How to replace relay with transistor
hello friends,
i am doing a project in it i need to use two realys.need to switch 5v and the load is a 3.7v battery for one relay ,and another load is a gas sensor for next relay .it make my pcb bulky.. i need to reduce the product size... so any one can say how to replace a relay with transistor...thank you very much....
What is the maximum current you need to switch for each?
thanks for your reply "strykeroz"....here i attached my circuit for your kind perusal
How does the booster enjoy having 5V at the input?
strykeroz:
More to the point, how does the battery like having 5 V connected directly? You should be using a proper charging circuit. You could then leave the 3.7 to 5 V converter permanently connected to the sensor/controller and no need for relays at all.
Russell.
russellz:
Russell.
hello sir.. thanks for your reply,i forgot to mention that there is charging ckt TP4056 between adapter and the battery..but i do not understand completely you said.. you think if i use a charging ckt then no need of any relays and always take power from the battery not directly from the adapter so no need of switching ,,,isnt it sir?...
ecworks:
Quite.
Russell.
russellz:
Quite.
Russell.
ok no problem
