How to program parallel action using Arduino UNO
Dears,
I have issue with programming a code which make two action to be executed in parallel.
For example:
Four LED's working sequentially using delay, during that sequence I should turn on another LED at any time when a push button pressed and turn off that LED once the push button released.
I tried If statement but it did not work as I need, it seems I need something else to do or to re-place the if statement.
Kindly help me in this small issue.
Below is my tried code
int InletSA = 2;
int OutletSA = 3;
int FlushSA = 4;
int DrainSA = 5;
int Button = 12;
int LED = 11;
int ButtonValue=0;
  pinMode(Button, INPUT);
  pinMode(LED, OUTPUT);
  pinMode(InletSA, OUTPUT);
  pinMode(OutletSA, OUTPUT);
  pinMode(FlushSA, OUTPUT);
  pinMode(DrainSA, OUTPUT);
  digitalWrite(LED, LOW);
  digitalWrite(InletSA,LOW);
  digitalWrite(OutletSA,LOW);
  digitalWrite(FlushSA,LOW);
  digitalWrite(DrainSA,LOW);
void loop{
  ButtonValue = digitalRead(Button);
  if(ButtonValue != 0){
  digitalWrite(LED, HIGH);
  else{
  digitalWrite(InletSA, HIGH);
  digitalWrite(OutletSA, HIGH);
  digitalWrite(InletSA, LOW);
  digitalWrite(OutletSA, LOW);
  delay(5000);
  delay(8000);
  delay(4000);
Take a look at Using millis() for timing. A beginners guide, Several things at the same time and look at the BlinkWithoutDelay example in the IDE.
Have a look at how the code is organized in Several Things at a Time
Note how each function runs very briefly and returns to loop() so the next one can be called. None of the functions tries to complete a task in one call. And there may be dozens of calls to a function before it is actually time for it to do anything.
Also note that it uses millis() to implement non-blocking timing.
...R
You could try something like this using millis(). Compiles, not tested
const byte InletSA = 2;
const byte OutletSA = 3;
const byte FlushSA = 4;
const byte DrainSA = 5;
const byte Button = 12;
const byte LED = 11;
int ButtonValue=0;
unsigned long
    timeNow,
    timeLED;
byte
    stateLED;
    stateLED = 0;
}//setup
void loop( void )
    digitalWrite(LED, digitalRead( Button ) );
    timeNow = millis();
    switch( stateLED )
        case    0:
            timeLED = timeNow;
            stateLED++;
        case    1:
            if( timeNow - timeLED >= 5000ul )
                timeLED = timeNow;
                stateLED++;
            }//if
        case    2:
            if( timeNow - timeLED >= 8000ul )
                timeLED = timeNow;
                stateLED++;
            }//if
        case    3:
            if( timeNow - timeLED >= 4000ul )
                stateLED = 0;
    }//switch
}//loop
