value for temperature
int32_t stemp = (temp + 45.0f) * 65535.0f / 175.0f;
stemp = stemp >> 7;
//Serial.print("setHighAlertLimit 0x");
//Serial.println(stemp,HEX);
// buffer to set high alert - command is 0x611D
uint8_t writebuffer[5] = { 0x61, 0x1D, ((stemp >> 8) & 0x01) | 0xCC, stemp & 0xff, 0 };
writebuffer[4] = crc8(writebuffer + 2, 2);
//Serial.print(writebuffer[2], HEX);
//Serial.print(writebuffer[3], HEX);
//Serial.println(writebuffer[4], HEX);
sht31.i2c_dev->write(writebuffer, sizeof(writebuffer)); // write updated value
delay(20);
delay(20);
// write high alert clear temperature
void writeHighAlertLimitClear(float temp) {
Serial.print("write high alert limit clear ");
stemp = stemp >> 7;
uint8_t writebuffer[5] = { 0x61, 0x16, ((stemp >> 8) & 0x01) | 0xc8, stemp & 0xff, 0 };
delay(20);
delay(20);
// read low alert set temperature
bool readLowAlertLimitSet(float &temp, float &humidity) {
Serial.println("reading low alert limit set ");
sht31.writeCommand(0xE102); // read low alert set
delay(20);
return false;
Serial.print("readLowAlertLimitSet 0x");
// temperature convert from 16bit value
return true;
static uint8_t crc8(const uint8_t *data, int len) {
* CRC-8 formula from page 14 of SHT spec pdf
* Test data 0xBE, 0xEF should yield 0x92
* Initialization data 0xFF
* Polynomial 0x31 (x8 + x5 +x4 +1)
* Final XOR 0x00
const uint8_t POLYNOMIAL(0x31);
uint8_t crc(0xFF);
for (int j = len; j; --j) {
crc ^= *data++;
for (int i = 8; i; --i) {
crc = (crc & 0x80) ? (crc << 1) ^ POLYNOMIAL : (crc << 1);
return crc;
// read data in Periodic Data Acquisition Mode
bool readTempHum(float &temp, float &humidity) {
uint8_t readbuffer[6];
sht31.writeCommand(0xE000); // Fetch Data command
delay(20);
if (readbuffer[2] != crc8(readbuffer, 2) || readbuffer[5] != crc8(readbuffer + 3, 2))
return false;
int32_t stemp = (int32_t)(((uint32_t)readbuffer[0] << 8) | readbuffer[1]);
// simplified (65536 instead of 65535) integer version of:
// temp = (stemp * 175.0f) / 65535.0f - 45.0f;
stemp = ((4375 * stemp) >> 14) - 4500;
uint32_t shum = ((uint32_t)readbuffer[3] << 8) | readbuffer[4];
// humidity = (shum * 100.0f) / 65535.0f;
shum = (625 * shum) >> 12;
humidity = (float)shum / 100.0f;
return true;
serial monitor output as temperature varies above set and below clear limits
sht31 limit tests
readHigAlertLimitSet 0xCCD822
high alert limit set temperature (should be 60.00) = 28.82 humidity (should be 80.00) = 79.69
reading high alert limit clear 0xC8CF75
high alert limit clear temperature (should be 58.00) = 25.75 humidity (should be 79.00) = 78.13
readLowAlertLimitSet 0x3466AD
low alert limit set(should be -10.00) = -10.13 humidity (should be 22.00) = 20.31
write high alert limit set 29.00
new high alert limit set temperature = 28.82 humidity 79.69
write high alert limit clear 26.00
new high alert limit clear temperature = 25.75 humidity = 78.13
status 60
status 60 Temp *C = 23.84 Hum. % = 50.36
status E0 Temp *C = 23.84 Hum. % = 50.27
status E0 Temp *C = 23.83 Hum. % = 50.29
status E0 Temp *C = 23.80 Hum. % = 50.29
status E0 Temp *C = 23.80 Hum. % = 50.09
status E0 Temp *C = 26.93 Hum. % = 53.67
status E0 Temp *C = 28.74 Hum. % = 76.61
******* alert !! ******* status 8C60 alert pin state = 1
status 8CE0 Temp *C = 28.74 Hum. % = 87.06
status 8CE0 Temp *C = 27.46 Hum. % = 85.21
status 84E0 Temp *C = 26.90 Hum. % = 73.39
status 84E0 Temp *C = 26.59 Hum. % = 60.77
status 84E0 Temp *C = 26.31 Hum. % = 53.30
status 84E0 Temp *C = 26.04 Hum. % = 49.52
status 84E0 Temp *C = 25.81 Hum. % = 47.74
******* alert !! ******* status A0 alert pin state = 0
status E0 Temp *C = 25.63 Hum. % = 46.94
status E0 Temp *C = 25.51 Hum. % = 46.70
status E0 Temp *C = 25.30 Hum. % = 46.75
status E0 Temp *C = 25.16 Hum. % = 46.84
status E0 Temp *C = 24.72 Hum. % = 47.80
status E0 Temp *C = 24.68 Hum. % = 48.08
status E0 Temp *C = 24.57 Hum. % = 48.13
status E0 Temp *C = 24.55 Hum. % = 48.23
status E0 Temp *C = 29.59 Hum. % = 60.79
******* alert !! ******* status 8460 alert pin state = 1
status 8CE0 Temp *C = 30.81 Hum. % = 80.16
status 84E0 Temp *C = 29.03 Hum. % = 75.95
status 84E0 Temp *C = 28.32 Hum. % = 62.32
status 84E0 Temp *C = 27.81 Hum. % = 51.87
status 8520 Temp *C = 27.23 Hum. % = 46.15
status 84E0 Temp *C = 26.89 Hum. % = 44.74
status 84E0 Temp *C = 26.59 Hum. % = 44.32
status 84E0 Temp *C = 26.41 Hum. % = 44.44
status 84E0 Temp *C = 26.20 Hum. % = 44.54
status 84E0 Temp *C = 25.95 Hum. % = 44.84
status 84E0 Temp *C = 25.83 Hum. % = 45.16
status E0 Temp *C = 25.69 Hum. % = 45.53
status E0 Temp *C = 25.57 Hum. % = 45.76
status E0 Temp *C = 25.44 Hum. % = 46.05
oscilloscope odisplaying state of SHT31 alert pin output
it is probably simpler to use the standard sht31 libraries and test the limits say every tenth of a second in an timer interrupt routine, e.g. along the lines of
ISR(TIMER1_COMPA_vect) {
if(sht31.readTemperature() > highAlertTemperatureSet)
void loop(void) {
if(alertFlag)
Serial.println("high temperature alert set !");
