hi gud morning
can u tell me process for sending data to the ip address by using at commands
i.e how to set the ip adress
n how to send the data to ip adress and
how to set gpr settings
for all these what at commands we are using.
and please give the format.
No I can't. Anybody can? I doubt it.
Here is how to use the forum:
hmmm sorry for inconvenience i am new to this forum
please help me in finding perfect 'at' commands to send data to ip
sharif:
I doubt if many members will even know what you're talking about.
What's an "at" command?
If you're using them, surely you know the format?
AT command means attention commands for operating GSM i konw that commands but i am feeling difficulty in dealing with the commands
for example to send data to ip the command for sim300 given as
AT+CIPSEND=?
then how i can use this i mean how to set the lenght and how to send data using this
AT+CIPSEND=?
Set the "lenght" of what? Set what data?
Post your code or go away!
I doubt you are actually using IP directly - more likely you are using TCP or UDP. You need to decide which. Once you've decided, Google will tell you all about using AT commands to send TCP data and so on.
Link to the GSM shield you are using!
Who/what is receiving the data?!
AT+CGATT?
+CGATT: 1
OK
AT+CIPCCON?
+CIPCCON: 1
OK
AT+CLIP?
+CLIP: 1,0
OK
AT+CIPSTART="tcp","213.202.225.39","21"
OK
CONNECT FAIL
STATE: IP IND
+PDP: DEACT
OK
STATE: PDP DEACT
AT+CGACT?
+CGACT: 1,0
OK
OK
STATE: PDP DEACT
these are the at commands i am using in my programme
at the time of starting i am, getting error like this, how to rectify this
Have this in mind, did you tell any one of us what shield you are using? Stop spamming and trolling if you don't intend to provide the basic information! I use a gsm module, not your module, and it needs a series of at commands before it can make tcp connections. Your at commands seem very few.
hmmm i am using sim300 gsm shield and atmega 328 controller
i got some errors like
CME error 107 and
ip ind
when i am dealing with this at commands
Where is the link to this shield's datasheet? Where is your code? Have you read the how to use this forum or just plain left your manner at home?!
hmmm ucan get the data sheet in google
i am sending this commands through serial port
i know how to use this forum thats why i am here posting my problem
if can please help me
i am sending this commands through serialport and i had modified the commnads
COMMAND RESPONSE
AT+CIPCSGP=1,"INTERNET"
OK
AT
OK
AT+CMGF=1
OK
AT+CGATT=1
OK
OK
AT+CSTT
OK
AT+CREG=?
+CREG: (0-2)
OK
AT+CREG=1
OK
AT+CIICR
OK
AT+CIPSTATUS
OK
STATE: IP GPRSACT
AT+CIFSR?
OK
AT+CIFSR
100.106.84.92
AT+CDNSORIP=1
OK
AT+CIPSPRT=1
OK
AT+CIPHEAD=1
OK
AT+CIPSTART="TCP","182.18.161.55","8887"
OK
ERROR: 1
STATE: IP STATUS
WHILE I AM USING AT COMMANDS I AM GETTING COMMANDS LIKE THIS
HOW CAN I OVERCOME THIS ERREOR.....
HMMM K THANK U ALL I HAD SEND THE DATA TO IP SUCCESSFULLY ![]()
can any one please tell me
how can i send this command through serial port
"AT+CIPSTART="TCP","182.18.161.143","3000""
i mean through Serial.println(""); to controller
If you need to include a " character in a string literal, put a backslash in front of it to tell the compiler that it should be treated as a normal character and not the end of the string.
Serial.println("AT+CIPSTART=\"TCP\",\"182.18.161.143\",\"3000\"");
YA ITS WORKING THANK U SIR ![]()
but when i compile the code i am getting error like this
Serial.println("AT+CMGF=1");
Serial.println("AT+CGATT=1");
Serial.println("AT+CGDCONT=\1","IP","INTERNET"");
Serial.println("AT+CDNSCFG=""\182.18.161.143");
Serial.println("AT+CGDCONT="INTERNET","",""");
Serial.println("AT+CIICR");
Serial.println("AT+CIFSR");
Serial.println("AT+CIPHEAD=1");
Serial.println("AT+CDNSORIP=0");
Serial.println("AT+CGDCONT="TCP","\182.18.161.143","3000"");
Serial.println("AT+CIPSEND");
Serial.println("HI THIS IS SHARIF FROM VIEW360 TECHNOLOGIES");
i am using this code for sending data to ip adress. at the time of compiling this code i am getting erro like this
"" call overloaded 'println(const char[13],const char[15])' is ambiguous ""
please help me in executing
There are still double quotes in (at least) one of your strings which you haven't put a backslash in front of.
Or to put it another way, there are four lines which contain embedded double quote characters that should have had backslashes inserted in front of them, and you have made mistakes in every single one of them. Go back and check more carefully.
