I have connected MPU9250 to my nano 33 BLE sense board. I have the code to read internal sensors of the Nano 33 Ble board as well as to read MPU9250 values through Arduino UNO board. But I can't figure out how to read MPU9250 values using Arduino Nano 33 Ble board wirelessly. Does anyone know how to read the i2c pins (A4 and A5) of this board?
The wire library works fine on the nano33 BLE to read I2C devices, also most library’s for the MPU9250 should also work
I tried using the Wire library and MPU9250 libraries, but somehow it's not working.
Here's what I did:
I connected MPU9250 to Arduino Nano 33 BLE via I2C. Then I uploaded this I2C scanner code:
#include <Wire.h>
Wire.begin();
while (!Serial);
byte error, address;
int nDevices;
Serial.println("Scanning...");
nDevices = 0;
for(address = 1; address < 127; address++ )
Wire.beginTransmission(address);
error = Wire.endTransmission();
if (error == 0)
Serial.print("I2C device found at address 0x");
if (address<16)
Serial.print("0");
Serial.print(address,HEX);
Serial.println(" !");
nDevices++;
if (nDevices == 0)
Serial.println("No I2C devices found\n");
Serial.println("done\n");
delay(5000); // wait 5 seconds for next scan
MPU9250 was detected while scanning for I2C and I could see the address on serial monitor.
Then I uploaded following code to get IMU values from MPU-9250 (this code is working fine when I connect MPU9250 to Arduino Uno via I2C):
/* MPU9250 Basic Example Code
by: Kris Winer
date: April 1, 2014
Modified by Brent Wilkins July 19, 2016
#include "quaternionFilters.h"
#include "MPU9250.h"
#include "Wire.h"
#define AHRS false // Set to false for basic data read
#define SerialDebug true // Set to true to get Serial output for debugging
// Pin definitions
int intPin = 12;
#define I2Cclock 400000
#define I2Cport Wire
//#define MPU9250_ADDRESS MPU9250_ADDRESS_AD0 // Use either this line or the next to select which I2C address your device is using
#define MPU9250_ADDRESS MPU9250_ADDRESS_AD1
MPU9250 myIMU(MPU9250_ADDRESS, I2Cport, I2Cclock);
Wire.begin();
Serial.begin(38400);
while (!Serial) {};
pinMode(intPin, INPUT);
digitalWrite(intPin, LOW);
byte c = myIMU.readByte(MPU9250_ADDRESS, WHO_AM_I_MPU9250);
Serial.print(F("MPU9250 I AM 0x"));
Serial.print(c, HEX);
Serial.print(F(" I should be 0x"));
Serial.println(0x71, HEX);
if (c == 0x71) // WHO_AM_I should always be 0x71
Serial.println(F("MPU9250 is online..."));
myIMU.MPU9250SelfTest(myIMU.selfTest);
myIMU.calibrateMPU9250(myIMU.gyroBias, myIMU.accelBias);
myIMU.initMPU9250();
Serial.println("MPU9250 initialized for active data mode....");
byte d = myIMU.readByte(AK8963_ADDRESS, WHO_AM_I_AK8963);
Serial.print("AK8963 ");
Serial.print("I AM 0x");
Serial.print(d, HEX);
Serial.print(" I should be 0x");
Serial.println(0x48, HEX);
if (d != 0x48)
Serial.println(F("Communication failed, abort!"));
Serial.flush();
abort();
myIMU.initAK8963(myIMU.factoryMagCalibration);
Serial.println("AK8963 initialized for active data mode....");
if (SerialDebug)
// Serial.println("Calibration values: ");
Serial.print("X-Axis factory sensitivity adjustment value ");
Serial.println(myIMU.factoryMagCalibration[0], 2);
myIMU.getAres();
myIMU.getGres();
myIMU.getMres();
myIMU.magCalMPU9250(myIMU.magBias, myIMU.magScale);
Serial.println("AK8963 mag biases (mG)");
Serial.println(myIMU.magBias[0]);
Serial.println("AK8963 mag scale (mG)");
Serial.println(myIMU.magScale[0]);
if (SerialDebug)
Serial.println("Magnetometer:");
Serial.print("X-Axis sensitivity adjustment value ");
} // if (c == 0x71)
Serial.print("Could not connect to MPU9250: 0x");
Serial.println(c, HEX);
// Communication failed, stop here
Serial.flush();
abort();
if (myIMU.readByte(MPU9250_ADDRESS, INT_STATUS) & 0x01)
myIMU.readAccelData(myIMU.accelCount);
myIMU.ax = (float)myIMU.accelCount[0] * myIMU.aRes; // - myIMU.accelBias[0];
myIMU.ay = (float)myIMU.accelCount[1] * myIMU.aRes; // - myIMU.accelBias[1];
myIMU.az = (float)myIMU.accelCount[2] * myIMU.aRes; // - myIMU.accelBias[2];
myIMU.readGyroData(myIMU.gyroCount); // Read the x/y/z adc values
myIMU.gx = (float)myIMU.gyroCount[0] * myIMU.gRes;
myIMU.gy = (float)myIMU.gyroCount[1] * myIMU.gRes;
myIMU.gz = (float)myIMU.gyroCount[2] * myIMU.gRes;
myIMU.readMagData(myIMU.magCount); // Read the x/y/z adc values
myIMU.mx = (float)myIMU.magCount[0] * myIMU.mRes
* myIMU.factoryMagCalibration[0] - myIMU.magBias[0];
myIMU.my = (float)myIMU.magCount[1] * myIMU.mRes
* myIMU.factoryMagCalibration[1] - myIMU.magBias[1];
myIMU.mz = (float)myIMU.magCount[2] * myIMU.mRes
* myIMU.factoryMagCalibration[2] - myIMU.magBias[2];
myIMU.updateTime();
MahonyQuaternionUpdate(myIMU.ax, myIMU.ay, myIMU.az, myIMU.gx * DEG_TO_RAD,
myIMU.gy * DEG_TO_RAD, myIMU.gz * DEG_TO_RAD, myIMU.my,
myIMU.mx, myIMU.mz, myIMU.deltat);
if (!AHRS)
myIMU.delt_t = millis() - myIMU.count;
if (myIMU.delt_t > 500)
if (SerialDebug)
// Print acceleration values in milligs!
Serial.print("X-acceleration: "); Serial.print(1000 * myIMU.ax);
Serial.print(" mg ");
// Print gyro values in degree/sec
Serial.print("X-gyro rate: "); Serial.print(myIMU.gx, 3);
Serial.print(" degrees/sec ");
// Print mag values in degree/sec
Serial.print("X-mag field: "); Serial.print(myIMU.mx);
Serial.print(" mG ");
myIMU.tempCount = myIMU.readTempData(); // Read the adc values
// Temperature in degrees Centigrade
myIMU.temperature = ((float) myIMU.tempCount) / 333.87 + 21.0;
myIMU.count = millis();
myIMU.yaw = atan2(2.0f * (*(getQ() + 1) * *(getQ() + 2) + *getQ()
* *(getQ() + 3)), *getQ() * *getQ() + * (getQ() + 1)
* *(getQ() + 1) - * (getQ() + 2) * *(getQ() + 2) - * (getQ() + 3)
* *(getQ() + 3));
myIMU.pitch = -asin(2.0f * (*(getQ() + 1) * *(getQ() + 3) - *getQ()
* *(getQ() + 2)));
myIMU.roll = atan2(2.0f * (*getQ() * *(getQ() + 1) + * (getQ() + 2)
* *(getQ() + 3)), *getQ() * *getQ() - * (getQ() + 1)
* *(getQ() + 1) - * (getQ() + 2) * *(getQ() + 2) + * (getQ() + 3)
* *(getQ() + 3));
myIMU.pitch *= RAD_TO_DEG;
myIMU.yaw *= RAD_TO_DEG;
myIMU.yaw -= 8.5;
myIMU.roll *= RAD_TO_DEG;
if (SerialDebug)
Serial.print("Yaw, Pitch, Roll: ");
Serial.print(myIMU.yaw, 2);
Serial.print(", ");
myIMU.sumCount = 0;
myIMU.sum = 0;
} // if (myIMU.delt_t > 500)
} // if (AHRS)
But after uploading this code, Arduino board is not even getting detected. No serial port is shown. Can you tell what modifications are needed in this code?
RakhiAg:
That is a good sign.
Which MPU9250 library are you using?
I am using MPU9250.h library by Sparkfun. I am following the code developed by Kris Weiner from this link: GitHub - sparkfun/SparkFun_MPU-9250_Breakout_Arduino_Library: Arduino sketch for MPU-9250 9DoF with AHRS sensor fusion
Edit: I just changed the library to the Bolder Flight library and it worked. But now the issue is that I want to use the functions from Sparkfun library because BolderFlight library doesn't have self-test and DMP of MPU-9250. But since both libraries have same name and class structure, I can't use. I tried to figure out why the Sparkfun library is not working and Bolder Flight library is working, but couldn't. Can anyone figure out how to make the SparkFun library work with this board?
