How to read multiple sensors through the serial?
Hi guys
I hope you can help me.
I have connected 4 force sensors to an Arduino, and I´m sending the data to the serial port simultanious – no problems so far.
Now I would like Matlab to read the serial and plot 4 graphs, 1 from each sensor.
The data in the serial are organized in 8 coloums with a description and the value for each sensor.
My problem is, that I dont know how to seperate the serial so each of the four dataset is placed in its own variable so I afterwards can make the plots.
This is my code:
clear all
clc
arduino=serial('COM4','BaudRate',9600);
fopen(arduino);
x=linspace(1,100);
for i=1:length(x);
y(i)=fscanf(arduino,'%f');
end
fclose(arduino)
This very basic code only reads the first "coloum" in the serial - how do I add the other coloum, so I can get that data as well?
I appreciate any help :slight_smile:
Best regards Kasper
A lot of what you need to do on the matlab side depends on what you do on the Arduino side - that is something you failed to disclose.
What type of data are the sensors sending?
PaulS:
Thank you Paul for your reply. This is my Arduino code:
// Start serial at 9600 baud
// Read the input on analog pin 0:
int sensorValue = analogRead(A0);
int sensorValue2 = analogRead(A1);
int sensorValue3 = analogRead(A2);
int sensorValue4 = analogRead(A3);
// Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
float voltage = sensorValue * (3.3 / 1023.0);
float voltage2 = sensorValue2 * (3.3 / 1023.0);
float voltage3 = sensorValue3 * (3.3 / 1023.0);
float voltage4 = sensorValue4 * (3.3 / 1023.0);
// Print out the value you read:
Serial.print(voltage,4);
Serial.print(" Heel ");
Serial.print(voltage2,4);
Serial.print(" Metatars 1 ");
Serial.print(voltage3,4);
Serial.print(" Svang ");
Serial.print(voltage4,4);
Serial.print(" Calcanus ");
// Wait 100 milliseconds
delay(100);
waski:
Thanks for your reply.
The data i 3.3v/1023 values, depended on how much pressure their is applied to the sensor.
So data is like 0.02, 1.08, 0.00, and so on.
Kasper
So it is related to matlab , not arduino ? :slight_smile: At the arduino site , you have everything quite ok . BTW - when posting code , use code tags ( # icon just above the smileys )
Theoretically, You'd need to give each sensor data stream a unique id for matlab or any app that reads it. Like serial print something like
Sensor1=12.332&sensor2=575.988
Or use a special character for each sensor like
L12.3332b3443.788k333.33
And so on. So then from another app, you'd need to parse this.
waski:
Thank you for your reply :slight_smile:
I´ll remember that for next time.
No I dont think my Arduino code is wrong. When I check serial in Arduino the numbers are like, depending on how much pressure I put on the 4 sensors:
Heel 0.0000 Metatars 1 0.5258 Svang 0.4290 Calcanus 0.0000
Heel 0.0258 Metatars 1 1.3258 Svang 0.8871 Calcanus 0.0774
Heel 0.1032 Metatars 1 1.5677 Svang 1.2226 Calcanus 0.0677
Heel 0.1710 Metatars 1 1.4452 Svang 1.0355 Calcanus 0.0871
Heel 0.6484 Metatars 1 1.3161 Svang 1.0677 Calcanus 0.1452
Heel 1.2548 Metatars 1 1.1677 Svang 1.0839 Calcanus 0.0968
My problem is, that I cant read each coloum in Matlab. I would like to put coloum 2,4,6 and 8 in their individual variable, so that I can make four different graph to time x.
Any ideas?
Best regards Kasper
mistergreen:
Thanks you for your reply.
That makes sense.
But I dont understand if you just cant read the individual coloums like I showed in my previous answer?
Or is it just not possible?
Best regards Kasper
you format the data for the computer to read easily, not necessarily you (human).
It's definitely possible. I can do it in various languages but have no idea how matlab works.
Oh, and 'listen' for a carriage return CR, for an end of serial.println. This will tell whatever app to stop listening and start parsing the serial string.
Thanks for the replies guys - I have figured the code out now, and if anybody should have the same problem, here is the code:
clear all
clc
fopen(arduino);
 x=linspace(1,100); % der optages 100 samples
   numcols = 1; %der laves en kollonne med data
   y = {}; %alt data smides i y
for i=1:length(x);
	data =fscanf(arduino,'%f'); % '%f' gør at det er decimaler
     IncomingString = char(data); % den indkomne data laves om til karaterer
     IncomingString = regexp(IncomingString, '\s*', 'split'); %dataen splittes op med mellemrummer og i kolonner.
       Heel(i,1)= IncomingString(1,3); %#ok<SAGROW> % jeg har suppressed en fejl %læser i kolonne 3
       Metatars(i,1)= IncomingString(1,5); %læser i kolonne 5
       Svang(i,1)= IncomingString(1,7);
       Calcaneus(i,1)= IncomingString(1,9);
end
fclose(arduino);
PlotHeel = str2double(Heel); %Omdanner data som er på cell array til double data
figure(1)
plot(PlotHeel);
title('Heel'); xlabel('Samples'); ylabel('Volt');
PlotMetatars = str2double(Metatars); %Omdanner data som er på cell array til double data
figure(2)
plot(PlotMetatars);
title('Metatars'); xlabel('Samples'); ylabel('Volt');
PlotSvang = str2double(Svang); %Omdanner data som er på cell array til double data
figure(3)
plot(PlotSvang);
title('Svang'); xlabel('Samples'); ylabel('Volt');
PlotCalcaneus = str2double(Calcaneus); %Omdanner data som er på cell array til double data
figure(4)
plot(PlotCalcaneus);
title('Calcaneus'); xlabel('Samples'); ylabel('Volt');
%Written by Kasper Stentz, Denmark
this code is not working man :confused:
