How to randomly pick a number of pins from an array, what am I looking for?
Hi.
I've been googling for hours trying to find a way to randomly pick a number of pins from an array.
Hopefully my sketch make sense, it's not pretty but doing my best here.
Tried to explain it as good as I can and my problem is //-out in the middle.
int pinArray[] = {2, 3, 4, 5, 6, 7};
int count = 0;
int Antal;
int Tid;
int Tid2;
void setup(){
  // we make all the declarations at once
  for (count=0;count<6;count++) {
    pinMode(pinArray[count], OUTPUT);
  randomSeed (analogRead(0));
  //randomize between 0 and 5
  Antal = random(5);
//Allocate 0 and 1 as 6 and 7
  if (Antal==0) {Antal=6;}
  if (Antal==1) {Antal=7;}
  //Randomize time
  Tid = random(2000, 6000);
  //Randomize time2
  Tid2 = random(2002, 10000);
//Randomly pick "Antal" number of pins from array
//Set picked pins HIGH
//Run for "Tid"
delay(Tid);
//Picked pins LOW
//Clear "Tid"
if (Tid=>0){Tid==0;}
//Pause for "Tid2"
delay(Tid2);
//Clear "Tid2"
if (Tid2=>0){Tid2==0;}
//restart by choosing new "Antal"
What do you want to do?
What is the objective here?
Pushing a random twelve-bit (or *n-*bit) binary number onto the output pins (2-13) - or what?
The upper bound is excluded so "//randomize between 0 and 5" should say "//randomize between 0 and 4". If you don't want the range to start as 0, use the two argument version:
Antal = random(2, 8);  // Random pin from 2 to 7
What do you mean by "randomly pick a number of pins from an array"? Do you want a random number of randomly selected pins? Do you want the pins not to repeat (so the same pin won't be used twice in a selection)? If everything is random, are you sure it matters?
Note: This does not "Clear Tid". You are using "==" so it compares Tid to 0 and throws away the answer.
//Clear "Tid"
Same for Tid2. If you want to assign a new value, use "=", not "==".
The idea with the sketch is to select a random number within a set range, select that number of pins randomly from an array and set those pins high for a random time.
Random here is random within a set span.
Regarding the delays I figured I can use delay(random(2000, 6000)); instead and get a cleaner sketch.
Some other minor tweeks to the code will be made too but haven't gotten to it yet.
Still struggeling with the over all function :confused:
You could define a new array the same size as the pin array and use the values in it as indices into the pin array.
The steps would be:
  • Get the number of pins you want to use
  • Generate that number of random indices, not repeating values
  • Use the array of indices to index into the pin array
const byte arraySize = 6;
int pinIdx[] = { -1, -1, -1, -1, -1, -1};
int count = 0;
int Antal;
  // get # of pins
  Antal = random(1, arraySize+1);
  fillIndexArray();
  Serial.print("Count = "); Serial.println(Antal);
  Serial.print("Values:  ");
  for (int i = 0; i < Antal; i++)
    // print index #
    Serial.print("Index:  ");
    Serial.print(pinIdx[i]);
    Serial.print("  ");
    // print pin #
    Serial.print("Pin:  ");
    Serial.print(pinArray[pinIdx[i]]);
    Serial.print("  ");
void fillIndexArray()
  int idx = 0;
  int newIdx;
  byte i;
  // clear index array
  for (i = 0; i < arraySize; i++) pinIdx[i] = -1;
  // set first value in array of indices
  pinIdx[idx++] = random(arraySize);
  // while we need more indices
  while ( idx < Antal )
    // get next candidate
    newIdx = random(arraySize);
    // look for it on our list
    for (i = 0; i < idx; i++ )
      if ( pinIdx[i] == newIdx ) break;
    } // for
    // if it is not already on list, add it
    if ( i == idx ) pinIdx[idx++] = newIdx;
  } // while
johnwasser:
Moreover if (Tid=>0) ... do you mean (Tid>=0) ?? and if you are going to assign 0 it may as well be (Tid>0)
Thank you all for good advice.
I selected to redo the whole sketch w/o arrays and now it work just fine.
Rly have to get my head around arrays but just didn't have the energy today.
Here's the alternate sketch, sry for swedish comments.
int pin1 = 2;
int pin2 = 3;
int pin3 = 4;
int pin4 = 5;
int pin5 = 6;
int Antal;
int Vilka;
int Pads;
pinMode(pin1, OUTPUT);
pinMode(pin2, OUTPUT);
pinMode(pin3, OUTPUT);
pinMode(pin4, OUTPUT);
pinMode(pin5, OUTPUT);
//Start Random
randomSeed (analogRead (0));
//Slumpa Antal 1-5
Antal = random(5)+1;
//Slumpa vilka pins 1-5
for (Vilka = 0; Vilka < Antal; Vilka++){
Pads = random(5)+1;
  if (Pads == 1) digitalWrite(pin1, HIGH);
  else if (Pads == 2) digitalWrite(pin2, HIGH);
  else if (Pads == 3) digitalWrite(pin3, HIGH);
  else if (Pads == 4) digitalWrite(pin4, HIGH);
  else if (Pads == 5) digitalWrite(pin5, HIGH);
//Slå på tid
delay(random(1000, 6000));
//Slå av
digitalWrite(pin1, LOW);
digitalWrite(pin2, LOW);
digitalWrite(pin3, LOW);
digitalWrite(pin4, LOW);
digitalWrite(pin5, LOW);
//Vänta tid
delay(random(2000, 10000));
Something like this?
const byte pinArray[] = {2, 3, 4, 5, 6, 7};
int Antal;
  for (int i = 0; i < 6; i++)
    digitalWrite(pinArray[i], LOW);
    pinMode(pinArray[i], OUTPUT);
  randomSeed(analogRead(0));
  // Pick a number of pins between 1 and 6
  Antal = random(1, 7);
  // Turn on 'Antal' pins.  Pins can repeat so not always 'Antal' will light up.
    byte pin;
    pin = pinArray[random(0, 6)];
    // Alternately:  pin = random(2,8);
    digitalWrite(pin, HIGH);
  delay(random(2000, 6000));  // Wait for 2 to 5.999 seconds
  delay(random(2002, 10000));  // Wait for 2.002 to 9.999 seconds
