Hi everybody
I am having an assignment on HALL ACS712 sensor.
I want to calculate the current through the load RL=39. But the result is different from the theory because there is a lot of error. Theoretical current output 0.13A but reality is different.
Can anyone help me redo the low pass filter for the above circuit. The cutoff frequency here is around 1800-2000Hz.
Thanks everyone.
This is circut. RL=39
Those sensors are inaccurate at low currents. 0.13A is only 2% of the full scale current, similar to the accuracy of the scale factor.
As you can see from the data sheet, the scale factor can be anywhere from 180 to 190, a 5% variation! So, you need to determine the best scale factor for that current range.
