How to remove the Arduino Cloud sync?
How to remove the sync between Arduino Iot Cloud connection from the Arduino IDE?
Hi @shameermohamed. I'm not sure I understood your question correctly. If you would like to disable the Arduino Cloud sketchbook integration feature, there is an option for this in Arduino IDE's advanced settings. I'll provide instructions you can follow to do that:
  1. Press the Ctrl+Shift+P keyboard shortcut (Command+Shift+P for macOS users) to open the "Command Palette".
    A menu will appear on the editor toolbar:
  2. Select the "Preferences: Open Settings (UI)" command from the menu.
    You can scroll down through the list of commands to find it or type the name in the field.
    A "Preferences" tab will open in the Arduino IDE main panel.
  3. Type arduino.cloud.enabled in the "Search Settings" field of the "Preferences" tab.
  4. Uncheck the box under the "Arduino › Cloud: Enabled" setting.
  5. Close the Preferences tab by clicking its X icon.
