How to read the value of a photoresistor and print it out in serial monitor
I need help on how to read the value of a photoresistor and print it out in serial monitor.
// C++ code
  pinMode(12, OUTPUT);
  pinMode(A0, INPUT);
  if (digitalRead(A0) == LOW)
  	Serial.println("av");
    delay(5000);
  if (digitalRead(A0) == HIGH)
    Serial.println("Avlest lysmengde er: ");//print out lightlevel value
    digitalWrite(12, HIGH);
    delay(1000); // Wait for 1000 millisecond(s)
    digitalWrite(12, LOW);
https://www.instructables.com/Read-a-Photoresistor-With-Analog-Input/#:~:text=Click%20to%20create%20a%20wire%20connecting%20one%20photoresistor,ground%2C%20and%20adjust%20its%20value%20to%204.7k%20ohms.
Why try use digital read with a photoresistor when the photoresistor puts out an analog value?
not tested but something
// C++ code
  //pinMode(A0, INPUT);
  int aoRead = analogRead(A0);
  if (aoRead > 1024/2 )
    delay(5000);
  if ( aoRead <= 1024/2)
    Serial.print("Avlest lysmengde er:  ");//print out lightlevel value
Serialprint( aoRead );
I want to know how much light detection it is on the photoresist and print it out in serialmonitor.
consider
find appropriate value for Thresh
#define PinLed  12
#define PinRes  A0
#define Thresh  500
    pinMode(PinLed, OUTPUT);
    int val = analogRead (PinRes);
    Serial.println (val);
    digitalWrite (PinLed, Thresh < val);
is it any way that if the photoresist is max a led flashes?
could do that, but i though you asked how to read sensor value. can you?
can i what?
If you report the exact type number of your photoresistor, then some calculations could be made to find the amount of light it has detected against the resistance value it exhibits.
could you try to explain what happens in this code and how it works? so I can get a better understanding for future
no i cant.thats why im asking for help here
  Serial.print( " a0Read = " );
Serial.print( a0read );
are you asking for help to read the photoresistor value or
have you tried the code i posted to "read the photoresistor value"?
yes?
is that a question?
consider
#define PinLed  12
#define PinRes  A0
#define Thresh  500
unsigned long msecLst;
    unsigned long msec = millis ();
    if (Thresh > val)
        digitalWrite (PinLed, LOW);
    else if (msec - msecLst >= 200)  {
        msecLst = msec;
        digitalWrite (PinLed, ! digitalRead (PinLed));
It's here
https://docs.arduino.cc/built-in-examples/basics/AnalogReadSerial
