How to send a http command from my arduino?
Hello.
I'm almost newbee.
I have a arduino 2560+ the ethernet shield.
I need to send a command to my home automate software(Homidom, french software).
The syntax is:
http://192.168.0.177:7999/api/123456789/command/device/4b993548-b81b-4565-9cae-cb2c3f4abcde/SetValue?Value=x
where is x is a variable depending of a sensor.
How can I do that?
Thank you for your help!
Patrick
Basic client test code where you can change the IP address and GET line to your setup.
//zoomkat 12-01-11
//simple client test
//for use with IDE 0021
//open serial monitor and send an e to test
//for use with W5100 based ethernet shields
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte myserver[] = { 208, 104, 244, 25 }; // zoomkat web page server IP address
EthernetClient client;  // connect to web server using port 80
void setup(){
  Ethernet.begin(mac);
  Serial.println("Better client test 12/01/11"); // so I can keep track of what is loaded
  Serial.println("Send an e in serial monitor to test"); // what to do to test
void loop(){
  // check for serial input
  if (Serial.available() > 0) //if something in serial buffer
    byte inChar; // sets inChar as a byte
    inChar = Serial.read(); //gets byte from buffer
    if(inChar == 'e') // checks to see byte is an e
      sendGET(); // call send GET function below when byte is an e
void sendGET() //client function to send/receive GET request data.
  if (client.connect(myserver, 80)) {  //starts client connection, checks for connection
    Serial.println("connected");
    client.println("GET /~shb/arduino.txt HTTP/1.1"); //download text
    client.println("Host: web.comporium.net");
    client.println("Connection: close");  //close 1.1 persistent connection
    client.println(); //end of get request
  else {
    Serial.println("connection failed"); //error message if no client connect
  while(client.connected() && !client.available()) delay(1); //waits for data
  while (client.connected() || client.available()) { //connected or data available
    char c = client.read(); //gets byte from ethernet buffer
    Serial.print(c); //prints byte to serial monitor
  Serial.println("disconnecting.");
  Serial.println("==================");
  client.stop(); //stop client
Thank you for your response.
Excuses for my probably stupid question:
I thougt I had to use the POST function to send the information from my arduino to my home automate software, and not the GET function.
Thanks
Since both GET and POST require you to send information to the server, if you control the server, you can use either and GET is nice and simple.
In your case, it very much depends what your automation system expects.
Hello everybody!
It almost works!! with the command:
client.println("GET /api/123456789/command/device/4b993548-b81b-4565-9cae-cb2c3f4abcd/SetValue?Value=199 HTTP/1.0");
My home automate receive the value 199.
But how can I send the value: analogRead(3) instead of a fixe value (199) ?
Thanks a lot!
